Everything posted by Chico
Happy T-Day Everyone!
Coolant Loss. Dip stick clean, and no leaks
Chico replied to RG67MA's topic in MJ Tech: Modification and Repairs
Hold my Lite Beer Fiat!, then pass it to Pete, and dump it on Wahoo. Someone correct me if I'm wrong. If the cap is "sealing" correctly, then there should be NO residue/ blacklight below the top thread of the tank. The seal to the system is at the top thread correct? ANyone? I don't have mine yet so can't physically confirm. There should be "zero" residue on those threads of the tank below the top thread if the cap is sealing properly. It's showing the system is NOT pressurized correctly letting "steam" coolant evaporate thru that opening right? Can anyone tell me if I'm correct or did the Miller Lite's hit early this holiday? Crack me open another one ,and get me the blowtorch Drahc. I got this. Hold this other beer Peteo. And probably a good idea to hold my keys at this point too. Where did I leave that lighter... Where did I leave the car??? -
Not sure if you did this one but have you tried a combustion leak tester yet? I didn't think you could do it with a closed system but Google says that supposedly it will work correctly and tell you if exhaust gasses are getting into the coolant possibly causing the different levels in the tank that you've recorded. -
Go back one page. If you have time and only if you want to, will you take a clear, well lit pic of the inside of the pressure cap and of the threads on the tank for me? Just curious. No need to if both are completely clean with no residue, gunk, or anything on them at all. Lemme know either way will ya? Also, Last mileage was 235,791. Any more data, miles driven, and level check after that report? I might have missed it but, when you burped the system for air, what kind of an angle were you at? -
Everything looks AMAZING dude!
That sucks man. I'm so sorry. Let us know what all you have left over when done though. I'm sure someone can put the leftover stuff to good use. Good luck bro!
Dude, the stories I could tell you about that detector in the last week. Five auto parts stores told me they either didn't rent those out anymore, or/and they had no idea what I was talking about. Then I got that exact number you just gave me, last night when I was searching the net. Called the manager at one of the stores that I had talked to earlier that said they did not have "those". Even the same NAPA I had rented one from in 2008 for my old Comanche told me they had no clue what I was talking about, and IT WAS NAPA! Gave him that part number and #25739 for the test fluid. He magically found both. And he's the manager I'm picking it up this week when I have time. Just haven't had the chance to dig into it yet. I did buy just one NGK plug and a Denso coil in case either broke apart when I pulled the ones at Cylinder 1 to check for coolant. The same idiot at the store argued with me that I was buying the wrong plug and coil even though I verified the brand and numbers 12 times to 6. I think I'm just going to run the leak test first, so if I do find gasses then, I'll return both because they were like $130 bucks dude. I'm telling you guys, One or two of you move up here with me, we open a shop that actually fixes cars, and WE WILL BE RICH. Literally no one here has a clue what they're doing. I am in no way close to being a mechanic AT ALL, or even "handy" for that matter, and I'm still smarter and can do more crap than 90% of the "pros" here. It's like, everyone became an idiot once covid hit. I have partial head trauma/ memory loss and still know more than the guys at the local shops OR dealer. Drac/ Jeff/ Pete/ Eagle/ anyone, let's go. Everyone takes a week working here at the shop we open, and we split the MILLIONS we make, evenly, after paying the overhead.... I'll supply all meals and lodging here. Lesssgoooo!!!!!
Does the fluid in the pill bottle smell like coolant or "sweet"? FYI, I'm not an expert here at all but, I did stay at a Holiday Inn last night. -
Where'd you post this for sale D?
next, When you put the die in the coolant, started up, warmed up, and the system ran... Did you ever take the blacklight back to the exhaust tip and see if the blacklight showed any coolant coming out the tailpipe? Would that even work? -
I guess maybe?? I'm having similar issues with a Corolla right now. Here's another question? Can you pull your spark plugs quick? One at a time and check each? or too much of a hassle? When's the last time you changed them? If you do pull them or have recently.. See if one or more of them looks "steam cleaned" or way too "clean" compared to the others. I wonder if your head gasket has a small leak and is letting coolant into the top of the piston slowly, and it's burning it off that way. That's what I think this Corolla is doing to me but I haven't really dug into it yet. Just another idea if you're bored. I want to tear down this Corolla but am waiting to get my jeep back because, it's my only ride and don't want to get left completely "car-less". And now I'm going to re-read this whole thread form the beginning just to hear everything again. I'm seriously interested to see what the lab results say. -
Thanks, I'm starting to lean toward it has a head gasket leak. Still need to actually get to it though.
Ok, I started researching some online. Thanks for all the input guys! 1) Majority rules so we're going gas, not electric. 2) One of these engines, " tecumsech, honda, yamaha, honda, briggs and stratton" 3) Brand? Guess there's plenty of options 4) PSI, no less than 2000 5) GPM ? 6) Plenty of nozzle options and a foam cannon So now, Forget cost, let's say budget doesn't matter.... I give each one of you an empty credit card, and tell you the stuff I'll be cleaning yearly with it at my house. (the stuff mentioned above), and then using it at my 80 year old aunt's house, and my 65 year old cousin's house, and the two 70 year old ladies that live next door, and...you get the picture. ( Renting not a good choice Pete.) ( My $250, 20 year old, marketplace, 42" deck, lawn tractor, runs for 6-10 hours straight every Saturday during the summer. (lol) ( Craftsman, It's got a Honda engine ) So I give each one of you guys that blank credit card and say, "go!" What gas powered pressure washer you bringing home? Brand? PSI? GPM rate? HP? And let's get a move on it Pete. (Wahoo's not here so, I gotta harass someone constantly, sorry.) After this we're doing "basic tools needed for a complete teardown". Or do we have that thread already so I can save some time? "AND GOOOOOOOO!!!!!!!"
Beatrice should be coming home this weekend. Decided first thing I wanna do before it gets too cold is wash her down well, and try to get rid of 10 years worth of grime build up on her due to being left "abandoned" in a field . Never bought a pressure washer up until now. Been looking thru marketplace. I want to try and get something "good" that will hold up in the future and that I can also use to clean the exterior house walls, wooden decks, concrete slabs, gutters, etc.. I'm partial to DeWalt, just because I like yellow Seriously though guys, what should I look for? Gas powered? Brand? PSI? Anything else anyone recommends? All opinions welcome and appreciated! Thnaks!
The Ultimate "While I'm In There" (Advice Needed)
Chico replied to Backpacker's topic in MJ Tech: Modification and Repairs
And keep us updated please! I'm looking at doing the same thing here...maybe. lol -
Any updates dude? -
That is beautiful!!! I am so jealous!
Hi! Welcome! First thing.. Who's truck on the right in that last pic? That was a rude first question, my apologies. But who's truck is that by the way? Oh, and My name is Chico. But, most people call me Chico. I know, it's weird. My parents were hippies in the late 70's when I was conceived by mistake. Again welcome!
Well, I asked AI about AI and this was it's response. Honestly though, I am technologically incompetent so a lot of that was an unrecognizable forein language to me but, damn isn't that all amazing? Thanks for the link E. Below is the answer to you question according to Google.
AnotherOldJeepGuy Also just read your older post where you said you've replaced your plastic tank 4 times already over the years and had problems with the caps already. More and more I'm leaning toward you might be "boiling off" coolant thru the tank or cap again without it being visually noticeable. Does anyone here know if it's possible that your cooling system is under to much pressure? Is that even a possibility? And I'm going to start researching it now but first thing I'd do anyway is get away from the plastic tank and move to an aluminum one. Even if you're not loosing coolant thru there or the connected hoses. -
I just noticed that while going back in time thru 2008 and making myself even angrier that I didn't "step by step" detail how I did everything in my Build post. The link to Mac's that I had is now inactive. So.. Sorry to hijack the thread guys but, where is everyone now getting their tank? Mishimoto? I'm now starting to break out in hives anticipating the MJ getting dumped on my driveway if it ever shows up. -
Here's the pics of the metal tank and plastic bottle we used 20 years ago. I still can't remember exactly why, what, we did who, so I'll have to brush up on my reading. Also, not my pic, think it was Pike's. I started reading old threads and memories started to come flooding back about how much of a PITA this closed system was to deal with back then and am now banging my head against the wall questioning WHY IN THE WORLD I thought it was a good idea to buy an MJ again I'm actually having chest pains from the anxiety about the thought of it. -
Pressure tank. Sorry. You have a closed system correct? Work with me here because I'm not a mechanic, my MJ still hasn't gotten here, and I haven't looked at one of these since 2008. The tank you have is plastic. There's only 3 places that coolant could leak from there correct? The two hoses and the cap. Tell me if I'm wrong because I don't remember that far back. The "Chico" version is replace the two hoses, all the clamps, AND the pressure tank and plastic cap. Then refill and burp the system and see if the loss stops. I remember changing mine to an aluminum one on my 88 back in 2008. Can't remember the brand but should be in my "build" post from 20 years ago if you can find it. The correct version would be to check for leaks somehow under pressure at the hoses and cap. Pull the cap, look underneath, see if it's "cruddy". Reasons I bring this up.. Common problem on JLU's today is the "expansion tank". System pressurizes and heats up, the plastic seam that runs horizontally across the middle of the tank let's vapors escape once the liquid hits a boiling point and some of it turns to steam slowly losing coolant. Once the engine is turned off, the coolant and tank drop in temperature and the tank magically "plastic welds" itself together again with no visible sign of any leaks. Loss is slow to everyone this has happened to but we've all remedied the problem by switching to an aluminum tank from Mishimoto. Note: I didn't have this problem on my JLU. My coolant loss was a very slow "vapor" leak again but from a rubber hose where the system meets the firewall. Never saw a drip either in this instance. MJ.... This system is "more pressurized" (excuse the term, not a mechanic.), 20 years ago I had a similar issue even after replacing the whole cooling system. In my case, the truck would also run HOT even after multiple tries at burping it. Now, I'm sure everything else needed changed anyway since at the time the parts were already 20 years old but, in the end ,the loss of coolant and overheating problem was because coolant was evaporating up thru the old, worn, cracked cap threads on the top of the plastic tank and cap. Once I swapped out the plastic tank and cap to aluminum, all those problems were magically solved, even though none of us ever saw any coolant come up thru the cap opening area. Can't be sure this is your issue but just a long story and suggestion. I'll see if I can find the aluminum tank I used. Keep us updated. Thnaks! -
Do you know how old the expansion tank up against the firewall is?
