question for pete
Is it making any noise? Get out your left-handed whats-it wrench and tighten up the little metal thingie for now. You'll definitely need to replace your doodad in short order, but I think you'll be fine for a while.
don't forget to change your blinker fluid every 1,000 blinks.
This is NOT TRUE!!! I get 3,000+ blinks on a change.
Used to get over 5,000 till the O-ring went bad and started leaking blinker fluid bad :chillin:
i change it every 1000 to insure a long life for the blinkers, plus i make my own fluid. :D
