jodawill Posted July 18 Posted July 18 I finally got around to pulling up the carpet to check for rust. It looks pretty good. Now that I have the carpet out, I have two questions: 1) What else should I do while this is taken apart? 2) What should I do about sound dampening? I've seen concerns that Dynamat may trap moisture on the floor. What should I do?
The86manche Posted July 18 Posted July 18 Scuff it and seal it with some enamel or other tough and comparable product. Spray some rust preventative, like cavity wax in those floor braces too and then you'd be find to put some sound deadening in if you wanted.
watchamakalit Posted Sunday at 10:17 AM Posted Sunday at 10:17 AM Wow. Cleanest floor I think I have ever seen......
ghetdjc320 Posted Sunday at 01:14 PM Posted Sunday at 01:14 PM That is one clean floor! I’d check the seam sealer and identify any possible leaks. If it’s all good, do as recommended above. On my last build after I removed and re seam sealed the cab, I por 15d it then raptor lined it. It’s worked great so far. And I did end up using dynapad on the floor with excellent results. I just don’t recommend the mass backed carpet. For me, it started to crumble and our gas horribly after 3 months.
jodawill Posted Sunday at 04:03 PM Author Posted Sunday at 04:03 PM 2 hours ago, ghetdjc320 said: That is one clean floor! I’d check the seam sealer and identify any possible leaks. If it’s all good, do as recommended above. On my last build after I removed and re seam sealed the cab, I por 15d it then raptor lined it. It’s worked great so far. And I did end up using dynapad on the floor with excellent results. I just don’t recommend the mass backed carpet. For me, it started to crumble and our gas horribly after 3 months. Do you have any tips on installing the Dynapad? Do you know how much I'll need? Are there areas that you didn't cover? I noticed that the original carpet padding didn't cover the entire floor. Also, there were two plastic bags with white padding in them at the front of the cab. I'm not sure whether those actually came with it or if perhaps someone added it later on. Do I need to keep those or use additional carpet padding beyond the Dynapad? 19 hours ago, The86manche said: Scuff it and seal it with some enamel or other tough and comparable product. Spray some rust preventative, like cavity wax in those floor braces too and then you'd be find to put some sound deadening in if you wanted. When you say enamel, do you mean something like Rust-oleum clear enamel? I'd like to keep the original gold paint if I can. There's a very small amount of rust around a few bolts that I need to address, but I don't want to spray a bunch of colored paint and ruin the original finish. (Yeah, I won't see it, but I can't stand the thought of ruining that factory finish floor.) I might just clean up that small bit of rust with a rotary tool and use a stencil to spray the rust converter only on those particular spots.
jodawill Posted Sunday at 04:34 PM Author Posted Sunday at 04:34 PM Here's one of those white pads I mentioned. I'm not sure whether these are original. It seems odd that they're in bags.
Pete M Posted Sunday at 05:18 PM Posted Sunday at 05:18 PM dynapad type products work great on large echo-y sheetmetal like door panels and roofs, less so on small expanses that can't really reverberate. personally I'd skip it on the floors and stick with protecting the steel down the road with the aforementioned products.
jodawill Posted Sunday at 05:36 PM Author Posted Sunday at 05:36 PM 9 minutes ago, Pete M said: dynapad type products work great on large echo-y sheetmetal like door panels and roofs, less so on small expanses that can't really reverberate. personally I'd skip it on the floors and stick with protecting the steel down the road with the aforementioned products. I plan to keep the original carpet. It's in pretty good condition. What would you recommend for the padding? It seemed like the original carpet padding didn't cover the whole floor, but I'm not sure which parts weren't covered. It came out in small pieces. And what about that white padding in the bags? Are those original?
Pete M Posted Sunday at 06:16 PM Posted Sunday at 06:16 PM yes, those are factory. plenty of weird things in an MJ. lol.
fiatslug87 Posted Sunday at 07:36 PM Posted Sunday at 07:36 PM 3 hours ago, jodawill said: Here's one of those white pads I mentioned. I'm not sure whether these are original. It seems odd that they're in bags. Those are from the factory.
jodawill Posted Sunday at 09:37 PM Author Posted Sunday at 09:37 PM I'm concerned about the sound dampening material causing moisture issues. Would it be a good idea to just add some to the transmission hump, the rear wall, and the doors? For the rest, maybe I should just throw that white insulation back where I found it and replace the original carpet padding.
The86manche Posted Sunday at 10:53 PM Posted Sunday at 10:53 PM 6 hours ago, jodawill said: When you say enamel, do you mean something like Rust-oleum clear enamel? I'd like to keep the original gold paint if I can. There's a very small amount of rust around a few bolts that I need to address, but I don't want to spray a bunch of colored paint and ruin the original finish. (Yeah, I won't see it, but I can't stand the thought of ruining that factory finish floor.) I might just clean up that small bit of rust with a rotary tool and use a stencil to spray the rust converter only on those particular spots. You could use a clear enamel if you wanted. And if you didn't want to brush it on and have that brushed look you could grab a cheap harbor freight spray gun and reduce the enamel and spray it on for a smooth look.
Pete M Posted Monday at 12:00 AM Posted Monday at 12:00 AM I bought some closed cell foam for the last truck I refurbed. I wanted something there, but not something that would retain moisture (though the carpet traps it anyways, so does it really matter?). it went down ok. not yet sure what I'll be doing with this new truck.
Gojira94 Posted Tuesday at 02:06 PM Posted Tuesday at 02:06 PM For the sake of posterity and documentation, what's printed on that yellow label on the tunnel? Or is that just a business card lol?
jodawill Posted Tuesday at 09:46 PM Author Posted Tuesday at 09:46 PM 7 hours ago, Gojira94 said: For the sake of posterity and documentation, what's printed on that yellow label on the tunnel? Or is that just a business card lol? It doesn't exactly inspire confidence, does it?
jodawill Posted Tuesday at 10:50 PM Author Posted Tuesday at 10:50 PM The passenger side has a hole in it. Is that supposed to be there? What should I do with it? The driver side has the same circle, but no hole.
jodawill Posted Tuesday at 11:08 PM Author Posted Tuesday at 11:08 PM How do I remove this rubber mat along the firewall?
Eagle_SX4 Posted Tuesday at 11:43 PM Posted Tuesday at 11:43 PM 30 minutes ago, jodawill said: How do I remove this rubber mat along the firewall? It goes all the way up the firewall. The dash needs to be pulled to get it out with out cutting it in half.
jodawill Posted Wednesday at 02:43 AM Author Posted Wednesday at 02:43 AM 2 hours ago, Eagle_SX4 said: It goes all the way up the firewall. The dash needs to be pulled to get it out with out cutting it in half. Thanks. I guess that won't be coming out any time soon. I decided to install Dynapad Xtreme and Dynamat. Maybe I should just put the Dynapad as far up underneath that firewall mat as I can reach without removing it? Do you know anything about that hole in my previous post? Is that supposed to be there?
Pete M Posted Wednesday at 02:50 AM Posted Wednesday at 02:50 AM I would fill the hole with a dab of seam sealer when I got to that step. I see a bit of rust that needs to be addressed.
ghetdjc320 Posted Wednesday at 04:34 AM Posted Wednesday at 04:34 AM 1 hour ago, jodawill said: Thanks. I guess that won't be coming out any time soon. I decided to install Dynapad Xtreme and Dynamat. Maybe I should just put the Dynapad as far up underneath that firewall mat as I can reach without removing it? Do you know anything about that hole in my previous post? Is that supposed to be there? On my MJ I used dynaliner on the firewall since it has an adhesive backing. Dynapad is super nice stuff to work with though. It can be a tight fit near the center co sole to dash area but basically from rocker to rocker and back wall to lower firewall are prime spots for dynapad. Also worth adding some rtv or seam sealer around your floor plugs.
The86manche Posted Wednesday at 02:02 PM Posted Wednesday at 02:02 PM 15 hours ago, jodawill said: The passenger side has a hole in it. Is that supposed to be there? What should I do with it? The driver side has the same circle, but no hole. Yeah, those are just drain holes with plugs in them and seam sealer. Looks like they may have used two different plugs from the factory? But still, oem.
coheed Posted Wednesday at 02:57 PM Posted Wednesday at 02:57 PM 15 hours ago, jodawill said: How do I remove this rubber mat along the firewall? Yeah, you have to remove the dash to get that out. I would at least try to lift it up as much as you possibly can and visually inspect under it. There's been quite a few trucks on here recently that have had rust under it and under the seam sealer under it going up to the wiper cowl, including my own.
jodawill Posted Thursday at 03:57 AM Author Posted Thursday at 03:57 AM What do you do with the POR15? Does it work as a cleaner? Do you just use it with a rag to clean the rust off?
