My 88 Comanche Story and project
My 88 Comanche 4x4 LB with a 4.0L and auto on the floor has been in the family since new, but had not been maintained the greatest.
I was asked to take it to the salvage yard because the accelerator would stick, and had been wrecked, damaged, leaking oil and antifreeze and was unsafe.  I offered to look at it, but was told "No", it's not safe, They had called and got a price from the local salvage yard and was happy with the price offered.
So I picked up the truck, took it to my nephew's shop and went back and paid them the $300.  Yep... $300 !
this Jeep has lived in the garage most of its life.  86, 667 miles.  Seat covers from day 1, interior is immaculate except the head liner, which I will replace.
I am going through the mechanicals now.
1) accelerator sticking (actually idling high) - Reconnected vacuum line
2) Oil leak - No valve cover gasket (just Rtv) Installed new valve cover gasket and corrected the oil leak (Was told the rear main was keeping, but they were wrong)
3) Coolant leak - bad thermostat and again no gasket. Installed a new thermostat with gasket and that issue is gone.
4) dtivers door has rust - replaced window sweep.
5)  floor pans- passenger is solid, drivers side has a 1/4 hole in it.
 Need to replace right outer u joint, repair the small depression in the hood and fender, fix the rust the rusty door, then repaint.
I should have been the towel off the passenger seat, It is flawless as well.
Right now I am setting at a total investment of $738.43 (including the price of the truck). Not to shabby.
If it weren't for me worrying about it rusting out, I wouldn't even consider painting it.
The best quote I have received so far was $3200 for BC/CC.
I have scheduled my MJ in for new paint in November and a spray in bed liner to protect the metal, and new stock bumpers, restoring it back to original.
Down the road I hope to do some modifications like a 2" lift, 16" rims and some Goodrich mud terrains, front winch bumper & winch, and a smittybuilt or rockcrusher rear bumper with integrated receiver. Nothing radical.
Right now money is getting tight, so the boss says NO to the fun stuff, just stock for now.
I just left LOU'S JEEP in Geneva IL with my parts. John is the guy to talk to at (630)232-2862
The fender is flawless, but the hood, although new and wrapped in bubble wrap, has surface rust and a small crease. He had 1 Comanche and 4x4 tag new in the package and 1 each used. I also picked up a piece of the rubber molding that is missing.
He threw in the used tags and the rubber molding. Out the door $191.35!!!
