89 MJ Posted April 7, 2020 Share Posted April 7, 2020 April 2020's Quarantine Comanche Owned by @AZJeff YEAR/MODEL The VIN is for a 1989. I don’t know what model it started out life as, since I have never had the VIN decoded. (I guess I should do that on this forum.) ENGINE/PERFORMANCE · 4.0 is from a 2000 XJ donor, with no modifications (except new cylinder head to replace the infamous “0331” head that was cracked) · The fuel tank and pump are from a 1998 Dodge Dakota, and modified to adapt to the XJ fuel delivery system. All mounting was custom designed to reuse the old MJ hardware where possible. DRIVETRAIN · AW-4 is from the same 2000 XJ, again with no modifications · NP231 is from the same XJ donor vehicle, no mods. · Rear axle is a Dana 44 (open diff.) · Front axle is a D30 low pinion from 2000 XJ COOLING · All metal CSF radiator (3 row) is installed · Stock viscous clutch and electric fan are used ELECTRICAL/IGNITION · Stock ignition system is in place, with the late 4.0 style coil rail · From the cab on forward, the vehicle is wired as a 2000 XJ · The wiring from the back of the cab aft is custom done by me to duplicate the regular MJ features, but adapted to deal with the interface to the XJ wiring, along with the use of the Dakota fuel tank/pump SUSPENSION/STEERING · Vehicle is lifted 3.5 inches above stock height · Steering linkage is stock MJ, except for an upgraded steering damper and a remanufactured Delco/Saginaw steering box · Front control arms are Core 4x4 Adjustable type · Track bar and bracket is Rubicon Express adjustable type · Front shocks are Quadratec Nitro · Rear shocks are Bilstein · Front springs are Rusty’s, but cut ½ inch to achieve proper leveling · Rear springs are of unknown make, but with new rubber bushings installed by me. INTERIOR · Dashboard, door panels and overhead console are from a 2000 XJ in the OEM “Agate” color · Seats are Corbeau black cloth with pneumatic lumbar support · New carpet and headliner were installed to match the “Agate” XJ interior color · The rear cab panel below window was recovered in black headliner material to replace very rough and nasty carpet from original cover BRAKES · A dual-diaphragm master cylinder and booster from 1996 XJ · The front calipers/rotors/hubs are from a 2000 XJ · A rear disk brake conversion using 1996 ZJ parts was installed · Parking brake lever, equalizer assembly and cables from 2000 XJ LIGHTING · High mounted stop light from 1996 Ford Ranger · LED front headlights · 24” LED light bar · LED fog lights EXTERIOR · Paint color is “Mango-Tango Metallic” used on Jeeps from 2010 to 2016 · Bushwhacker fender flares · Rear bumper is custom, made from rectangular tubing, welded, and then covered with bed liner · Front bumper is custom, fabricated from the metal center section of the later XJ bumper. Three bumpers were cut/welded together to create the one-piece wrap-around appearance, and then coated with bed liner. · D-rings are from Quadratec WHEELS AND TIRES · Jeep OEM 16” wheels from Wrangler · Goodyear “Wrangler” 265/70R16 tires MISC · Spare tire carrier was custom designed/fabvricateed by me and uses a Ford Explorer tire ‘winch’ to retain the spare. · Jack and handle are modified from late-model XJ and are adapted to work with the Ford spare tire winch · Entire bottom of chassis is covered in bedliner, as is the interior of the cab (except the doors) Remember That One Time?... Tell Us Your Best MJ Story PRO TIP: Don’t let foreign material fall into the intake manifold and then fail to retrieve it before starting the engine. While installing the new intake manifold gasket on the MJ the other day, I decided it would be a good idea to keep stuff from falling into the hole where the throttle body mounts, and so crammed a hunk of old tee-shirt as a “plug” in this hole, and it worked just fine. When I installed the throttle body, I pulled the tee-shirt plug out and bolted up the remaining intake parts. Now came time to start it up. It starts right away, and runs smoothly immediately. I let it warm up, and check for fuel rail leaks, and all seems good to go. Now for a short test drive. I pull out of the garage, and about 400 yards down the street, the engine starts running rough. REAL rough. I nurse the machine home, and shut it off. I look under the hood, and see nothing amiss. No loose hoses, no disconnected wires. I start it back up, and I hear a VERY noticeable whistle coming (like a MAJOR intake manifold vacuum leak), and it seems to be coming from around the area of the throttle body. I pull the throttle body and begin inspection. The gasket on the bottom looks fine, but then I peer into the intake manifold, and see a small amount of cotton rag material off to one side of the opening. That’s odd…. I grab the rag piece, and start pulling. Out comes a HUGE hunk of tee-shirt, about 15 inches long, and about 4 inches wide. Judging by the burns on the one end, it apparently ran all the way down one of the runners of the manifold, and was probably getting beat up and burned by the intake valve. After I removed the piece, I spent a while fishing in the manifold for any other pieces, but nothing came out. I reassembled it all, and started it up. It ran pretty crappy for a few minutes, and then the engine smoothed out. My theory is that the hunk of tee-shirt rag I stuffed into the throttle body hole was actually TWO rags, and when I pulled out the first one, the second one fell down into the manifold and I failed to see it. When the engine was idling, the rag stayed put. Once I started moving down the street, the airflow in the manifold sucked the rag into the intake port for cylinder #2, and it began to choke on that cylinder, creating the rough running. Now before any of you declare me unfit to work on anything more complicated than a door knob, please know that I have been working on cars for almost 55 years. I had done LOTS of intake manifolds, so this wasn’t a venture into uncharted territory. It WAS, however, the first time I ever left a rag in an intake runner!! In the end, it’s pretty funny. Had my error been made on a more modern engine with limited (or no) valve clearance, I would have been tearing the engine apart after that mistake. Thank God the AMC six is too primitive to have problems dealing with a few bits of cotton rag. CC is Awesome!... Why Do You Think So? I have owned 2 XJ’s in the past, and fell in love with the basic chassis. I had always wanted an MJ, and when I got one, I realized it was just different enough that I needed a forum where I could consult with experts on the MJ. That is what makes the CC so valuable to me—a place where those “in the know” about MJ’s hang out. Congrats Jeff, and always if you would like your MJ to be an MJotM, pm me, it doesn't need to be the nicest or most expensive MJ, you just need to care about it. Link to comment Share on other sites More sharing options...
jdog Posted April 7, 2020 Share Posted April 7, 2020 Congrats, great color. Link to comment Share on other sites More sharing options...
Pete M Posted April 7, 2020 Share Posted April 7, 2020 one of the best, that's for sure Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 7, 2020 Share Posted April 7, 2020 Very nice truck, love the color with the black accents! Congratulations. Link to comment Share on other sites More sharing options...
buxmj Posted April 8, 2020 Share Posted April 8, 2020 Awesome MJ, congrats! Link to comment Share on other sites More sharing options...
JMO413 Posted April 8, 2020 Share Posted April 8, 2020 Congratulations your truck is beautiful. The black and orange just set each other off perfectly! Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 9, 2020 Share Posted April 9, 2020 Very nice. I wish mine was as shiny. Enjoy and glad to have you here on the board. Link to comment Share on other sites More sharing options...
thecodemonk Posted April 9, 2020 Share Posted April 9, 2020 So...beautiful... Link to comment Share on other sites More sharing options...
NHMJXJ Posted April 10, 2020 Share Posted April 10, 2020 Yep, she's a beaut! Link to comment Share on other sites More sharing options...
Ryder86 Posted April 17, 2020 Share Posted April 17, 2020 Very nice, I'm a sucker for an orange jeep, nice color choice! Link to comment Share on other sites More sharing options...
trailseeker Posted April 23, 2020 Share Posted April 23, 2020 So beautiful. That color makes it more pleasing to look at. Link to comment Share on other sites More sharing options...
tugboat95 Posted April 28, 2020 Share Posted April 28, 2020 That thing is gorgeous89 ComancheEliminator2wd4.0L5 speed PukeGoatFactory Original Link to comment Share on other sites More sharing options...
Wolfpack Posted May 8, 2020 Share Posted May 8, 2020 I love those bumpers! Can you lead me anywhere where I can buy some that are similar? Also I love the interior of your Comanche aswell. Hopefully I can get my interior to look as good as that! Link to comment Share on other sites More sharing options...
Car Enthusiast Posted May 15, 2020 Share Posted May 15, 2020 Awesome Comanche! Any pics of the overhead console? @AZJeff Link to comment Share on other sites More sharing options...
AZJeff Posted May 16, 2020 Share Posted May 16, 2020 On 5/8/2020 at 1:18 AM, Wolfpack said: I love those bumpers! Can you lead me anywhere where I can buy some that are similar? Also I love the interior of your Comanche aswell. Hopefully I can get my interior to look as good as that! Expand The front bumper is actually a fabrication using several MJ/XJ front bumpers as pieces. Notice that the contour of the front bumper is segmented, showing that various pieces were cut and then butt-welded together to create the angles needed to match the curve of the front grille. The end caps (which I am not really happy with) were further butt welds with some flat sheet stock to finish the end proper. The entire bumper is covered in bed-liner, so the welds/grinding are concealed under the final coat. Because the bumper is made from factory pieces, the attachment method is factory. BTW, I wouldn't actually use the front clevis' for serious towing/pulling, they are mostly for looks. Link to comment Share on other sites More sharing options...
AZJeff Posted May 16, 2020 Share Posted May 16, 2020 On 5/8/2020 at 1:18 AM, Wolfpack said: I love those bumpers! Can you lead me anywhere where I can buy some that are similar? Also I love the interior of your Comanche aswell. Hopefully I can get my interior to look as good as that! Expand The rear bumper is a complete, from scratch, fabrication using rectangular tubing. After welding/grinding, the entire thing is coated in bed liner. The rear receiver hitch is relatively light duty, but the clevis lugs are serious, and pass through both side of the tubing and are welded on both sides, making them pretty substantial. They are also located very close to where the bumper mounts to the "frame" of the MJ. Here are a couple of pictures. Link to comment Share on other sites More sharing options...
AZJeff Posted May 16, 2020 Share Posted May 16, 2020 On 5/15/2020 at 4:01 PM, Car Enthusiast said: Awesome Comanche! Any pics of the overhead console? @AZJeff Expand The console in my MJ came with it, along with a very sad looking headliner, when I bought the vehicle. It wasn't hooked up correctly at all, but from what I can determine, it came from a later XJ. It's not the same overhead console that was in my 2000XJ "Classic", which was long and contained rear maps lights, so I don't know exactly what year it may have been donated from. The console has a central courtesy dome light, and two map lights, all of which work now. It is fastened to an XJ headliner board that I cut down and recovered with new headliner material. The back of the headliner does not curve down to connect to the rear of the cab like a MJ would, so I added in an aluminum channel (covered in black cloth) that is attached to the inside of the cab with structural adhesive. The blunt end of the back of the cut-off XJ headliner slides above this aluminum channel to be retained in the rear of the cab. Link to comment Share on other sites More sharing options...
CO MJ Posted September 11, 2022 Share Posted September 11, 2022 On 5/16/2020 at 9:56 PM, AZJeff said: The front bumper is actually a fabrication using several MJ/XJ front bumpers as pieces. Notice that the contour of the front bumper is segmented, showing that various pieces were cut and then butt-welded together to create the angles needed to match the curve of the front grille. The end caps (which I am not really happy with) were further butt welds with some flat sheet stock to finish the end proper. The entire bumper is covered in bed-liner, so the welds/grinding are concealed under the final coat. Because the bumper is made from factory pieces, the attachment method is factory. BTW, I wouldn't actually use the front clevis' for serious towing/pulling, they are mostly for looks. Expand What bedliner did you use? Has quite a nice look to it. Link to comment Share on other sites More sharing options...
AZJeff Posted September 11, 2022 Share Posted September 11, 2022 On 9/11/2022 at 3:23 AM, CO MJ said: What bedliner did you use? Has quite a nice look to it. Expand That stuff is Rhino Liner. It was put on at the same time as when the bed of the MJ was done, and was done by a professional shop. Link to comment Share on other sites More sharing options...
