5.9L 360 conversion with all factory gauges
The frame on my 91 jeep comanche rotted out.  It was to the point it was easier to build a new complete frame from cab back than try to repair existing rust.  The following is the journey up until now. This pic is the before I am still working towards the after pic.
The center console I started before the frame rotted out
Nice work, but one comment:   sealing up boxed sections of a frame is a VERY bad idea.   Moisture that is inside the frame at time of welding can now just sit there and go to work creating rust.   This is one of the big issues that plagued early unibody cars.
It's MUCH better to have vent holes, and plenty of them.   Ideally, they should be at least 1/2 inch in diameter, and located on bottom surfaces where water can run out..   Just make sure you locate them where wheel splash won't force road dirt mixed with water into those vent holes.
I know this sounds very counter-intuitive, but you will have FAR less rust on frame with plenty of open holes for air circulation that you will on one that is all sealed up.
I'd agree with having the vent/drain holes in the frame if you can.  Also, you can get spray cans of rust proofing paint specifically set up with a long flexible nozzle designed to paint the inside of tubing.  They're great for painting the inside of frames that have holes like factory frames do.
One example:  https://www.amazon.com/Eastwood-Internal-Coating-Aerosol-Nozzle/dp/B00MROX1J4
  • 3 weeks later...
Wow fantastic work!  Someone mentioned about the moisture in your excellent X frame being sealed.  If you put a Schrader valve on it and inerted it with Nitrogen or any inert gas it would not rust either.  Great job!
Orginal Tach works and accurate
Used oil pressure sending unit for 96 XJ
Used fuel sending unit out of 96 XJ mounted it to 98zj fuel assembly
Only guage left it temp sensor, don't know it I want it in motor or in radiator still working on location
