jeep_pieces
Everything posted by jeep_pieces
  1. Getting closer to finishing console 5.9L out of 98 jeep grand Cherokee runs good
  2. now 10 inch sub fabbed in. Time to mount 1000watt amp, CB radio, and 12v out lets
  3. Both tanks installed / vent lines / fill neck hooked up/ fuel pumped wired in
  4. Tach is wired to negative side of coil no longer receives signal from computer
  5. Orginal Tach works and accurate Used oil pressure sending unit for 96 XJ Used fuel sending unit out of 96 XJ mounted it to 98zj fuel assembly Only guage left it temp sensor, don't know it I want it in motor or in radiator still working on location
  6. Duel tanks to feed 5.9L are ready for leak test. Then cut in holes for roll over vents and off to powder coat.
  7. Already wired in. Just got computer programmed. The goal is to make look as if it could have come from the factory.
  8. Just finished lower part of air box to hold factory air filter.
  9. Just finished lower part of air box to hold factory air filter.
  10. Motor mounts for 360/5.9L. Also little exhaust work
  11. The replacement frame before welded on truck. 3 X 5 X 3/16 box tubing air tight. I can use it as on board air if needed.
  12. The center console I started before the frame rotted out
  13. The frame on my 91 jeep comanche rotted out. It was to the point it was easier to build a new complete frame from cab back than try to repair existing rust. The following is the journey up until now. This pic is the before I am still working towards the after pic.
