ghetdjc320 Posted November 20, 2021 Author Share Posted November 20, 2021 An interesting update to my stand alone efi project: I’ve found that many aftermarket ecu’s don’t want to control the 4 wire iac valve on the throttle body. It’s a stepper motor design and at the very least, uses a lot of extra outputs from your new ecu. My ecu is made to control a pwm idle valve. Basically the idle valve gets constant 12v on one pin then a pulsing ground on the other pin which moves the plunger to control the air bypass. There is no valve I’ve seen that bolts into the stock throttle body. The solution? A 2005-2006 TJ 4.0 throttle body. Not sure why but they switched to a pwm idle valve which works great with the aftermarket ecu. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 20, 2021 Share Posted November 20, 2021 I’ll be looking forward to seeing the finished product! Link to comment Share on other sites More sharing options...
Pete M Posted November 21, 2021 Share Posted November 21, 2021 6 hours ago, ghetdjc320 said: The solution? A 2005-2006 TJ 4.0 throttle body. Not sure why but they switched to a pwm idle valve which works great with the aftermarket ecu. how perfect is that?! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 22, 2021 Author Share Posted November 22, 2021 Inside of hood curing Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 23, 2021 Author Share Posted November 23, 2021 I’ve decided to set aside my stand alone project for the time being and will be listing the system for sale if anyone is interested. I’ll be moving in the near future and don’t have time to work on this at the moment. In the mean time, hood has been completely refinished with a lot of custom work for a much sleeker design. Have all the hardware degreased and now soaking in rust remover. Will install tomorrow. Link to comment Share on other sites More sharing options...
89 MJ Posted November 23, 2021 Share Posted November 23, 2021 Moving back to the mainland or are you staying out in the ocean? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 23, 2021 Author Share Posted November 23, 2021 10 hours ago, 89 MJ said: Moving back to the mainland or are you staying out in the ocean? Still out in the ocean for now Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 25, 2021 Author Share Posted November 25, 2021 Hood finished up. Will cut and polish the whole truck in another week after the clear cures further. Link to comment Share on other sites More sharing options...
JMO413 Posted November 27, 2021 Share Posted November 27, 2021 On 11/25/2021 at 5:48 PM, ghetdjc320 said: Hood finished up. Will cut and polish the whole truck in another week after the clear cures further. Beautiful! That scoop is awesome. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 4, 2021 Author Share Posted December 4, 2021 I cut an polished the roof the other day. That paint had been curing for about 3 months now so it ready to go. Went in order starting with 800, 1000, 1200, 1500, 2000, 3000 grit paper all wet sanded. Finished with 3m trizact single step polish. Ideally I’d cut it to 5000 grit but I have a pretty potent DA that was able to make quick work of the 3000 grit with that polish. Came out great. Next l coated it with Migliore ceramic coating. I used the “Acqua” coating which is made for boats since I had plenty left over from my jet ski. The level of salt spray and rain makes this actually a very good fit for this truck. Stuck the truck under the canopy to let it all cure for 24hrs. Also did the windshield and door windows with rainx after a dawn soap and razor blade treatment. Turned out great. I had forgotten how much better the windshield and wipers perform in the rain with rainx (and similar products). Link to comment Share on other sites More sharing options...
watchamakalit Posted December 5, 2021 Share Posted December 5, 2021 Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 10, 2022 Author Share Posted January 10, 2022 Well guys, that concludes this build. It was a great project that spanned 5 years and traveled the globe. My MJ sold today and will be remaining on Guam. The buyer is a diehard Jeep owner though and it will be greatly appreciated. Link to comment Share on other sites More sharing options...
watchamakalit Posted January 10, 2022 Share Posted January 10, 2022 1 hour ago, ghetdjc320 said: Well guys, that concludes this build. It was a great project that spanned 5 years and traveled the globe. My MJ sold today and will be remaining on Guam. The buyer is a diehard Jeep owner though and it will be greatly appreciated. I hope the new owner finds his way here. Looking forward to watching the new build for sure...... Link to comment Share on other sites More sharing options...
89 MJ Posted January 10, 2022 Share Posted January 10, 2022 Wow, not what I was expecting. Glad you still have the other one, but does this change that trucks plans? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 10, 2022 Author Share Posted January 10, 2022 1 hour ago, watchamakalit said: I hope the new owner finds his way here. Looking forward to watching the new build for sure...... I’m pretty sure he will. He has a busy with a 92 here on island. It was originally sold here as well so I’d be very interested to see the vin registry on that one. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 10, 2022 Author Share Posted January 10, 2022 54 minutes ago, 89 MJ said: Wow, not what I was expecting. Glad you still have the other one, but does this change that trucks plans? The wheels are turning that’s for sure. Stay tuned, should be interesting Link to comment Share on other sites More sharing options...
scguy Posted January 10, 2022 Share Posted January 10, 2022 Aww man, best wishes on the next project. Love this truck. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 10, 2022 Author Share Posted January 10, 2022 Final pic as it drove out of the driveway today Link to comment Share on other sites More sharing options...
howeitsdone Posted January 10, 2022 Share Posted January 10, 2022 Hope there was a pre-sale photoshoot Looks great! Link to comment Share on other sites More sharing options...
Pete M Posted January 13, 2022 Share Posted January 13, 2022 you're going to miss that one for sure. but on to the next project! Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 13, 2022 Share Posted January 13, 2022 see u later bye. Next. Link to comment Share on other sites More sharing options...
