Everything posted by howeitsdone
Electrical connectors compilation
howeitsdone replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Anyone ever find any of these unicorn plug manufactures? The square one was used in late 80 early 90 GM vehicles. From brake lights, to power mirrors, and even XJ tail harness. Seen the male side potentially look like this now, but the markings don't tell anything except A3 is male and A6 is female. I found what looks like the female connector https://nexelec.com/CHRY-4209711/ Of course there are zero in stock but that's a Mopar part number I believe. Doesn't help with modern part numbers or manufactures, but it's a start.. On those 91/92 tail connectors, a few years ago I tried calling and emailing any manufacture I could find that makes ZJ fuel pumps and wiper motors since it's the same plug but I got nowhere. Even spoke to someone at BorgWarner and Delphi (same but separate) and they just shut me down. -
I got about $20 from one of these a few months ago for TurboTax. Looking forward to my pennies here too...
Squirrelly Dan: Coheed's 86 Custom
howeitsdone replied to coheed's topic in Member Projects: Your Comanches
It get's it piping hot in that small space. Definitely need a CO monitor, but helps in those high desert winters when the 0 degree and liner aren't cutting it. -
Thanks! I lived in it for about 6-months so it evolved a slight amount. I could never get the topper carpet right but oh well. Love the bike in the back though! -
Dunno the height of the 20t but I have the 12t and it's too short for a rear axle. Grab their bearing separator kit while you're there though.
Big Ton Leaf Springs Source?
howeitsdone replied to robfg67's topic in MJ Tech: Modification and Repairs
I went there in person when I lived in Utah. The JY next door had some stuff I needed so I stopped in. @jeepmjga got his from there, I think. Maybe he has a different email. -
Zero chance I get 'approved' but might stop by. The irony will be pouring with all of the mall crawlers literally at the mall... lol
+1 for Alcan Springs You can also find a local shop to make them for you if you provide the specs. -
Need Source For Jeep Liberty Advice
howeitsdone replied to AZJeff's topic in MJ Tech: Modification and Repairs
Jeep Forum is pretty active. I'm over there for my WK2 and it's been great! This is the general area https://www.jeepforum.com/forums/jeep-liberty-forums.291/ And this is specific to the early models https://www.jeepforum.com/forums/kj-liberty-forum.28/ -
When I have the time for another hobby, I'll print this one and make an RC. Grille is a bit off so I'll modify but it's free. The one posted by Ωhm is $6.
Don't believe he makes the latch. Don't see it anywhere, but does sell a few other odds and ends.
I'd say you're pretty dang prepared already lol. Tire plugs as mentioned but otherwise you have an AutoZone in your car as-is.
Ax15 3rd gear issues
howeitsdone replied to speeding_infraction's topic in MJ Tech: Modification and Repairs
There are two sizes of the AX-15 input shafts. Since you have an '89 did it come factory with it or was it a swap? -
Need to replace your synchros. A good chance they look like this. Means that when power is applied it can't stay in gear. -
2000 XJ - Red Riddle
howeitsdone replied to howeitsdone's topic in Member Projects: Other Cool Stuff
She's up and running as of today. Lots of things still to do but she drives down the road. Just bought a camper on Tuesday and thinking this could be a perfect tow vehicle if I re-geared it and replaced all of the suspension Trailer only weighs 3,400lbs so I think she'll take it. Just a lot more work still... May sell the 2wd WK2. -
Sway Bar or No Sway Bar?
howeitsdone replied to Bomberjeep's topic in MJ Tech: Modification and Repairs
What's a sway bar?... -
It's for the wiper motors. That female connector is one of the elusive 91/92 tail harness connectors.
Serpentine belt path question
howeitsdone replied to NC Tom's topic in MJ Tech: Modification and Repairs
Fuel and air should only be in the same room during combustion... or the fuel tank, I suppose. It's $40 on Amazon -
Belt squeak - harmonic balancer?
howeitsdone replied to CO MJ's topic in MJ Tech: Modification and Repairs
86 2.5 Heated Intake
howeitsdone replied to TheDirtyJeep401's topic in MJ Tech: Modification and Repairs
CPS Plug inspection. Is this normal?
Welcome to an internet forum -
Jeep splash guards
howeitsdone replied to fiatslug87's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
You can get a pack of test leads with alligator clips for practically pennies from Harbor Freight or Northern Tool. Wago 221 connectors are also great to have around for purposes like this. Heck, a wing-nut connector just for testing if you've got any laying around. Soldering seems like a bit of work just to test. But to each their own.
