Pete M Posted December 21, 2020 Share Posted December 21, 2020 looks like you had fun! Link to comment Share on other sites More sharing options...
89 MJ Posted December 21, 2020 Share Posted December 21, 2020 Why do you not have the hood painted like the rest of the body, out of curiosity? Is it because of the weight of the bedliner paint? Link to comment Share on other sites More sharing options...
Fryedaddy Posted December 29, 2020 Author Share Posted December 29, 2020 On 12/21/2020 at 4:31 PM, 89 MJ said: Why do you not have the hood painted like the rest of the body, out of curiosity? Is it because of the weight of the bedliner paint? Expand no reason, it was like that when I bought it. Just haven’t painted the hood. Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 29, 2020 Share Posted December 29, 2020 because it gives it character. and always something for someone to talk about. fire down below. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 2, 2021 Author Share Posted January 2, 2021 The new year brings new projects. I received a set of 37x14.5 Toyos and will be installing them next week. I’m welding the drop bracket to my track bar. Experienced death wobble a few times and thought it was fixed but it wasn’t. Finally figured out the drop bracket was the culprit. Will be adding a stainless exhaust and 4 or 12 hole injectors as well. Hope to be complete with my mods by February. We’re supposed to be going to Moab this year but not certain Covid hasn’t put a hamper on it. Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 3, 2021 Share Posted January 3, 2021 I'm having simular issues with my track bar bracket. are you welding it to the frame then? i thought about this and was considering the options. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 7, 2021 Author Share Posted January 7, 2021 On 1/3/2021 at 5:28 AM, MiNi Beast said: I'm having simular issues with my track bar bracket. are you welding it to the frame then? i thought about this and was considering the options. Expand If you are using the drop bracket, go ahead and weld it. It appears that the factory bolts have too much leverage against them once the drop bracket is mounted. After my Windrock trip, I had my brother watch the bracket when I would turn. The bracket would move, even with me tightening the bolts as tight as I could. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 9, 2021 Author Share Posted January 9, 2021 The Manche got some new shoes. It will barely fit in my garage now. I have to pull the pin from my garage door opener and slide the door as far forward to get enough height. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 9, 2021 Author Share Posted January 9, 2021 Link to comment Share on other sites More sharing options...
Jesse J Posted January 9, 2021 Share Posted January 9, 2021 that is a tight squeeze that is for sure . also something weird is going on with your profile picture Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 14, 2021 Author Share Posted January 14, 2021 Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 14, 2021 Author Share Posted January 14, 2021 Built with vband clamps for easy removal Link to comment Share on other sites More sharing options...
neohic Posted January 14, 2021 Share Posted January 14, 2021 Such a good looking rig. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 14, 2021 Author Share Posted January 14, 2021 On 1/14/2021 at 2:17 AM, neohic said: Such a good looking rig. Expand Thank you Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 14, 2021 Author Share Posted January 14, 2021 I’m making the flare so they can be pulled easily. Link to comment Share on other sites More sharing options...
89 MJ Posted January 14, 2021 Share Posted January 14, 2021 If the flares are easily removed, aren’t you worried about someone stealing them? Link to comment Share on other sites More sharing options...
MercManche Posted January 14, 2021 Share Posted January 14, 2021 On 1/14/2021 at 1:31 AM, Fryedaddy said: Built with vband clamps for easy removal Expand What size pipe is that? 2.5"? I would like to do a 3" straight back with V-bands like in my YJ. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 15, 2021 Author Share Posted January 15, 2021 On 1/14/2021 at 3:14 AM, 89 MJ said: If the flares are easily removed, aren’t you worried about someone stealing them? Expand I’m not worried, it will be mounted the same way as now just less bolts holding it together. Someone could steal them now if they wanted. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 15, 2021 Author Share Posted January 15, 2021 On 1/14/2021 at 3:43 AM, MercManche said: What size pipe is that? 2.5"? I would like to do a 3" straight back with V-bands like in my YJ. Expand It’s 2.5”, I like the vbands, will be easy to remove. How does 3” do on your YJ? Link to comment Share on other sites More sharing options...
MercManche Posted January 15, 2021 Share Posted January 15, 2021 On 1/15/2021 at 11:45 AM, Fryedaddy said: It’s 2.5”, I like the vbands, will be easy to remove. How does 3” do on your YJ? Expand Gotcha, it sounds amazing and lets the engine breathe so much better. Also turbo back is great. I was wondering because I would love to do the same on my comanche. Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 16, 2021 Author Share Posted January 16, 2021 On 1/15/2021 at 9:50 PM, MercManche said: Gotcha, it sounds amazing and lets the engine breathe so much better. Also turbo back is great. I was wondering because I would love to do the same on my comanche. Expand Hate to say it but Amazon has good pricing on stainless exhaust tubing Link to comment Share on other sites More sharing options...
MercManche Posted January 16, 2021 Share Posted January 16, 2021 On 1/16/2021 at 3:17 AM, Fryedaddy said: Hate to say it but Amazon has good pricing on stainless exhaust tubing Expand Lol, I buy it from my local exhaust guy, very reasonable. anywhere along the underside you might see a 3" pipe not clear? Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 17, 2021 Author Share Posted January 17, 2021 On 1/16/2021 at 3:21 AM, MercManche said: Lol, I buy it from my local exhaust guy, very reasonable. anywhere along the underside you might see a 3" pipe not clear? Expand No, you should be good to go Link to comment Share on other sites More sharing options...
Fryedaddy Posted January 23, 2021 Author Share Posted January 23, 2021 Link to comment Share on other sites More sharing options...
Pete M Posted January 29, 2021 Share Posted January 29, 2021 On 1/9/2021 at 6:21 PM, Fryedaddy said: It will barely fit in my garage now. Expand a minor price to pay Link to comment Share on other sites More sharing options...
