4th Generation MJ project
Got the flywheel removed as well as the pilot bearing. I removed the oil pan and will be replacing the rear main seal soon. I've been getting alot of help from members. I really appreciate it. I started other threads for help and wanted to get some photos in this thread.
After installing the ax15 it no longer sits in the center of the tunnel hole. It shifts freely which is good. The issue is the plastic shift bezel doesnt fit. If the bezel is installed and the 4x4 shifter is in 2wd, all the way forward and I shift into 2nd or 4th the shifter stalk hits the bezel. Do I trim the bezel? Is there a different bezel?
My ax15 is out of a wrangler and so is the shifter stalk. The stalk is shaped different than my ba10 was
