Manche757 Posted July 27, 2018 Share Posted July 27, 2018 I have left headlights on a few times and drained the battery. Has anyone replaced the headlight switch with a newer one that turns lights off or at least buzzes? If so, what did you replace it with? I have an 87 and an 89 Comanche. Hope something works for both. Link to comment Share on other sites More sharing options...
87MJTIM Posted July 27, 2018 Share Posted July 27, 2018 You should check or change the buzzer chime module on the fuse box. It’s either brown or blue Link to comment Share on other sites More sharing options...
Manche757 Posted July 27, 2018 Author Share Posted July 27, 2018 So it had a buzzer when built? Didn"t know that. Thanks! Link to comment Share on other sites More sharing options...
Eagle Posted July 27, 2018 Share Posted July 27, 2018 There was a factory option for what they called (IIRC) "headlight sentinal" in 1988. I ordered it on my '88 XJ. But it doesn't turn off the lights if you forget to turn off the switch. The way it works is that if you turn off the ignition first, and then turn off the headlight switch, the lights stay on for one (or three?) minute(s), giving you time to get to the door. The headlights on my 2000 XJs work the same way, so a newer switch won't do what I think you're looking to accomplish. Link to comment Share on other sites More sharing options...
87MJTIM Posted July 27, 2018 Share Posted July 27, 2018 On 7/27/2018 at 4:49 PM, Eagle said: There was a factory option for what they called (IIRC) "headlight sentinal" in 1988. I ordered it on my '88 XJ. But it doesn't turn off the lights if you forget to turn off the switch. The way it works is that if you turn off the ignition first, and then turn off the headlight switch, the lights stay on for one (or three?) minute(s), giving you time to get to the door. The headlights on my 2000 XJs work the same way, so a newer switch won't do what I think you're looking to accomplish. Expand That's the delay option. There should be a buzzer chime module on the fuse box. The buzzer goes off if: 1) you leave your lights on when you turn off the engine, 2) you have not buckled your seat belt, or 3) you left your keys in the ignition switch when you open the door. Link to comment Share on other sites More sharing options...
gogmorgo Posted July 27, 2018 Share Posted July 27, 2018 I've been pulling the buzzers on my Jeeps cause they're so obnoxious. It doesn't cause any problems to have them missing, so I imagine I'm not the only one who can't stand it. Plus having the buzzer never stopped me from leaving lights on, or keys in the ignition, or anything. When the same alarm means a ton of things, half of which I do deliberately on a regular basis, you really just start ignoring it, until you're trying to diagnose issues with a hack wiring job on the door speakers which means you need to have the door open with the key on, and the buzzer just makes your head want to explode. Link to comment Share on other sites More sharing options...
87MJTIM Posted July 27, 2018 Share Posted July 27, 2018 It won't stop you from doing any of the things I mentioned. It may/will make you look why the buzzer is going off. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 27, 2018 Share Posted July 27, 2018 On 7/27/2018 at 4:13 PM, Manche757 said: I have left headlights on a few times and drained the battery. Has anyone replaced the headlight switch with a newer one that turns lights off or at least buzzes? If so, what did you replace it with? I have an 87 and an 89 Comanche. Hope something works for both. Expand As stated, there will be a blue or black buzzer box installed on your fuse block. If black, there is no "HEADLAMPS ON" buzzer. Only the blue box has this function. Of course, if someone has removed the box, you will have to install one to get the lights on buzzer. Here's a pic of the blue box: Link to comment Share on other sites More sharing options...
Eagle Posted July 27, 2018 Share Posted July 27, 2018 On 7/27/2018 at 5:13 PM, 87MJTIM said: That's the delay option. Expand Understood. That's what he asked about. Quote I have left headlights on a few times and drained the battery. Has anyone replaced the headlight switch with a newer one that turns lights off or at least buzzes? Expand Link to comment Share on other sites More sharing options...
87MJTIM Posted July 27, 2018 Share Posted July 27, 2018 On 7/27/2018 at 7:14 PM, Eagle said: Understood. That's what he asked about. Expand Thanks. However, you did not drag the BOLD over far enough "or at least buzzes." Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 27, 2018 Share Posted July 27, 2018 There's a visual indicator that the lights are on if you walk by either the front or back of the Jeep. If you're turning your lights on during the day and thus forgetting to turn them off, you might want to just get a generic DRL (daytime running light) module and install that instead of turning the lights on. There's also a factory DRL module I believe. Link to comment Share on other sites More sharing options...
Eagle Posted July 27, 2018 Share Posted July 27, 2018 On 7/27/2018 at 7:37 PM, 87MJTIM said: Thanks. However, you did not drag the BOLD over far enough "or at least buzzes." Expand Because the buzzer is not part of the switch, and had already been answered by other members. The point is that the later model headlight switch does not provide automatic operation, which is what he was aksing about. Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 27, 2018 Share Posted July 27, 2018 My keyless system is expandable, with existing circuits and add-on modules......my options are nearly endless. You can also be creative with the stock system. Or, you can develop good habits. Link to comment Share on other sites More sharing options...
dvitha Posted July 28, 2018 Share Posted July 28, 2018 If you wanted to be lazy, but save your self. Put a standard relay to your light switch that gets energized only with the key on. yes you would only be able to have lights on if your ignition is on. At that point you leave lights on as, soon as you pull the key all off. You can also get a delay switch connected to a standard relay. it will keep energized for up to 5 minutes after you turn off. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 28, 2018 Share Posted July 28, 2018 On 7/27/2018 at 4:13 PM, Manche757 said: I have left headlights on a few times and drained the battery. Has anyone replaced the headlight switch with a newer one that turns lights off or at least buzzes? If so, what did you replace it with? I have an 87 and an 89 Comanche. Hope something works for both. Expand Getting back to the OP's original question, the only PnP stock option for a "Headlights On" alarm (buzzer) is to install the 7-pin blue color chime module, p/n 22514857, on the fuse block. They were still available (at least they were last year) from the stealer. It also has has SF8956001076 (AMC p/n) written on the side. But it's easy and cheaper to find at the yard, make sure you pull the one with the blue case and seven pins. Most all 94 and up XJ's had them. I have a bunch of them - if you need shoot me a PM. Link to comment Share on other sites More sharing options...
SVPete Posted July 28, 2018 Share Posted July 28, 2018 On 7/27/2018 at 7:50 PM, DirtyComanche said: There's a visual indicator that the lights are on if you walk by either the front or back of the Jeep. Expand Classic! Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 28, 2018 Share Posted July 28, 2018 On 7/28/2018 at 3:22 AM, SVPete said: Classic! Expand Glad somebody caught that. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 28, 2018 Share Posted July 28, 2018 Classic yuk-yuk faux pas. Yes, the visual indicator works great at night, buy only sometimes during the day. Unfortunately in some states, in some counties, when it's raining in the daytime, the local law requires drivers to turn their headlamps on. Rain stops, drive home, headlamps still on, park in the garage, walk away, don't eyeball the headlamps, night falls, crap happens. I'm sure you can envision this happening. The buzzer prevents this. Cheap protection for us not so vigilant drivers. As I'm sure you are Dirty. Link to comment Share on other sites More sharing options...
Manche757 Posted July 28, 2018 Author Share Posted July 28, 2018 Virginia law requires headlights to be on when wipers are on. Sun comes out and you know the rest. Leave early morn with lights on, arrive later with the sun out also. Thanks for the great info Link to comment Share on other sites More sharing options...
Eagle Posted July 28, 2018 Share Posted July 28, 2018 Connecticut is another state that requires headlights when it's raining or when "visibility is impaired" (which I suppose means fog or smoke). The buzzer in my '88 XJ stopped working a few years ago, and I've gotten zapped a couple of times because I forgot I had them on. Link to comment Share on other sites More sharing options...
gogmorgo Posted July 28, 2018 Share Posted July 28, 2018 I used to just always drive with my headlights on, no matter the weather. The main advantage to this was that turning them off again at the end of the trip was just part of my normal shut-down sequence, and I was rarely caught out, but it also meant I didn't get caught out by sudden decreases in visibility, and also when my headlight switch set itself on fire it was during the day and with fairly reasonable weather, so I had no issues pulling the instrument cluster to blow it out. For me it's also more about being seen than it is to see. Because DRL's are required here, I've caught myself a couple times assuming a car with no lights on isn't moving, and the little orange parking lights many manufacturers aren't always enough. Link to comment Share on other sites More sharing options...
High2by Posted January 5, 2020 Share Posted January 5, 2020 On 7/27/2018 at 5:37 PM, HOrnbrod said: As stated, there will be a blue or black buzzer box installed on your fuse block. If black, there is no "HEADLAMPS ON" buzzer. Only the blue box has this function. Of course, if someone has removed the box, you will have to install one to get the lights on buzzer. Here's a pic of the blue box: Expand I know this is an old thread but I have a slightly different question about this buzzer box. The buzzer box in my truck is black. I thought I was being a hero by replacing my door pins and fixing my interior lights. Well, interior lights are fixed but now the stupid buzzer goes off anytime the drivers door is open. Doesn't matter if the key is in the ignition or not. Is it supposed to? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 5, 2020 Share Posted January 5, 2020 Sounds like something is wrong with the key buzzer. I would love to have my key buzzer fixed and working as it should but it seems like a science to figure it out. Most guys will tell you to rip the buzzer out. Link to comment Share on other sites More sharing options...
High2by Posted January 5, 2020 Share Posted January 5, 2020 I would like the thing to work if I can get it to work right. I'm getting tired of disconnecting the battery every time I go to work on the truck. Maybe the door pins should have been the last "fix" I did... Link to comment Share on other sites More sharing options...
Ωhm Posted January 5, 2020 Share Posted January 5, 2020 LH Door Jamb Switch is a dual (two wire) switch to ground. One for lamps, one for buzzer. Technically speaking buzzer shouldn't work with the KEY OUT. I think removing wire from C276_B might shut off buzzer. Not sure what it will do for the Headlights ON buzz (doesn't seem to be tied into it). If you try this, let us know. Link to comment Share on other sites More sharing options...
