Evolution '88
  • Replies 331
  • 3 weeks later...
  • 1 month later...
Been a while but I've been working on it here and there when I have time.
Cab was sanded and reprimed because it sat too long.
I got all my block sanding done. Spot primed again yesterday.
Windshield is out and channel is cleaned and primed.
The only thing I have left is wet sanding, clean, paint. And I have to build a tent.
I wet sanded a small panel yesterday just to see how it was going to come out, slick.
A little advice, if you paint it yourself make sure you have a plan to control the bugs. They are attracted to paint. I redid my gas door 4 times and a fender and a door 3 times each. JUST when I thought I was safe a damn knat would buzz down and land in my fresh clear.
Yes, I'll be building a tent.
Cast of product- for those who may be interested in painting their own.
I picked up the balance of what I need to paint the cab next weekend.
Lacquer thinner for cleaning.
Denatured alcohol for cleaning.
Liteweight filler for interior, headliner.
Liteweight filler exterior, 3M. (over-metal)
Upol 2 part putty.
Over-metal seam sealer.
Upol 2K primer.
Primer/surfacer for bodywork.
Single stage enamel for frame and under bed.
Base coat black for bumpers, vents, mirrors, flares. (no clear, hardener added)
Single stage enamel for tailgate handle and grille, Sterling to match factory JEEP letters on tailgate.
Base coat Coffee, stock color.
Base coat Pearl, metallic, blue.
Base coat custom color interior match. (no clear, hardener added)
Clear, slow activator.
Reducer, medium, single stage.
Reducer, 50/50 slow and extra slow.
Other, misc, paper, tape, sandpaper (grits- 80-600)......etc....
Thank you guys for the comments.
95% of the cab is acceptable but the 5% I can't live with. I have a couple of areas with too much texture and I also have one run to deal with.
I've decided to let it sit for a week then start wet sanding, I'll respray the clear in a couple of weeks. If I don't now it will never happen.
Also, the engine compartment is a shade off from the body, when I gut the bay again I think I'll do something radical there. :wink:
Apparently there is a term for what I did here, didn't know it was a thing, Flow-Coat.
I got it this time, no sags, no runs, no dust, no bugs, no excessive orange peeling. Helps to use the correct tip too, not the suggested one.
17 hours ago, JMO413 said:
That is simply beautiful. Good work:L:
17 hours ago, kansashogan said:
That looks really nice
Thank you.
Now that I have the truck outside I like it even more, I'll still end up cut-and-buffing it out but it's good, real good.
