ParadiseMJ Posted June 3, 2016 Share Posted June 3, 2016 I dented my oil pan going over a log. Grazed it right in the middle, pushed it in about 1/2" over about 4" "round". No creases, no leaks. I'll replace it eventually, but should I replace it NOW or can I get by for a few weeks. Also the pans I looked at on RockAuto, there are some with an oil level sensor bung. Never knew this was an option. They run around $50-$80 - up to $130. Any body have a preference. Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 3, 2016 Share Posted June 3, 2016 It's okay for the time being (forever, or until you have to take the pan off, if you don't care) unless you heard a really loud *CLANK CLANK CLANK* as the rod smashed the pan as it went by. Buy a good quality pan, or you will have a lot of trouble getting it to seal. Lots of the cheap ones come warped. Link to comment Share on other sites More sharing options...
Zebvance Posted June 3, 2016 Share Posted June 3, 2016 i bought one from summit and It ad to be manipulated to work decent. Link to comment Share on other sites More sharing options...
schardein Posted June 3, 2016 Share Posted June 3, 2016 I smashed mine on a rock about 10 years ago. No need to replace it if it is still running, not interfering with the rotating parts inside, and not leaking. Unless just knowing it's there bothers you. My suggestion for a replacement is get a good original from the junkyard for cheap. I got one from a Grand Cherokee, along with all the nuts/bolts/harness clips, etc for cheap (don't remember how much, the pick-a-part places list their prices on their websites). It's cleaned up waiting to go in, I got a new gasket. Granted, I have a solvent tank to clean mine up in, but a couple cans of degreaser and a water hose would work too. I found a GC with the front axle already removed, which made things a lot easier. Going the junkyard route also gives you the free experience of pulling one off, so you know what you are getting into. Link to comment Share on other sites More sharing options...
91Pioneer Posted June 3, 2016 Share Posted June 3, 2016 If I was you I wouldn't replace it at all. If there's no weird noise and it's not leaking you should be fine. Link to comment Share on other sites More sharing options...
Minuit Posted June 3, 2016 Share Posted June 3, 2016 If you replace the pan (which I wouldn't worry about in this case), use a factory pan or don't bother. Aftermarket oil pans for our engines are junk. Link to comment Share on other sites More sharing options...
88whitemanche Posted June 3, 2016 Share Posted June 3, 2016 This is something to consider after you decide to replace or stay with the same oil pan.... http://www.metalcloak.com/Wrangler-Oil-Pan-Skid-Plate-p/2701.htm Link to comment Share on other sites More sharing options...
gogmorgo Posted June 3, 2016 Share Posted June 3, 2016 My two cents, I've got two 4.0l's with factory pans with dents that still seal. One of them runs great, the other hasn't run since August for unrelated reason. Link to comment Share on other sites More sharing options...
Minuit Posted June 3, 2016 Share Posted June 3, 2016 My dad's car (Buick 3800 engine) has been fine for the last 80,000 miles with a dented oil pan. As long as you didn't have crankshaft-on-oil pan action or a leak, you'll be fine forever. Link to comment Share on other sites More sharing options...
gogmorgo Posted June 3, 2016 Share Posted June 3, 2016 Unless it's a severe enough dent it significantly reduces oil capacity or prevents oil from draining or reaching the pickup. But if it runs for more than ten minutes after the dent happens, you're probably good. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 4, 2016 Author Share Posted June 4, 2016 On 6/3/2016 at 11:29 PM, Minuit said: . As long as you didn't have crankshaft-on-oil pan action or a leak, you'll be fine forever. I don't think it's big enough to decrease oil capacity, a very low speed thump and at the very bottom of the sump. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 4, 2016 Share Posted June 4, 2016 If you eventually replace it, you can use one from the 4.2 with the bash plate. Bolts right on if you use the 4.2 sump tube. Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 4, 2016 Share Posted June 4, 2016 On 6/4/2016 at 12:46 AM, ParadiseMJ said: On 6/3/2016 at 11:29 PM, Minuit said: . As long as you didn't have crankshaft-on-oil pan action or a leak, you'll be fine forever. I don't think it's big enough to decrease oil capacity, a very low speed thump and at the very bottom of the sump. plus, our 4.0L's have the oil capacity of some v8 engines, so there's lots to go around Link to comment Share on other sites More sharing options...
mikekaz1 Posted June 4, 2016 Share Posted June 4, 2016 On 6/4/2016 at 1:34 AM, hornbrod said: If you eventually replace it, you can use one from the 4.2 with the bash plate. Bolts right on if you use the 4.2 sump tube. hmm that's pretty cool. I never noticed those before Link to comment Share on other sites More sharing options...
MJam86 Posted June 4, 2016 Share Posted June 4, 2016 I have a stock oil pan you can have if you decide you want to replace it. I'm about 2.5 hours south of you, so if you ever come towards the bay area you can hit me up Link to comment Share on other sites More sharing options...
terrawombat Posted June 4, 2016 Share Posted June 4, 2016 1/2" dent won't hurt so long as you keep the oil fresh and don't let any sludge build up. If for any reason you need to drop the pan, that'd be the time to replace (or repair dent). Link to comment Share on other sites More sharing options...
Rockfrog Posted June 4, 2016 Share Posted June 4, 2016 Hmm, I've been eyeing up the oil pan on my stroker donor 4.2 for some time now wondering if I could make a better pan from the two. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 4, 2016 Share Posted June 4, 2016 They are fairly popular with the stroker folks as the 4.2 pan is slightly deeper than the 4.0 pan. Thus no metal massaging is necessary when using some of the the taller high-volume oil pumps. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 4, 2016 Author Share Posted June 4, 2016 On 6/3/2016 at 7:07 PM, schardein said: I smashed mine on a rock about 10 years ago. No need to replace it if it is still running, not interfering with the rotating parts inside, and not leaking. Unless just knowing it's there bothers you. My suggestion for a replacement is get a good original from the junkyard for cheap. I got one from a Grand Cherokee, along with all the nuts/bolts/harness clips, etc for cheap (don't remember how much, the pick-a-part places list their prices on their websites). It's cleaned up waiting to go in, I got a new gasket. Granted, I have a solvent tank to clean mine up in, but a couple cans of degreaser and a water hose would work too. I found a GC with the front axle already removed, which made things a lot easier. Going the junkyard route also gives you the free experience of pulling one off, so you know what you are getting into. . So any Jeep 4.0 pan will work in my 88? I spent this morning crawling around under the MJ today. The dent is bigger than I thought. I put a straight edge on it and it measured about 1.25" at the center. The sides are creased in and it wouldn't seem that the pump and pickup have a perfect environment to work in. Like the pump would likely be cocked and the pickup sitting at an angle (if I remember the set up correctly. I also bent up one of my control arms. Good thing I have a set of new arms sitting in my shop. More fixing in my future. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 5, 2016 Author Share Posted June 5, 2016 On 6/4/2016 at 3:14 AM, MJam86 said: I have a stock oil pan you can have if you decide you want to replace it. I'm about 2.5 hours south of you, so if you ever come towards the bay area you can hit me up PM sent Link to comment Share on other sites More sharing options...
terrawombat Posted June 5, 2016 Share Posted June 5, 2016 On 6/3/2016 at 7:07 PM, schardein said: I smashed mine on a rock about 10 years ago. No need to replace it if it is still running, not interfering with the rotating parts inside, and not leaking. Unless just knowing it's there bothers you. It's not so much that a dented oil pan would cause mechanical interference (that'd be a pretty epic dent) but more so that the gap between the oil pump pickup and the bottom of the oil pan gets smaller. This is bad when the engine is at high revs and the oil pump is slurping up more oil. If the gap is too small between the pickup tube and the bottom of the pan it can suck in more oil than what is capable of flowing into the narrowed volume. This causes oil starvation at high RPM and can damage the engine. The gap on the 4L oil pan is actually quite large when compared to other vehicles. Small oil pan dents on other vehicles are commonly known to cause premature engine bearing failure due to oil starvation at higher RPM. Link to comment Share on other sites More sharing options...
mjeff87 Posted June 7, 2016 Share Posted June 7, 2016 The junkyard suggestion is a good one, but with one caution.... Make sure the 'yard didn't punch a hole in the pan to drain the oil from the vehicle before they set it in the yard. I wrestled with a very nice looking pan on a junker one hot summer day for over an hour before I could get it off, only to find a nice round hole in it once I got it on the ground. Link to comment Share on other sites More sharing options...
schardein Posted June 7, 2016 Share Posted June 7, 2016 On 6/7/2016 at 2:36 PM, mjeff87 said: The junkyard suggestion is a good one, but with one caution.... Make sure the 'yard didn't punch a hole in the pan to drain the oil from the vehicle before they set it in the yard. I wrestled with a very nice looking pan on a junker one hot summer day for over an hour before I could get it off, only to find a nice round hole in it once I got it on the ground. Hahaha, I once spent 45 minutes pulling a receiver hitch off an XJ, only to find the back of it completely rusted away when I finally got it off. Looked mint on the front. :doh: Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 8, 2016 Author Share Posted June 8, 2016 I went to the yard today, many 4.0's. All of the gas tanks are pierced. Some of the tranny pans are too. There are a few oil pans with just the drain plug pulled, no piercing. Didn't have time or the inclination to bust out a pan in 95+ degree weather...that friggin yard is toasty and full of Black Widow spiders. May try a different way. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted June 11, 2016 Share Posted June 11, 2016 On 6/4/2016 at 7:41 PM, ParadiseMJ said: I spent this morning crawling around under the MJ today. The dent is bigger than I thought. I put a straight edge on it and it measured about 1.25" at the center. The sides are creased in and it wouldn't seem that the pump and pickup have a perfect environment to work in. Like the pump would likely be cocked and the pickup sitting at an angle (if I remember the set up correctly. I also bent up one of my control arms. Good thing I have a set of new arms sitting in my shop. More fixing in my future. Sounds like it took quite a hard hit, don't know the condition of your MM to block bolts, but suggest you check them if you haven't already. Link to comment Share on other sites More sharing options...
