A-man930 Posted April 3, 2023 Author Posted April 3, 2023 On 3/31/2023 at 12:01 AM, NorthwestMJ said: My “machining” was rudimentary at best LOL. That looks great! I’ve been looking around at bridgeports, knowing it will only open a MASSIVE can of worms. This is the most complex piece I've ever attempted, but only because there were so many steps, not because there was any one "hard" thing to do - all rudimentary! To those with any inclination and means to do so, I would 100% recommend getting a lathe and a mill and learning how to use them. It's been a fun addition and beneficial to this whole resto-mod hobby.
NorthwestMJ Posted April 3, 2023 Posted April 3, 2023 11 hours ago, A-man930 said: This is the most complex piece I've ever attempted, but only because there were so many steps, not because there was any one "hard" thing to do - all rudimentary! To those with any inclination and means to do so, I would 100% recommend getting a lathe and a mill and learning how to use them. It's been a fun addition and beneficial to this whole resto-mod hobby. Are you running your machine in 3 phase? If so, did you do an add a phase?
A-man930 Posted April 23, 2023 Author Posted April 23, 2023 Compressor is a scroll-type from a 2000ish Civic, which natively rotate CCW. Was hoping to fit two of them like this with one as onboard air, but this was complicated enough!
A-man930 Posted September 12, 2023 Author Posted September 12, 2023 On 4/3/2023 at 10:50 AM, NorthwestMJ said: Are you running your machine in 3 phase? If so, did you do an add a phase? Sorry for the no-response on this. I'm using a Variable Frequency Drive; its a pretty popular way to do it nowadays and you can get them cheapish.
A-man930 Posted April 10, 2024 Author Posted April 10, 2024 Homemade bead rolled DOM aluminum and heat shrink hose clamps made for a clean lower radiator hose.
A-man930 Posted April 10, 2024 Author Posted April 10, 2024 I eventually found a parallel-flow A/C condenser for our trucks (I'll provide a link if I can find it) I'm hoping the OE serpentine condenser will flow enough volume to support the liquid-to-air charge cooler. Everything fits so well!
A-man930 Posted April 11, 2024 Author Posted April 11, 2024 1 hour ago, neohic said: Excellent update! Man, I haven't really stopped tinkering with it, but things aren't really worth posting until they're at least somewhat complete... which takes months in my case. Thanks for the kind word.
A-man930 Posted April 11, 2024 Author Posted April 11, 2024 9 hours ago, ghetdjc320 said: Excellent fab work Learning as I go. Thank you.
A-man930 Posted April 11, 2024 Author Posted April 11, 2024 Reusing the ZJ (?) master cylinder I've had for forever. Adding in an adjustable proportioning valve for the rears.
A-man930 Posted April 12, 2024 Author Posted April 12, 2024 Here's the rest of the power steering system (the reservoir from the donor Jetta is shown earlier): -I bent and flared the hard portion of the suction line from some 5/8" tubing from McMaster Carr. -I found AN adapters for the pump and box and had a local shop make the pressure hose with some common JIC fittings. -I'm planning to use the OE trans. cooler in the radiator as a power steering cooler. Upper fitting in the radiator is just SAE flare, but I'm struggling to find a quick connect fitting for the outlet on the bottom...
A-man930 Posted April 22, 2024 Author Posted April 22, 2024 On 4/20/2024 at 5:03 PM, Limeyjeeper said: Quality work!! Thanks!
A-man930 Posted April 24, 2024 Author Posted April 24, 2024 I think I have found a solution for the cooler outlet. Out of the box, Dorman 800-121 doesn't engage because the barb on the radiator-side is too long. Against my typical preference, I elected to shorten the barb. I would have greatly preferred replacing the fitting in the radiator, unfortunately, it's soldered onto the cooler. My only remaining concerns are 1. The possibility that I cut off more length than necessary, leaving only one of the o-rings left to seal 2. That the o-ring material may not be compatible with power steering fluid.
89 MJ Posted April 24, 2024 Posted April 24, 2024 It’s good to see a bunch of progress on this truck again.
A-man930 Posted April 25, 2024 Author Posted April 25, 2024 18 hours ago, 89 MJ said: It’s good to see a bunch of progress on this truck again. I agree. Life has this way of slowing these things down.
Comanche SS Posted April 29, 2024 Posted April 29, 2024 13 hours ago, A-man930 said: Track bar progress today: How close is the track bar/oil pan with full compression?
A-man930 Posted April 29, 2024 Author Posted April 29, 2024 52 minutes ago, Comanche SS said: How close is the track bar/oil pan with full compression? The most we managed to find was the cast UCA mount on the diff hit the power steering inlet, but this is well beyond where the tires will be stuffed hard.
A-man930 Posted May 24, 2024 Author Posted May 24, 2024 Scored a set of JT steelies for $10 a pop. I like them!
