carnuck Posted November 22, 2010 Share Posted November 22, 2010 watched the snow fall on it as I leave for work Link to comment Share on other sites More sharing options...
reece146 Posted November 23, 2010 Share Posted November 23, 2010 Blasted the bed bolts with penetrating oil yesterday. Maybe I'll get the box off today - the weather is supposed to clear, get the Jeep moved into the garage... maybe. Link to comment Share on other sites More sharing options...
comanche12 Posted November 23, 2010 Share Posted November 23, 2010 replaced lower radiator hose thats cause leaked. refill the coolant and burp it out. no more leak! :cheers: now there no more leak from my jeep so far :cheers: Link to comment Share on other sites More sharing options...
GreenF350 Posted November 23, 2010 Share Posted November 23, 2010 First "legal" drive in over a year. Got it registered today and wow, my brakes suck. Its good to be back driving a Comanche again. Oh, and in the few hours its been registered, its already consumed almost $100 in gas,oil change,coolant, alignment etc. Good to be back. Link to comment Share on other sites More sharing options...
comanche12 Posted November 24, 2010 Share Posted November 24, 2010 working on electric gremlin with blower motor issue, turn signal and brake light :ack: Link to comment Share on other sites More sharing options...
dfreeman616 Posted November 24, 2010 Share Posted November 24, 2010 in the last few days... 1. replaced d44 pinion flange/seal. 2. replaced d44 right axle bearing/seal 3. fixed exhaust from cat back with tailpipe 4. replaced exhaust manifold and remove one broken bolt 5. replaced water pump 6. replaced t-stat with stock unit, back flush heater core with water and compressed air...HEAT WORKS! 7. replace coolant tank with extra one 8. replaced aftermarket oil pressure sender/tube with stock one to eliminate oil leak 9. replaced left front unit bearing under warranty, timken bad that quick? what? 10. discover bad left front u-joint at same time, replace u-joint 11. fix driver's door so it locks 12. replace headlight switch and rewire power source for park lights and instrument lights i think that's about it...oh and an oil change Link to comment Share on other sites More sharing options...
comanche12 Posted November 24, 2010 Share Posted November 24, 2010 just ordered extended ss brake hoses :banana: Link to comment Share on other sites More sharing options...
jimmy21669 Posted November 25, 2010 Share Posted November 25, 2010 Wow....I worked my butt off is what I did. Finished rebuilding my AX4...first time effort and it did NOT come without it's pitfalls. I shattered my cluster gear bearing, but was able to build a new one with parts I had. Once I got the whole shebang reassembled, I reinstalled everything into the MJ. The Purple People Eater is now OFFICIALLY a 4x4 a MAY make it's debut in December. :banana: :banana: :banana: This was a very rewarding challenge. I now know how to rebuild manual transmissions which is a major plus! Link to comment Share on other sites More sharing options...
beaterheep Posted November 25, 2010 Share Posted November 25, 2010 finally wired up the led strobes ive had here for a week. put the tailgate back on, loaded the jeep and the trailer with 85 bucks worth or scrap, next is the trans swap, add 2" front spacers to the coils, new clutch, trim the rear quarters and add to the rear bumper, come spring new rims and 35's. go figure its too damn cold out now... Link to comment Share on other sites More sharing options...
JohnQ Posted November 25, 2010 Share Posted November 25, 2010 Put the starter back in after having it tested yesterday, but I wasn't able to try and start it. I have no idea what is going on with it. Then I got in trouble with the wife because I was suppose to be getting ready to go to the in-laws. Now I'm at my in-laws wishing I was still working on my truck! Link to comment Share on other sites More sharing options...
cluricaunne Posted November 25, 2010 Share Posted November 25, 2010 I cleaned off all the snow, and cleaned out the garage. As soon as my roommate wakes up, I can put the two together, and finish the jeep in the garage... yay :clapping: Link to comment Share on other sites More sharing options...
JohnQ Posted November 25, 2010 Share Posted November 25, 2010 cluricaunne said: I cleaned off all the snow, and cleaned out the garage. As soon as my roommate wakes up, I can put the two together, and finish the jeep in the garage... yay :clapping: Snow sure would be nice right now, it's around 80º here in TX! Link to comment Share on other sites More sharing options...
cluricaunne Posted November 25, 2010 Share Posted November 25, 2010 JohnQ said: Snow sure would be nice right now, it's around 80º here in TX! I'd trade you in a heartbeat, snow really sucks when the jeep is the only rig I have that will get around in the stuff... Link to comment Share on other sites More sharing options...
comanche12 Posted November 25, 2010 Share Posted November 25, 2010 SNOW FTW! Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 26, 2010 Share Posted November 26, 2010 The Boss's MJ has been sitting, not driven since the last time I fixed it, I think for a broken heater control valve, its been a month or so since I did that. Anyways, he gives it to our cleanup guy this morning to take to pick something up 2 cities over. He makes it two miles up the road before it dies, and the boss called me to go get him. Took a jump box with me, and we jumped it off, it ran fine as long as it had the jump box on it, take the jumper off, and it boggs, spits and sputters. The negative cable was not fully tight, and the cable itself is in REALLY bad shape. I figured at the least it was a bad cable causing it to not be able to charge, so we shoved the jump box in the engine bay, cliked the hood down to first latch, and drove it back to the dealership. I got a new cable for it, and then tested to see if the alternator was putting out..... NOPE. Ordered a new alternator, to be put on monday. :shake: Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 26, 2010 Share Posted November 26, 2010 Ordered a Yukon Locker for the D30 on my 88 Link to comment Share on other sites More sharing options...
flyn2er Posted November 26, 2010 Share Posted November 26, 2010 Hit the JY for some parts for the jeeps .MJ got a trac bar, interior lights and compressor for the OBA. XJ got a 136 amp alt. Link to comment Share on other sites More sharing options...
MJCARENA Posted November 28, 2010 Share Posted November 28, 2010 Replaced the starter. Took it to Lowes to get roofing stuff and when I went to go back for some 2x4's it wouldn't crank over. :( Banged on the starter and it started right up. Used my other truck and got a new starter and the 2x4's. At least it broke at the house. The wife said that the MJ doesn't like to have to do any work. She called it a princess. :nuts: Link to comment Share on other sites More sharing options...
SW86 Posted November 30, 2010 Share Posted November 30, 2010 put on a new track bar end and started it up to let it warm up. its raining now so I'm sure itll be muddy later :D man i need some rocks to crawl on, that mud is fun but a b***h come clean-up Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Share Posted November 30, 2010 removed my blower motor last night and retest and try put oil in it as other thread recommend to. now its spinning fine :nuts: while removed it out. guess what i found a box that bolted on the plate that support coolant expand bottle? :yes: but its didnt hook anything and just sit there cover with mud :no: Link to comment Share on other sites More sharing options...
ryno56 Posted November 30, 2010 Share Posted November 30, 2010 comanche12 said: removed my blower motor last night and retest and try put oil in it as other thread recommend to. now its spinning fine :nuts: while removed it out. guess what i found a box that bolted on the plate that support coolant expand bottle? :yes: but its didnt hook anything and just sit there cover with mud :no: nice find! I'd clean it up and ebay that thing. spend the cash on something USEFUL. Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Share Posted November 30, 2010 ryno56 said: nice find! I'd clean it up and ebay that thing. spend the cash on something USEFUL. thats what I'm thinking :idea: how many should i sell for it. Link to comment Share on other sites More sharing options...
ryno56 Posted November 30, 2010 Share Posted November 30, 2010 http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=msd+6200&_sacat=See-All-Categories looks like you may only get $50 to $100 for it. For what it's worth I would hang on to it after all. Link to comment Share on other sites More sharing options...
comanche12 Posted November 30, 2010 Share Posted November 30, 2010 ryno56 said: http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=msd+6200&_sacat=See-All-Categories looks like you may only get $50 to $100 for it. For what it's worth I would hang on to it after all. good enough to buy me new shocks for front that i damaged it anwhile ago Link to comment Share on other sites More sharing options...
cluricaunne Posted December 1, 2010 Share Posted December 1, 2010 pulled a new headlight harness off of an XJ in my yard today, need to dissect it, pull the pins, and clean it up, then make it work on the MJ Link to comment Share on other sites More sharing options...
