what did you do to your MJ today?
JeepcoMJ
I just want to say this thread should be stickied!
I picked up a set of 33" Toyo AT's wrapped around some Eagle Alloy 137's for cheap. I also got my wiring issues squared away and worked on the interior a bit. Oh, and I washed it for the first time!
RockMJ
Hey automan2164. I saw you have a ZJ up on NAGCA. I'm a moderator on there actually! I havent been all that active due to selling off the ZJ but I still lurk around. Nice ZJ!
RockMJ (RockZJ)
Thanks! I like it, but would like something diesel powered, and stick. The NAGCA crowd is cool, but very... Well, different?
Rob
took insurance off of it and transfered the coverage to a minivan...
don't worry, there's some big plans in the works
:peek: :wrench: :wrench: :fs1: :grrrr: :wall: :wrench: :wrench: :help: :wrench: :wrench: image_209027.gif :wrench: :wall: :wrench: :wrench: :wrench: :wrench: :wrench: :wrench: :wrench: :wrench: :wall: :wrench: :wrench: comanche.gif
or something like that
Replaced the alternator and belt. Bearing went out on the alternator, freezing it up solid, and the belt broke trying to go around the non turning pulley. Found out some of the earlier alternators had both a grove for a V belt and the ribs for a serpentine.
Dismantled the front brakes and greased up the slide pins and pad bars so all the moving parts slip and slide easier. Lubed everything that has a zerk in it. Lubed one end of the carden joint but couldn'r get to the front one as cross-member was in the way. Drilled a 5/8 hole through it so I could line up on the front zerk and broke off the needle about half way through getting it lubed.
