87MJTIM
    9
Everything posted by 87MJTIM
  1. If I recall, the XJ inner-boot doesn't fit. I purchased this several year ago. It is a shifter boot from a TJ. It was "almost" a perfect fit: http://www.quadratec.com/products/55014_0949_14.htm
  2. From the 88 electric manual: Connector 2, pink wire: power feed from fuse panel "Dome Fuse 10 amp" Connector 3, black wire: direct ground. When you rock the courtesy light either up or down, the light turns on. Connector 1, black w/ white trace: provides ground through light switch when resistor is turned up/on. The dome light has a ground side switch, not a power side switch.
  3. http://www.cherokeeforum.com/how-tos/a/jeep-cherokee-1984-2001-how-to-replace-dome-light-399029 Seek and you shall find
  4. I had a 91 XJ with the same center, overhead console. I don't remember how to (or if I ever) changed the light bulbs.
  5. Is it a complete loss of all power - engine shuts off and light go out? Check the CPS.
  6. There are lots of write up on here about this. I did this swap last year (I did a thread). Here is a (partial) list of the parts you will need. Get the trans cross member from the donor. The BA will not fit properly. Get the fork that is inside the bellhousing. Get the tcase shift linkage. It is positioned differently than the BA (same tcase, just positioned differently). You should change the clutch and pressure plate to a 97 model. Search RockAuto. You will need a pilot bushing. The 97 trans input shaft tip is .75" vs. the BA is .5" You will need to get a new slave cylinder. Consider buying the hydraulic kit: it includes the master/line/slave all in one. Search Rockauto. Do not get the kit for 98+. The master cyl will interfere with the brake booster. I am sure I am leaving things out. Good luck. I love the AX15. I got rid of the stupid internal slave cylinder.
  7. Bringing this back from the dead. Yesterday, I stopped at a store. I parked directly in front of the window/register of the store. While waiting at the counter, I saw a young man (he was probably early 20s) walking in front of the window. He stopped to look at my MJ. He pulled out his cell phone (no one has camera anymore) and proceeded to photograph the truck from three angles. He walked away from the direction he came. By the time I got out of the store, he was gone.
  8. I recently changed my bushings (only took 29 yrs). I pulled the unit out without a problem. Changed one bushing at a time. Went to put the unit back in.... It took me a LONG time to figure out how to slide it back in to place. :fs1:
  9. Just a note: An auto, AW4 is longer than an AX15. The front drive shaft will need to be shortened or a manual trans front drive shaft will be needed.
  10. Mine has been running at 160* for years. That's after two 'stat changes. I figured it was the temp sending unit or the gauge. A cluster swap with diff gauge did not change the temp, thou. On one really hot day this summer with the AC running, the gauge did creep up close to 200*. Then I guess the e-fan kicked on and the temp dropped back to the new normal. Perhaps I will search for a "Motorad" stat. Edit: Maybe not. A search of their website does not show retailers in the mid-Atlantic.
  11. The PO may have installed a later model XJ axle - Chrysler 8.25. This is considered a better axle than a Dana 35, that most likely came from the factory. (A Dana 44 was an option for MJs). Additionally, the factory gear ratio for a 4.0, 5 speed was 3.07. You should check the current gear ratio. If the XJ axle came from an auto trans, then the ratio would be 3.55. The front axles used for MJs and XJs was a Dana 30. If the rear axle changed to 3.55, make sure the front axle matches that ratio.
  12. Search craiglist for either a trans or even a full donor XJ.
  13. My BA10 used to get a high pitched whine in lower gears when I would rev it up to 2500 - 3000 RPMs. This only occurred in 1st and 2nd while accelerating. Since the upper gears never (very seldom) rev'ed that high, I never heard it when driving. I figured it was a set of bearings going bad, not the throwout bearing. This was just another reason to swap to an AX15.
  14. What color? I have a tan/beige full length console from a 93 XJ, including the black top tray (whatever it is called).
  15. Other than a lift, you did not say what, if any, modifications/changes were done to the MJ. Since it is an 88, I assume it is still a Renix. Before anyone else chimes in, you should perform Cruiser's Renix Tips. http://comancheclub.com/topic/48463-cruisers-mostly-renix-tips/ Put in your signature a description of your MJ (Yr, eng, trans, mods done) and your location.
  16. Don't need to replace/change the clutch. Sorry. Sometimes my fingers can't keep up with my mind.
  17. Be prepared to take the upper half of the engine apart: valve cover, intake and exhaust manifolds, and lots and lots of wiring. Use masking tape to label all the wires and connectors. Bag-N-Tag all loose nuts and bolts. Be sure to take pictures of all the parts before removing them. This way you can see how it was on there originally. For parts, you will need a new head gasket, valve cover gasket (unless it is a blue FelPro), and to be safe, purchase new head bolts. Since the engine (probably) overheated, you should take the head to a machine shop to have examined and cleaned up. If it warped, you don't want to put it back on that way. Search YouTube for videos of how to remove/install a Jeep 4.0 cylinder head. There are a lot on there. One is "Nickintime." He has a lot of videos on his XJ. There are several on replacing the head.
  18. Just to be clear, you want "from the bellhousing on back" for all the parts, correct? If the clutch on has 10k, then I do think you need to change. Just get a larger pilot bushing. (See my thread on swapping my BA10 to an AX15: http://comancheclub.com/topic/48136-my-ax15-swap/?hl=ax15+swap)
  19. The tcases from one AX15 to another AX15 will be the same. (Just throwing things out in no order) To go from an internal to external, you will need the ext bell housing, the release fork, holding spring/clip, the fork holding ball (what ever it is called)(these may come with the new trans). The new trans will need to have the proper front bearing retainer cover. You will need an external slave cylinder and clutch release bearing. The later model AX15s will have a lager input shaft tip ( .75" vs. .5"), so you will need to replace the pilot bushing/bearing. To get to this, you will need to remove the clutch. You may want to change that as well, while you are there.
  20. No, the bumper is worthless. Just send it to me. ;)
  21. Man! That's beautiful! I always loved that shade blue. I don't see any rust on it. Has it always been in MN? That's an original bumper, too.
  22. 91 is HO, 90 is Renix. The first year MJ (86) came with either a 2.5L 4 cyl or a 2.8L V6. The 2.8 is not considered a desirable engine. Many 86 owners look to swap to a better engine, either a 3.4 from Chevy or perform a 4.0 swap. Just be aware of the "Red headed step child" of the MJs. For 87 to 89 ½, the 4.0 manuals came from the factory with a BA10/5 5 speed. In 89 ½, Jeep switched to the AX15 for the 4.0. Both the BA and AX were internal slave cylinders. In 94, Jeep changed the AX15 to external slave cylinders. (These came in the XJ and YJ models.) The BA is not considered a desirable trans, especially if you plan on off roading it. If you will just be streeting the MJ, the BA will hold up well. (Just be prepared to change the internal slaves every few years.) Find out from a PO what modification/changes/upgrades were done: lifts, re-gearing axles, etc. There is a wealth of info and knowledge here on ComancheClub. Much of the info is written in numerous thread, especially in the DIY section. Much more of the knowledge is stored in between the ears of many of the members. Use both sources of the knowledge to help you.
  23. First of all, you have a manual transmission. It has a "flywheel." A "flex plate" goes with an auto trans. (Now, off my soap box.) The flywheel needs to match the engine electronics. Since both the 87 and 89 are Renix, either fly wheel will work with a Renix engine. The trans doesn't matter which fly wheel you use. For the clutch, you should match it to the trans. I use Rockauto's web site to research part number changes. For example, i look at the clutch used with an 87 BA10, then look at the clutch for a 90 with an AX15, either an MJ or XJ. The pressure plate and throw out release bearing part #s changed, But the clutch disk and pilot bearing/bushing remain the same.
  24. The 88 electric FSM has the Grn/Wht as the left rear feed. There is no Gry/Wht in the 88 FSM. I have found that the manual and what the actual wires don't always match. (Mine is factory original and has NEVER been hacked. 1 owner - me.)
