9
Everything posted by 87MJTIM
Loud fuel pump, fuel ballast resistor deleted
87MJTIM replied to mark corbitt's topic in MJ Tech: Modification and Repairs
That is Jeep's way of grounding engine compartment components in one location. One of the wires is for the blower fan FROM THE PASSENGER SIDE of the engine compartment. See Cruiser's tips to ground the blower to the passenger side. -
The 87 did not come from the factory with a ballast resistor. However, there was a TSB to add a ballast resistor to address the noisy fuel pump. Your resistor may not have been deleted; your truck may never have had one. I have an 87 XJ that had a ballast resistor added. -
Snow shoveling? May want to consider one of these.. https://www.harborfreight.com/propane-torch-91033.html?cid=paid_google|*PLA+-+Top+SKUs+-+All+(Main)|Shop+Press|91033&utm_source=google&utm_medium=cpc&mkwid=s|pcrid|387366652005|pkw||pmt||pdv|c|slid||product|91033|&pgrid=75957826701&ptaid=aud-466777368694:pla-297244757211&pcid=1398685905&intent=&gclid=Cj0KCQiAz53vBRCpARIsAPPsz8Unf0hquuKvxjGf91XKsFZ9hgHcp88yoNLhEAHsJw3lRUR11DI3Tc0aAgFzEALw_wcB
I don't see OEM on Ebay. Most seem to be C.R.A.P. A parts number search (on Rockauto) seems to have 87-96 matching. Diff part #s for 84-86 and 97+.
My fan blower has been squealing a lot lately. It happens mostly and the loudest on cold days. The fans still moves air and has multiple speeds. I guess it is the bearings going bad. Are new fans still available? Up to which year XJs will fit an 87? I have access to two XJs (87 and 93) to get blowers from, but they're not much younger than the one I have. Can oiling the bearing fix the noise for long-term?
You take care of yourself and follow Dr. instructions.
Maryland: Aspiring to be California - East Maryland: Virginia's best friend (and Delaware)
I cannot speak for all states, but the Peoples' Democratic Republic of Maryland has rules/restrictions on how dark tinting is allowed. Southern states have different rules. Just saying...
Renix/HO mashup questions (fuel pressure)
87MJTIM replied to JeepComanche89's topic in MJ Tech: Modification and Repairs
I am no expert on the 2.5. I believe it has much of the computer electronics of RENIX. -
RENIX was the partnering of Renault and Bendix. In the 80s, AMC was partially owned by Renault. AMC gave the Jeep 4.2/258 engine to Renault to "fix it up" with fuel injection. Thus, the RENIX fuel injection system. Some Jeepers swear by it; others swear at it. I believe yours is a RENIX. -
I just don’t care for him.
After-Market Temp Gauge Causing Misfire?
87MJTIM replied to Boltjd's topic in MJ Tech: Modification and Repairs
You wrote you have an 88 4.0. The factory temp gauge sensor is located at the back of the cylinder head, close to the fire wall. It only controls the dash gauge. The sensor for the computer is on the block, below the manifolds. If your sensor is on the t-stat housing, then a PO changed the housing to a later style. If the PO ran a wire from the original location to the t-stat housing, that does not change the computer functioning (unless a PO did a HO swap). If yours is still RENIX, the temp gauge wiring does not run through the computer. I "should not" effect engine firing. -
I purchase a set as part of the "group buy" several years ago. I am very pleased with them. I have loaded the bed with some camping gear and the bed doesn't even move. The old springs would start to sag with a little bit of weight (one of the leaves was broken). Same as Knucklehead, the back was lifted about 3.5". I put 1.75" pucks up front to even it out, but it still has that "70's hot rod look." The springs have not settled down, yet.
Thomas the Tank Engine! My daughter (and I) loved that show (with Ringo and George Carlin, not Alec Baldwin)
Speaking (or writing) as a CPA with knowledge of taxes, I can say that for some states (MD, for example) charge sales tax on "Shipping and Handling." The reasons for this is beyond the scope of my reply. If the charges are reported separately, i.e. "shipping" and "handling" then only "handling" is subject to sales tax. Different states may/will treat the two services as one or not tax them at all. Because of the recent Supreme Court ruling (Wayfair), most on-line retailers have to charge sales tax on all sales to customer in states that charge sales tax. Given the complexity of sales tax rules (48 states charge sales tax, within states local sales tax rules apply, and different items can be taxed at different rates, etc.), Rockauto may take a simple rule of charging sales tax on all applicable sales and items. Most states will not charge sales tax to a reseller of parts - auto repairs shops and other retailers. I don't know where you live and what the sales tax rules in your state may be. If you believe you are getting charged sales tax incorrectly, do you own research on your state's tax department website. Do your own research, don't just tell RA that they're wrong. Remember, they have high priced lawyers and accountants to help them. If your research proves you are correct, then write (do not email) to RA and present your argument and evidence. If that does not satisfy you, shop somewhere else. Getting a refund? Fat chance.
I got a train set when I was 5 (50 Yrs ago). I played with for years until my mid-teens. I never got rid of them. When I moved into my current house (92), I eventually got it out again. I had not used it much. I eventually "put it away," but have not given up on it. One day I will get it out again (grandchildren, maybe?). (BTW: I still love getting stopped at RR crossing for a train to pass.)
The fill plug is on the passenger's side up high. The drain plug is on the driver's side down low. A wise man once said to loosen the fill plug BEFORE draining in the gear oil. If you drain it first, and cannot remove the fill plug, you're screwed. (Yes, you can fill it from the top shift tower, but that is a lot of work to get to.)
WTF?
Get any/all MJ specific parts: Brake load/height sensing valve Fuel sending unit Interior trim parts (B-pillars, rear cab panels, head liner panel) Bucket/bench brackets B-pillar vent covers Drip rails Passenger side (?) rear wheel flare Rear bumper (?) and end caps Rear cargo bed light (if present) Rear window, if sliding glass, 3 window. Others may add more. If you don't need/want the part, other may want them. You could recover some of you costs.
There was a guy at the York PA Jeep show several years ago with "possibly" one of those. It was a Comanche with an open bed, BUT all the body pieces were one solid unit. The bed was not separate from the cab. I asked the owner if it was a Cherokee that had lots of body work. He insisted it was original. I walked away thinking he was BS'n me. Maybe he was tellin' the truth. I remember it was a dark blue. Anyone else remember this?
The "blue" gauges have the needles that go from 7 O'clock to 5 O'clock; the "Red" gauges go from 9 to 5. My 87 has the Blue. I pulled an 86 full cluster that is also blue. However, I have seen 87 and 88's that had Red clusters - both full and idiot lights. I think the clusters were what ever Jeep had in the parts bin when you MJ/XJ rolled by on the assembly line.
89 4.0 Cam 180 Degrees Off?
87MJTIM replied to big66440's topic in MJ Tech: Modification and Repairs
NO! There is one turn of the CAM for two turns of the crank. -
Do yours have the same transmissions? Stock manual 4.0: 3.07 Stock auto 4.0: 3.55
