fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. fiatslug87
    VIN help!
    Nice, congratulations. It should be '90 not an '89 since the 10th digit is an L, K is '89.
  2. This is the inner shift boot, someone on here said this one fit their MJ. http://www.quadratec.com/products/52106_03.htm
  3. Herculiner itself is Xylene based, the instructions say to thin it with Xylene.
  4. Here's all the info you need from the UC Davis Integrated Pest Management site. http://www.ipm.ucdavis.edu/PMG/PESTNOTES/pn7431.html
  5. PM an address I'll send you a pair.
  6. The trick I used came from a member from this board. Wet toilet paper, place it in the pilot bearing, use a rod and hammer it in, keep adding wet TP and hammering it in. I've done it three times, doesn't seem to do anything at first, but it will press the bearing out. Similar to the wheel bearing grease method but a more stable substrate.
  7. All three of my RENIX MJs have this wire to nowhere. Maybe the '88 electrical manual has some info. http://comancheclub.com/forums/viewtopic.php?f=9&t=12734&hilit=Electrical+manual
  8. None of my MJs had the wiring (88-90), I spliced into the door speaker wiring. The '88 MJ electrical manual does not show any wiring for the knee panel speakers.
  9. fiatslug87
    my MJ ......
    My momma dogface on the bannana patch, I though I had a stroke. Google won't translate Virginian :D
  10. What headliner adhesive have you guys used with good long-term success? I see some by big names like 3M, Loctite and Permatex along with some others. I don't want my headliner sagging in a year.
  11. Thanks MJ, I didn't want to just start prying on them.
  12. Can the vent registers be removed with the dash in place? How?
  13. The clutch is the same but the slave cylinder tubing is bent differently. It will still work but you may have to bend them a little especially if you want the rubber bushing to fit.
  14. http://comancheclub.com/forums/viewtopic.php?f=9&t=12734&hilit=Electrical
  15. Received mine today, THANKS Brett.
  16. Just for reference, the pin is just a flared roll pin and the nut is a star washer type. People have just used a screw in the pin hole at the 7 O'clock position.
  17. Nice :thumbsup: . It looks like Plum Crazy (FC7).
  18. Just got this from Rockauto.com, 5% off and it can be shared. 78308506467740 Enter the code above in the "How did you hear about us" line of the shopping cart. If you are using our traditional HTML catalog, please click the "Apply" button to the right of the field. Your discount will automatically appear, subtracted from your order total. Orders using discount codes must be placed online. Phone orders are not eligible for discounts. This discount code expires on February 19, 2012
  19. Are the unlabeled bottles filled with your homemade spirits?
  20. Team Cherokee sells the whole mount, it's an option. About half way down: http://www.teamcherokee.com/Transmission/index.html
  21. They are transmission specific (e.g. BA10 vs. AX15) not 2x or 4x specific.
  22. Can anyone tell if those are OEM bed rails? I don't think they are but I'm not sure.
  23. Also check the exhaust hanger bushing at the crossmember, mine was in bad shape. http://comancheclub.com/forums/viewtopic.php?f=2&t=33148
  24. That's how my '90 is and I purchased it new.
