RDAN1
    St. Louis MO
Contact Methods
  • Yahoo
    rdan1@yahoo.com
RDAN1's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. I am looking for a complete set of air hoses for an 88 factory 4.0 in any condition to use as patterns to make a new custom set. Anyone have a set on a parting out truck they’re willing to part with? I’d return them also if someone would want them back..Thanks.
  2. I'm trying to replace the headlight switch in my 88 and finally got it removed but in the process broke the plastic cone the switch attaches to in the dash. I believe it can be repaired but it would have to be removed to do it. Has anyone removed this portion of the dash that can advise how to do it? It appears its secured by a couple of rivets below the dash and a couple of screws in the dash. Is that correct? Thanks for the help!
  3. Thanks HOrnbrod !
  4. I need to replace the headlight switch on my 88 and the retainer nut is stripped and I'm going to have to cut it out with my Dremel. Does anyone have a good one they can part with ? The one I have is brass I believe and has been boogered up so there is no way to turn it/unscrew it. All help appreciated. Thanks
  5. I'm using Dot 5 in brakes and clutch. No problems so far after a few months. I bought the wilwood fluid (expensive!) from Jegs as no one around here stocked it that I could find.
  6. Me either..probably wouldn't be pretty............
  7. I didn't. I had to buy a used one from a tranny rebuild shop.
  8. I did this mod and definitely think it's worth it. The bell housing was very hard to find in this area and took me months. I finally spotted an ad for a late model AX15 tranny for sale and called the guy and offered to just buy the bell housing..He thought they were one piece but when he looked at it, he said yes so I got it. And he still was able to sell the tranny to someone else. And when I installed it, I used Dot 5 silicone fluid for it.
  9. Your Opinion and view is welcome but isn't shared evidently by Chrysler/Jeep who now recommend synthetic 10w30 for the ax15 since the gl3 lubes are no longer produced. As I mentioned in my post, there has been lots of discussion about this on other jeep forums and not everyone agrees.
  10. There is a lot of discussion about this in other forums. I decided to go with synthetic 10w30 in mine. All is well and it shifts fine.
  11. The 87-90 parts book shows the part number as 56000636..I'm not sure if its available but there are some used ones on ebay from time to time for about $15.00 +/-. the JY might be a good spot to find one also...???? Edit:..Team Cherokee is selling one for $41.95....part number 56009324 which they say replaced 56000636.
  12. UPDATE: Today I received an FFD Radiator and indeed it has the bung (with the correct Threads!) to install a Fan Temp switch. Pictures below of the Radiator with the bung plug out and another of 2 Fan Temp switches..an OEM One and an aftermarket one (TS258 from Rock Auto.) With this radiator the aftermarket fan switch fits perfectly however the OEM one is too deep and won't snug up tight due to the radiator internals. I'm installing it tomorrow..Thanks Don for the lead on this and the solution to a problem finding a radiator with a bung to accommodate the fan switch and with a fill neck!!!!.
  13. Today I received a response from the guys at FFD. They indicate they haven't changed their radiator design in over 5 years and if purchased since then, it would be like the one in the picture Don posted. They didn't confirm that it had a "bung" ...only that they hadn't changed it....????? Don: How long ago did you purchase yours from FFD?
  14. 88 Pioneer 4.0 4X4 AX15 External Clutch
  15. Just about everything from the doors forward interchanges one way or another all the way up to 2001. Up to 96, most everything interchanges. If you do some searches and some prowling around on the forum you'll find lots of info related to this topic.
