88mjgilley
    Columbus IN
88mjgilley's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. This is the exact issue i had with my Comanche all my cooling system is new also i ended you removing the Ac condenser and i no longer have a single issue keeping it cool
  2. i just did it to my mj the strikers were easy as can be i then wired the doors up by there selves seems how it was pointless to have them both controlled from the drivers side
  3. what other rigs have you had i go to haspin all the time I'm sure if i saw some of them i would know ya and i wish i was 3 miles instead of 60
  4. a 4 gage wire from the battery to the secondary would work fine,and then just ground it as close as you can to the frame. For charging purposes i normally use a snow plow solenoid hooked into the ingintion. So the battery only receives power when the engine is running. I would mount it in a tool box. Your stock alternator should do perfectly fine charging a second one seems how it won't be doing that big of a draw
  5. wow this is one beautiful MJ i wish i had the space and patience to do a build like this
  6. did you accidentally get a locker for the jk and not a xj mj i just installed my spartan last week and everything went perfect
  7. if your going to do the 97 up dash and all find a xj and swap every thing over
  8. Thanks i looked threw there but didn't see it. i swear any time i look for something i can't find it when I'm not looking for it it will poke me in the eye
  9. ok i know there have been posts on the different lengths but for the life of me i haven't been able to find them. I have a Ba10, 231 combo going in this weekend and i need to figure out what length the drive shaft needs to be. 88 4.0 swb 8.25 rear
  10. i had this issue with my 96 but thats to late of a model to matter here and i actually lost power to one of the feed wires on the ignition switch it would run just fine with it turned to start but as soon as i would let off the key every thing would lose power
  11. sounds like the ignition switch went out
  12. Well i finally got the lift installed It has Rough country 4.5 in Coils, Rustys anti wrap spring perches, Rustys shocks , RC lower non aj lower control arms, lockrite locker up front, and a spartan locker in the rear. I swapped in a HP 30 from a 98 xj and also a 29 spline 8.25 in the rear
  13. i ordered mine from randys ring and pinion should be here tomorrow
  14. there good now and yes my dumb a** put the calipers on the reverse side.... all that wasted time and money that could have went to something else on my build :( thats For the help once again guys
  15. no need for sealant on the 1pc rubber oil pan gasket the thermostat and water pump should be fine with the sealant tho
