speeding_infraction
Everything posted by speeding_infraction
LS Drag Comanche!
speeding_infraction replied to krustyballer16's topic in MJ Hardcore Tech: Epic Journeys to Greatness
So what are you doing for suspension? Still solid/beam axles? -
The Comanche has failed me
speeding_infraction replied to hgeranium's topic in MJ Tech: Modification and Repairs
Interesting, mine came out easy. The only issue I had was a welded nut broke off that held the skid plate in. Easy fix. And I zip tied the driveshaft out of the way -
Is your axle centered?
Any chance you just did a valve cover gasket recently? -
Your best bet is eBay with cheap china tires. Looks like you can get mud tires or all terrains for about $400. https://ebay.us/m/UXX7fD https://ebay.us/m/53YVuS But I'm not saying they will be good.
Did you see that in a store? I would love to try that, but I thought they discontinued it.
I'm on the TJ Wrangler forum, they definitely appreciate the comanche. There are a few members on there that own one.
I knew I should've gone!!! Next year🤞
Purist versus Updated
speeding_infraction replied to 1999 MJ's topic in MJ Tech: Modification and Repairs
Build it how you want, when I am looking at vehicles, I tend to focus on price and body condition. Everything else I am comfortable working on. And if I can't afford it then I don't need to worry about it anyways. -
Just saw your build thread over on the Silverado forums, didn't notice it was you till I read "project Jeep Comanche Prerunner" and did a double take. The truck looks great!
Crank won't turn
speeding_infraction replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
https://www.enginelabs.com/engine-tech/engine/explaining-under-and-oversized-engine-bearings-with-king-bearings/ Make sure your bearings are all the right size. -
Help get my truck running.
speeding_infraction replied to camjeep3's topic in MJ Tech: Modification and Repairs
To make completely sure you have adequate fuel pressure, rent a fuel pressure test kit from AutoZone or the like and verify pressure. Read post #5 https://naxja.org/threads/87-renix-4-0l-auto-weak-vs-strong-fuel-pump-sound-when-cranking.1063540/#post-245350096 There may also be a way to test that the PCM is firing the injectors properly. -
Agreed. Dropping the tank on an MJ vs an XJ, I could do 3 Comanches in the time it took me to do one XJ. Can't remember why tho. Mostly the rear axle being in the way, and having to use a pipe to break loose some of the skid plate bolts on my XJ. The breaker bar was bending... I found it made everything easier to either remove the driveshaft or zip tie it off to the side, so it's out of the way.
What thickness steel for plating frames?
speeding_infraction replied to Eagle's topic in MJ Tech: Modification and Repairs
Myself not being a structural engineer of any kind, at least 3/8"(?) of an inch, or the thickness of the original frame, depending how thick it is. Imo, over built is underated -
Repairs/modifications that aren't by the book, but worked anyways
speeding_infraction replied to 89 MJ's topic in The Pub
Project “Tomahawk”
speeding_infraction replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Nice, blue sea is high quality. I work in custom van upfitting, we do a lot of electrical and use them as our vendor. -
I found a caprice ppv 6.0l on the list as well... Immediately started looking up manual transmission swaps🤣
I am definitely keeping an eye out.
