derf
Everything posted by derf
  1. I have been looking into this as well. The biggest thing is getting the extra shift detent for the 4L60. You need PRND321 but the stock column is PRND21 or PRND3L (the 1-2 is L for the AW4). From what I gathered, you can cannibalize another GM column shift and swap over the parts you need. I believe the column from a later 80s Chevy G20 van should work. You do have to take the detent plate off the donor and put it in place of the one in the Jeep column. That should get you all the shift positions. Then from there you can use a Lokar universal shift cable to go from the column to the transmission.
  2. derf
    Gas prices
    Moab was $3.37. Grand Junction was $3.17. I didn't pay attention to what it is when I got home.
  3. The most expensive and frustrating swaps I've done have been trying to make free parts work.
  4. Don't waste your time on a WJ 4.7. It's not a good swap candidate for many reasons. It's too big to fit, it doesn't make much power, and the heads like to drop valve seats. Also, there is zero aftermarket for them. A stroker 6 cylinder will come out to about 4.6/4.7 and give you more power and reliability.
  5. No idea. But since you're modifying, you should get the axle and transfer case installed first. Then measure from the end of the slip yoke on the transfer case to the yoke on the axle. Then you can have it exactly right with no chance of it being too short or too long. A shop can shorten a shaft in about an hour or two and they know how to work with the measurements to make it right. They can also swap in new ujoints quick and easy which is entirely worth it.
  6. Your 2wd rear driveshaft won't even come close to fitting behind a transfer case. And if you don't have a slip yoke eliminator you can't run without a rear shaft. Measuring for the rear shaft modification is a known thing and easy to do. Then take the shaft to the shop in a different vehicle, have them shorten it, take it home, and install it. If you find a 4wd rear shaft from a Comanche with the same bed size, it would probably work. But the 2wd shaft is a hard no.
  7. Adding a transfer case takes a foot or so out of the rear driveshaft. The 8.25 may have a longer pinion than a Dana 35. If you find a stock 4x4 rear driveshaft for your bed length it will probably work. The stock 2wd shaft will be way too long. But getting it shortened is easy and not expensive.
  8. I would love to do a 2.8 Cummins swap. Unfortunately, the emissions laws in CO prevent it. Any swap I can do has to come from a vehicle in the <8600 GVWR weight class from my year or newer (1987) that was certified in the US. Or one with a CARB EO number (like GM E-Rod crate motors). The 2.8 was never released in a US vehicle like that and Cummins didn't do CARB certification. So it's LS from a donor for me.
  9. derf
    Tool Talk
    I ended up getting started with Ryobi batteries so I got their impact gun. It's fine for basic jobs but it doesn't have the oomph to tackle really serious jobs. It's good for 99% of what I do. If something is really stuck I have my oxy-acetylene rig to persuade it.
  10. derf
    XJ vs Trailblazer
    Hit me up next winter. We'll turn you into a snow driving pro in no time.
  11. I can't tell what brand it is but that's a "lunchbox" locker. It's a spring loaded automatic locker. It will clunk as you go around corners. That is normal. Different brands sound different.
  12. Bench seats are more versatile. Comfort varies between people and everyone is different. For me, the MJ will be a dedicated rock crawler. My butt prefers the buckets for long stretches of time. And the harness works better with a bucket seat. So that's the direction I'm going.
  13. For what it's worth, I'm planning a serious rock crawling build with 1 ton axles and 40" tires and I'm going to keep leaf springs out back. Flex is important but you can have too much of a good thing.
  14. Nobody makes any bolt on kits. So you have to custom build your own parts. That involves welding.
  15. This. The closer we get to full vaccination the better. Fewer people getting it means fewer mutations. Not only that, the more herd immunity we have the better for people who can't take the vaccine.
  16. An old high school friend has GBS and got his shots. They just had him in observation to make sure he didn't have a flare up. He didn't so they let him go and he's fine. YMMV
  17. It's that big company that takes a bunch of money and then refuses to pay for damages when you get in an accident after blaming you for it all. Yeah, like I was supposed to know that I was going to land short of the ramp on the other side of the river...
  18. With enough fabrication and money you can do anything. But why downgrade what you already have? If the AW4 is bad, get it rebuilt. That will cost less money, take less time, and be better than the 42re or 42rle.
  19. Yeah, it gets better as you get older. Needles used to bug the hell out of me but not so much anyore. Don't psyche yourself out ahead of time. When you're sitting waiting for the person to inject you, don't watch. Chat about something else and before you know it, you're done.
  20. Get off my lawn ya darn kids!
  21. An AX15 is a better trans than the T5. It's stronger and good for a small block V8. Adapting the transfer case to the trans will take some work if you stay with the T5. An AX15 from a Jeep just needs a bellhousing for the Ford. If you go with a Ford automatic you can get something like an F150 donor and keep the engine/trans/tcase combo.
  22. Should fit fine. It'll require some custom work, like coolant hoses and exhaust. Wiring will take a bit of effort but it isn't rocket surgery. Carb or EFI? What transmission? 2wd or 4wd?
