2
Everything posted by BeaterComanche86
Reproduction Comanche Emblems
BeaterComanche86 replied to carolinajeepman's topic in Vendors- members making products for MJs
Excellent I’ll keep my eye on this thread and will be ordering soon. Thanks for taking the time to repop these, they look great. -
Are the 2.5 emblems coming soon? -
Did you check to see if the headlight switch plug was melted when replacing the switch? Mine was melted slightly and was the source of my gauge light issues. If that’s the issue the plugs are pretty cheap so I’d buy new. Also look into adding a relay harness to the headlights as it will reduce amperage going to your switch and reduce the likelihood of it melting or your truck catching fire.
You could check the ground under the dash, have you went through cruisers tips? http://cruiser54.com/
Those are slick
Sounds like another excuse to have a edm music festival and take some recreational drugs.
86 Beater to Better
BeaterComanche86 replied to BeaterComanche86's topic in Member Projects: Your Comanches
Pulled my front bumper off to paint it and install some Harbor Freight fog lights. Oem switch I used for the lights Also scored some chrome windshield trim that looks pretty sweet. Need to purchase some clips from teamcherokee since quite a few of mine were broken or missing, but there’s enough to hold it on for now. Also got some rugged ridge mats and loose fitting bench seat cover off amazon. It will work till I can get the bench reupholstered. -
86 Beater to Better
Finally got around to putting in my gauge cluster with actual gauges. It doesn’t have the clip for the speedo cable but works just fine. Oil pressure sensor and the temp sensor Oil pressure seems pretty high which doesn’t seem like a bad thing and the temp sensor seems to be very sensitive since I can see when the thermostat opens up via the gauge dropping the temp. -
MJ with 75k miles in WA
BeaterComanche86 replied to rylee144's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Very clean but I’d like to see under that carpet -
@Kalal92 Did some digging and it seems to be called a ventilation valve. Here’s the picture I found.
Here’s the set up on my 86 with 2.5. Front of the valve cover seems to go to the throttle body and the rear to the air box.
Comanche bed lengths and transmissions
BeaterComanche86 replied to Dammerung's topic in MJ Tech: Modification and Repairs
Vote for longbed/5 speed/4wd I use the truck to haul whatever yard debris I have, I like being able to choose my shift points, and it’s snows we’re i live occasionally. -
That thing is awesome
Congrats! I bought my first house last year and it’s been fun. Be ready for some projects that take precedence over your Jeep, I know ive had a few. Nonetheless enjoy the new house and the new pup both will be a great time.
1986 Jeep Comanche X 4cyl 2.5/ Ax-5/ NP 207/ Dana 30/ Dana 35/ LWB Build date: Blank Current Location: Baltimore, MD Status: Sunday driver Notes: Originally Dover Gray exterior with red or maroon interior, vinyl bench seat, floor shift Current owner: Me as of March 2019
MJ Tail Light Replacement
BeaterComanche86 replied to Vakarian's topic in MJ Tech: Modification and Repairs
I second what eaglescout, I would be interested in just the lens if you decide that go that route. -
As a electrician I would defiantly suggest a rewire of your house. Now that your grounds are up to code at the panel running new Romex would be the best way to have piece of mind. And since there’s ghost voltage basically everywhere and your circuit breakers aren’t tripping even though your getting voltage to ground your wiring needs to be updated. This is a huge task but in one of your earlier posts you mentioned you have easy access to all the outlets and switches via the attic and craw space so since you have the ability I would do a rewire a room at a time starting with the kitchen. Then you can run your wire directly to what it needs to feed with no mystery boxes or splices. Do a little over time and then you will know that everything is done correctly.
Glad to hear your swap when smooth. I was able to get the broken fitting sorted out, and I’m picking up the temp sensor today and hopefully swapping it with little issue. Gotta love working on original parts that have been in the same spot for 30 years. I’m gonna start using my torch a bit more on some of these old threads
In your sub panel make sure you unbond the ground and the neutral. In any sub panel they need to be separate if you don’t already know.
I ment that you could do this in your home panel so that your grounds and neutral wouldn’t be connected and there would be no neutral bleed on your ground wire but disregard that as I was wrong about the neutral and ground not being bonded. I apologize, just start opening boxes and find all the neutrals that are spliced to the added ground or any hots that may be attached. Also the first panel pictured your bonding screw is at the bottom (green) so your could try tightening it to make sure the bonds tight
