BeaterComanche86
    2
Everything posted by BeaterComanche86
  1. I messed up big time… So alittle over a year and a half ago after swapping my dummy cluster for a full cluster I was removing the oil pressure sensor and snap, the brass fitting snapped off inside the block. I tried a few different methods to remove it but wasn’t getting anywhere. Bright idea, use a pipe nipple extractor. Well due to my impatience and inexperience the result was the picture above. Cursing myself I still had to come up with a solution, so I relocated the sensor to another spot in the block and tried my best to stop the flow of oil spewing out the block. No amount of JB weld or Marine Tex could keep the oil inside the engine where it belongs, once again probably from impatience leading to poor prep. Regardless I thought that’s not the proper way to fix this so in search of an engine I went. Found a pretty sweet deal for an engine in Virginia, problem was miles and condition were unknown so what other logical choice did I have then to get the engine rebuilt… After killing my confidence breaking off part of my old block there was no way I was gonna attempt this myself… Shiny Fast forward a few months and I now have a freshly rebuilt engine in the truck and am finally able to enjoy driving her around town. I learned a valuable and expensive lesson in patience. This is a 39 year old truck and parts are fragile so take your time(saying this to myself). Anyway I’m just happy to be back.
  2. You may have figured it out already but here’s a page from M.R.277.
  3. @87MJTIM I was just there last Saturday, and it was already picked clean. Got the fender flares though That was the first MJ I’ve seen in any of there yards around Baltimore so I had to check it out, so much rust…
  4. Glad to help This workshop manual has helped me a ton with working on my 86 as well as all the great info here on the forum.
  5. Theres 4 different diagrams; California, Canada, 49 state manual trans, and 49 state automatic trans. Which do you have? I have the diagrams sitting in front of me.
  6. Mine use to have it I need to get one I got lucky and teamcherokee had some “oem” for sale but looks like there out. I’m sure someone in the club has one lying around they’d sell you, or just wait for Jesse to take his off. Also there’s this one on eBay but it’s doesn’t look to be in the best shape. https://www.ebay.com/itm/Jeep-XJ-MJ-Mid-Size-Wagoneer-Cherokee-Comanche-Front-Factory-Skid-plate/224397956207?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D09126fa4583945deb0cbd3ce0fdd2757%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dnone%26sd%3D224397956207%26itm%3D224397956207%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DJeep&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A0315a19a-a110-11eb-8b4e-e2f10fab5435|parentrq%3Aea3d04d11780aaec9f6a8531ffdfe6f0|iid%3A1
  7. Ohhhhh that makes sense, mission accomplished.
  8. Thank you sir but I’m not frontin’ lol
  9. Congratulations man, home ownership can be stressful but very rewarding. Having a peaceful place to unwind and relax after a tough day is worth all the stress and projects you’ll have. Enjoy it
  10. Thank you, as you can see the chairs were pretty rough since they were left outside for about a month before we got them so it was a hell of a transformation.
  11. Picked this table up on marketplace for $50 and got the chairs from a friend for free so me and my fiancé stained and painted them giving them new life. I’m happy with how they turned out and now we have a dining room set Before: After:
  12. That’s cool it’s stayed in MD, I believe it’s been sold or he decided to keep it. It’s not on market place anymore.
  13. That’s wild if that’s true, I don’t know how that would be possible but . And I think I’m gonna stop by there shop tomorrow after work so I’ll see what there price is and go from there. Can’t hurt to ask. Also I’m not pressed to get this done quickly so I’ve got time. I appreciate everyone’s input.
  14. I’ve tried a few times to get ahold of them today with no answer so I may just clean it up myself. I did want them to make me new spacers for the slave where it bolts to the bell housing since who ever repaired it last used 3/8 nuts but I may just figure that out myself as well.
  15. Awesome thank you. Good to know it’s not a big deal. I was a little concerned, I’d like this job to be one and done.
  16. Thanks I’m gonna call the machine shop today and see if they’ll separate them if not I’ll give this a try. Just need to be careful and not get it to hot like you said. Thanks Pete, I appreciate the reassurance
  17. Any tips on separating the two? I haven’t tried yet but also I’ve never done it either.
  18. The wear is on this section of the ring gear, the starter hasn’t been skipping so I think taking a file to them might do the trick. Here’s a zoomed in photo of the teeth in question:
  19. Your the man @eaglescout526 Thank you
  20. Yeah I’m mistaken, I thought that was all one piece or was fused to the flywheel. Anyway I think I’ll just look into replacing the gear ring and getting the actual flywheel resurfaced.
  21. 135k, I was hoping to keep the original but the teeth on just the one side have some signs of wear. Before I pulled everything it shifted fine and didn’t shutter when changing gears so I think I’d be okay putting it back in. It’s just the wear on these few teeth that have my wondering.
