BeaterComanche86
    2
Everything posted by BeaterComanche86
  1. https://poconos.craigslist.org/pts/d/pocono-manor-comanche-tailgates/6986045126.html
  2. My god he doesn’t even know what he has, that MJ’s worth twice what he’s asking for
  3. There something about a wagon that I just really dig
  4. Been working on paint the last weeks with slow progress but I’m about a 1/3 of the way there. Think I’m gonna have to wait for spring to finish up. Also loaded some dirt and whatnot for a dump run this coming weekend, not to much sag.
  5. Not sure if it’s been posted before but here’s the vacuum diagram for 86 TBI 2.5
  6. Wow wasn’t expecting them to go for that much when they started at $72 but I have seen taillights go for $150 each.
  7. Cheap starting bids on some clean tail lights https://m.ebay.com/itm/1986-1992-set-jeep-comanche-tail-lights-/362784114734?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Fcampid%3D5337866144%26customid%3D%26toolid%3D10018%26mpre%3Dhttps%3A%2F%2Fwww.ebay.com%2Fitm%2F1986-1992-set-jeep-comanche-tail-lights-%2F362784114734%26srcrot%3D711-53200-19255-0%26rvr_id%3D2153552236142%26rvr_ts%3Df53f73c416d0a6e46ec66836ffce74d0&_mwBanner=1&_rdt=1&ul_noapp=true
  8. They’re okay for the $10 I spent on them, and there regular incandescent. The light output isn’t super impressive and the included wiring harness uses a pretty small gauge wire but with higher watt bulbs and some larger wire I think they could be improved.
  9. Is it me or did you only post a picture of a “confidential” document?
  10. We are a dying breed for sure
  11. Thanks @eaglescout526, I can take those out of my cart then
  12. Good to know, I’ll be in the lookout at the JY and I’ll be keeping an eye out for that Ford radio as well.
  13. Does this part number work for the 2.5 tbi?
  14. Alright I’ll keep that in mind, maybe if I get enough together we could work out a trade for one of your factory radios with aux or Bluetooth if that an option. Before I didn’t mind my aftermarket radio but after seeing some of these older radios my JVC is looking a bit cheesy and out of place in my MJ. Is there any oem radios your not interested in? Maybe after a certain year
  15. @Minuit Just wondering for my next JY trip are you interested in any Jeep Oem radio? There was a 94 Cherokee with a factory radio and I was gonna pull it but the buttons were a little faded so I wasn’t sure if you’d be interested in it.
  16. Just wanna thank everyone who helped out, turns out it was a tire balance issue all along. Still surprised that them being out of balance would cause such violent vibrations. But thanks again guys, that’s why I came to the experts here at CC
  17. I appreciate all the input and suggestions, I’ll have to call around to find a shop that has the “road-force” balancer and get it taken care of. Seems pretty unanimous it’s a balance issue. Hopefully that will solve my issue, gonna order some leaf bushings while I’m at it
  18. Just tried to give it a wiggle and it’s tight. Had one blow up on a trip back from the beach and that’s when I learned a lesson about proper drive shaft alignment That’s what I thought but after having my tires rebalanced recently the problem still persist.
  19. Thanks @DesertRat1991 I’ll for sure be replacing them. But could this be the cause of my issue? To me it’s odd that it’s only at specific speed.
  20. Leafs aren’t cracked and the bushing are worse than I remembered but i found something that doesn’t look right. Can the sleeve be replaced along with the bushing?
  21. All the bushings are intact but worn. And I would guess that there the original rubber from the factory, it doesn’t look like any have been replaced.
  22. I noticed the vibration before so I threw those parts at it in hopes to fix. But there was no change. Also I’ve had two different sets of wheels and tires (both balenced) and the vibration was the same with both sets.
  23. Wanted to get some ideas on how to track down my vibration issue. So only between 50-65 mph I experience a violent vibration which seems to be right under the seat or back at the rear. Once pass 65 or under 50 it goes away, and there’s hardly any vibration in the steering which makes me think it’s not in the front end or death wobble. I’ve replaced the trans mount and have new ujoints in the rear drive shaft. Any thoughts or opinions would be appreciated.
  24. Here’s one in Baltimore https://baltimore.craigslist.org/cto/d/1986-jeep-comanche/6985156599.html
