4
Everything posted by JMO413
This thing is awesome!
If it's a factory tank there is a bracket in the baffle that the bottom of the sender goes in. I also use Vaseline on the sender seal. It will hold it in place and the lock ring guess on easier.
Rear coil swap/ full Comanche rebuild
JMO413 replied to 1988gecko's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Sounds awesome how about some pictures. -
Welcome to the club! Very nice looking truck you have there. As stated above work through cruisers tips first. This will save you allot of time later. I have found using Google and adding Comanche club to the search works great. ( Jeep Comanche 2wd to 4wd swap Comanche club) this will take you to a few swaps. There's quite a few. I would also add your truck specifications to you signature. It will help with questions. Welcome to the addiction!
Awesome find!
Then I had to fix my front tank strap mount. As you can see it wasn't holding much. Got it all cleaned up and welded a large thick washer to the good metal that was left. It is definitely good to go for a while. While I had the tank it I ran a new brake line to the rear. As you can see when it rusted it the PO just ran it out around the gas tank. All new and shiny, makes the rest of the truck look that much more rusty. For the third time since I've owned it I filled it until the pump stopped. First time was when I drive it home. Second time was the time after that when I realized I had a descent sized fuel leak. This time it is full and all staying in! Should have fixed this along time ago!
I finally collected all the pieces to replace my leaky fuel tank. It would only leak if you filled it over 3/4 tank. The truck had always had a bit of fuel she'll to it. So today the old tank came out. There was a nice little crack that when I pushed on it became a hole. That nice little hole sprayed gas everywhere while I was dropping the tank. Bought a tank from Rock Auto. Liland Global it was cheap $104 to my door. It is a little thin but not bad. It does have the baffle in it. Everything thing else I needed to put it in. The tank came with the lock ring and seal. I had a hard time find a listing for the strap bolts. I found these on Summit and Rock Auto. Goodmark GMK2111749581. They are all but an exact match. Quick couple of coats of paint on the tank straps. I was lucky enough to but a couple sets of them from Rock Auto on wholesale closeout for $4 a set. Painted the fuel neck while I had it out. It's in surprisingly good shape just a little rusty. Nothing a wire wheel and a couple coats of paint couldn't fix. I bought fuel filler hoses for a Cherokee and cut them down. They worked quite well actually.
Looks great! Any ideas how far you lowered it?
Found the one I was thinking of.
Care to elaborate?
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Bookmarked. Thank you.
Just ordered both of them. Thank you.
I like the window sticker idea for sure.
First Comanche (project)
JMO413 replied to SeasToSwamps's topic in MJ Tech: Modification and Repairs
If I remember right that seat looks very S-10 ish also. The seeing column makes since, our trucks do have a very common Saginaw column. I paid $1200 for one with a hole in the frame. To each their own. Seems reasonable to me. -
That is awesome!
I would also add to double check the routing. Make sure there's no sharp bends and that it is secure.
Very sorry to hear this. Hope everything turns out good for you.
You're are right I remember reading someone's build thread that had one. Now if I could just remember who.
I thought it was just an Iowa thing.
Welcome
https://www.amazon.com/dp/B008FGYEJ4/ref=cm_sw_r_apa_i_GfkKEbZWRC85Y Here you go.
Build Date 1/9/89 Body Model JL61 *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 144 Zone 44-Syracuse 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Open BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Perforated Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII
