JMO413
    4
Everything posted by JMO413
  1. I would definitely check the floors. The doors just don't rust through and nothing else? It's worth what your will to pay. To make it back into a DD is going to take some work for sure.
  2. Nice find!
  3. JMO413
    1j7ft36l8ll255211
    Build Date 4/18/90 Body model TL61 *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 4EA Sold Vehicle 4HC Special Scheduling Condition III 5KN Metro Cars of Detroit AHL Heavy Duty Insulation Group ALN Body Color Bumper Group APA Monotone Paint ARL BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning HGD Deluxe Insulation Group JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKE LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PS3 DOVER GRAY MET CC PRI PNT - HS3 QS3 DOVER GRAY MET CC SEC PNT - HS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII
  4. And because I can't leave good enough alone. I figured out Dorman also makes a replacement. It comes with 2 and 1 of them are correct. PN#20741
  5. I had been noticing a coolant smell coming from the truck. It was losing just a small amount over a long time. Half the pressure tank in 3-4 months. The only thing in the cooling system I hadn't replaced was the radiator. After allot of internet research I decided on CSF. Bought it from Rock Auto $211 to my door. All metal construction and 3 row sold me. I haven't had any cooling issues but added cooling and capacity is always a plus. Yes I did stay with a closed cooling system. No need to fix what isn't broke IMHO. Nice and thick at almost 2" The one I took out was a plastic tanked aluminum. In guessing it has already been replaced once. It's was almost 1.3" thick. The upper support came out nicely it was only missing 3 bolts. Gotta love when the PO strikes again. Added a few zip ties to clean up the wiring while the radiator was out. Found my coolant smell and leak. Took out my mint condenser LOL. I've never seen one just falling apart before. Got new lower isolators. Glad I got them the old ones weren't very rubbery anymore. New upper isolators. $8.33 each from Amazon. Everything came out nicely and went back in just as nice. I also replaced all the missing bolts. No more worries about air pockets. Every tech at work had one of these and they swear by them. $82 Amazon. This thing works awesome. Fits in the Renix tank perfectly. It holds vacuum. Upper hose sucked flat. I did overfill it just a bit. Got it down to perfectly on the molded line in the tank. It's about perfectly centered between full and add. Started her up and everything is good to go. Coolant level never moved. I did figure out I drained about 2 gallons of coolant out. It took almost 3 gallons to fill it with the new radiator. I am overall very impressed with the CSF radiator. The one problem I did run into was the fan shroud didn't want to fit between the fan clutch and the new radiator. I forgot to take a picture of the trimming I had to do before I installed it. This picture sucks but you can see the part I trimmed. No more coolant smell!!
  6. JMO413
    New guy
    The sooner the better. Welcome to the club and the addiction!!
  7. I don't want to even think about it. I don't want to think about what I have paid for parts. But the hunt is always fun.
  8. That's $300 more than I paid for my truck.
  9. That is an AMC part number.
  10. It looks like you have a Cherokee washer tank there. One pump does the front the other is for the rear on a Cherokee. Comanche should only have a single pump. It should be the one with the metal bracket. This is what mine looks like. Sorry I couldn't get a better picture.
  11. This is cool!!
  12. This truly is an amazing place. Great people and Jeep's what more could you ask for?
  13. Mine was doing the same thing. I replaced it with a truck pump for $6 from Rock Auto and all is better now.
  14. I would like two for Christmas please.
  15. You should definitely do it. When are you ever going to find another 1965 Gladiator?
  16. J truck for sure. I had 4 or 5 Rangers that I never fell in love with. Had a buddy that had a J-10 and I loved that truck.
  17. I drive at WOT regularly I would say. My drive to and from work is a whole 2.4 miles. I drive 1.3 miles to the highway on ramp get up to speed just to stop at the stoplight. Then down the highway for a mile and another stoplight. Left into work from the stoplight. So in no way is this good on gas.
  18. 88 with 4.0 Ba10/5 4.10 gears 31s I've only ever figured it combined and I end up at 14 ish MPG.
  19. DD, truck, toy, and reason to buy more parts.
  20. JMO413
    Halloween
    I love that commercial!
  21. Looks good! There should have been a version of that rather than the mini console.
  22. I like it!
  23. I have 2 XJ consoles and the original MJ console in my truck. I will compare them and see what all is different. I just know my XJ had the vent and my MJ did not. I also seem to remember the MJ console didn't have the ashtray in the back.
  24. The MJ console doesn't have the vent.
