4
Everything posted by JMO413
Sorry I definitely dropped a little.
This is without cruise. I wish I had lubed it before I installed it now my speedometer is super jumpy.
Well I knew better shortly after I got it all back together I smelled burning plastic. The good part is that it was only the speedometer cable on the exhaust. Had a little time today so I installed a new one. Hopefully everything will work for a while! Didn't take long to melt this fine unit. It balled the t case end pretty well.
I'm getting a WK2 soon. Any good forums out there???
JMO413 replied to dasbulliwagen's topic in The Pub
I haven't seen or found one that's worth looking at. Good luck. -
89 MJ with 98 donor Cherokee 4x4 project
JMO413 replied to Herc1999's topic in Member Projects: Your Comanches
Looks like a good starting point. -
That S-10 bumper looks good on there. It looks like it fits pretty good. Parts should be readily available to service that set up also.
87 AMC Comanche Manuals
JMO413 replied to Comanchejeepgal's topic in MJ Tech: Modification and Repairs
I finally got this to go. I don't know where I found it but had been opened to many times to count on my phone. The xjjeep site is awesome! -
mj1988electricalmanual -
That is awesome. Perfect place to add about anything. Any idea what they would cost? I could see a definite use for this. I would believe you could sell quite a few considering it works also for the XJ platform. We all know there's a ton of those out there!
88 4X4 Longbed Pioneer - 4.0 5 spd
JMO413 replied to 88towmanche's topic in Member Projects: Your Comanches
Welcome to the addiction for sure! That is a good looking survivor for sure. I will say 4.5" lift fits 31's nicely and makes for a good DD. -
1991 Eliminator ROW Rig
JMO413 replied to TexanEliminator's topic in Member Projects: Your Comanches
That is one pretty truck you've got there. I feel you in the black vehicle. It seems red was the color for MJ's for some reason. I really like the gray Eliminator decals on the black truck. -
It looks like the clutch master cylinder has been leaking for a long while. I'm guessing your right on that being the electrical problems source. Good looking truck you've got there! What's the plan with it?
Pm sent
I not usually into two tone but those are some nice trucks!
Block heater might help if it starts of warm it might get warmer? https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.ebay.com/itm/Fia-WF927-6-Custom-Fit-Winter-Front-And-Bug-Screen-05-07-LIBERTY-KJ-/302906271972&ved=2ahUKEwj25qfB6ebgAhVn4IMKHYJLCqoQjjgwC3oECAMQAQ&usg=AOvVaw1NXaRKc5Y-TpScqarZJJY2 Maybe a cold front.
Unknown electrical components
JMO413 replied to Amccutc21's topic in MJ Tech: Modification and Repairs
ECM Cruise control module Maintenance timer module. From what I have read this just turns the light on so you know when to change the O2 sensor. -
Headlights not working solution
JMO413 replied to moparbrown's topic in MJ Tech: DIY Projects and Write-Ups
I would definitely replace the connector also and do the relay upgrade. You can buy a connector for a later Cherokee. I ordered one for a 96. You do have to cut a chunk of for it to work. They agreed more wires. It's very easy to do. The headlight relays are a must! And also easy to do. -
That is one pretty truck. I love the grill being upside down. I always notice that after mine was pointed out to me. It's just too easy to do if you don't pay attention.
Anybody running 12 hole injectors?
JMO413 replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
Just shooting for a reliable fun to drive truck that everyone stares at. So far I have achieved the goal! There aren't many Comanches in southeast Iowa. -
How else do you get rid of money?
I love the Sasquatch switch. Did it fit perfect in the dash panel hole?
I did the O2 sensor first. Mine was game over, it didn't ever go to closed loop. Drove like a 30 year old truck after that. Then I did the 746 injectors or the PCM next not sure. The PCM seemed to help the idle, it seemed smoother. The injectors make a very noticeable difference. They are awesome! Drove better than ever. Then I did the bored throttle body from Meanlemons. That is a game changer IMHO. Truck runs like a scalded dog. Now to see what indexing the distributor and new wires will do. -
Love the blue and gray interior! What color is the exterior going to be?
