rideordie
rideordie's Achievements
Comanche Fan (3/11)
Okay, so if I'm understanding correctly I pretty much can't get a column shift and it will have floor mounted? And as it is right now, I have a separate key for my door locks and a different one for my ignition so that really isnt too much of an issue. Is there an aftermarket one that would have a column shift? I don't mind the 4wd being on the floor but would be nice to have the column shift for my build.
Hey guys, I need to swap out my steering column since mine is pretty badly beat up. I have a 1990 MJ 2wd auto, which I am in the process of converting to 4wd auto. I would like the shifter to be on the column as well if possible with tilt. What year XJ's will swap in and is there any good aftermarket options? Thanks in advance :)
Hey guys, Been quiet lately due to the virus and a lot of my money for this project went towards a house I was flipping so I've been on 'pause' for a bit with it. The project took a change of course slightly. I was having a lot of difficulty trying to figure out how to mount the Sunrader shell up, prepping it for the subfloor, moving it around, working on it in my suburban neighborhood and all that. It was just too big and cumbersome unfortunately. Not to mention how top heavy it would be once mounted up. So I decided to go with a more lightweight, and nimble Chinook! Being able to fit it in my garage is a total game changer. Gonna pull the shell and mount it on my Comanche. Here she is, project will be moving forward with a more appropriate vision.
Super nice one! The factory 4x4's are extremely rare and that one is an excellent, updated example. With the rear axle issue fixed too. I'm (somewhat) in the process of putting a sunrader shell on a comanche but money has been tight with current situaitons :/ here's the build thread for anybody interested:
Me too man, haha Yeah, Want to start making a bit more progress first but I'm almost there. Axle swap should be underway this week. Dana 44 Hp Front / Dana 60 Rear 4:10 gears With that said, I'm looking into suspension options and wanted to get some opinions. Don't want to lift it too much since I want to keep the center of gravity at a reasonable height, but some 31's would be nice 33's at the most. So I'm considering a 3" lift at the front and a 4" lift in the rear so that once the camper is on it will hopefully level itself out nicely. Thoughts?
Hey man! Sorry for the late response, as far as the project goes I'm waiting on my buddy who has a shop who will be doing the axle swap for me since he's basically an expert at it. I have all the pieces to put the puzzle together basically just waiting on him atm. Thats rad you have a sunrader too! I'm assuming its a 2wd? What size is it? Yeah I'm pretty fortunate to have found the shortest version with the door on the rear. Those are very rare, I think they only made them for one year? can't hardly find any info on them. But yeah, I'm going to have to do a full subfloor rebuild and lots of fiberglassing so I definitely have my work cut out for me, but I'm hoping to get her going within the month.
In the process of sourcing parts :) I have a AW4 with 70k miles, the drive shafts and Transfer case lined up and will be picking up tomorrow. Now I need some axle suggestions... I was told that a Dana 44 up from and a 9" Rear would be a great set up. I've found quite a bit of both but any recommendations of years I should look for or other rear axles for that matter? the original dually rear on the toyota the camper came off of measured about 66" wide so I'd like to keep a wider stance in the rear for stability but would prefer a non-dually rear. Any and all recommendations welcomed :)
The original toyota had a stock front axle, don't recall which it was, and the rear had a Dually Rear end, or "Foolie" as it was referred to since there was a major recall on them. Whatever option I decide to go with will be a major upgrade from the original for sure haha. Also need to widen the stance a bit so since I have to swap the front axle anyways, may as well beef it up some
Yeah in the process of doing the axle swap to be able to support the camper shell, I'll be re-gearing as well. For the transmission, I need to be looking for an AX-15 correct? Assuming the Cherokee I'm looking at has that Trans, everything else should just swap over accordingly? Anything I should consider upgrading during the swap process?
