89 MJ
    8
Everything posted by 89 MJ
  1. Sounds like you need to get out and use it more. Then you’ll find more to do I’m sure.
  2. This is from the AMC Eagles Den and I figured it might be entertaining here too. Anyone have any tools to add to it? DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand, or other nearby body parts. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable or valuable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle. TWEEZERS: A tool for removing wood splinters. PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack. Secondary usage: used to call 911 when car has fallen on you. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog **** off your boot. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway. TAP: See Bolt Extractor above. TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry-bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light. It is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to cut hoses too short. HAMMER: Multipurpose, if the smaller one does not work, use larger model. Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. PIPE AND/OR CHEATER BAR: Used to provide leverage on stuck or stubborn parts, since you should have had the strength to do it but recently have only been doing 12 oz curls. WATER PUMP PLIERS: Larger, with more adjustment points than ordinary pliers, it is used to round off bolt heads too large for ordinary pliers. Also doubles as a device to check one's palm pain tolerance when the jaws slip off the rounded off bolt head causing the handles to pinch the fleshy part of your palm below the first finger. ANGLE GRINDER: Used for grinding off flesh of knuckles and finger tips. ADJUSTABLE WRENCH: Commonly used to round off bolt/nut heads and slam your fingers into the sharpest nearby object. SNAP RING PLIERS: Used to expand and then shoot your only and very necessary snap ring into another dimension (distant relative to wire wheel.) Oxy-Acetylene Torch: Also known as the Acetylene Wrench....When the progression of hammers fails once you get to the "Thor", try the acetylene wrench also known as "Metric". SAFETY GLASSES: Meant to protect your eyes, but only serve to become fogged-up and distort any amount of vision provided by the aforementioned trouble-light. 4 - 6' STEEL PIPE: Used to snap breaker bars in half to reduce their length. Also good for breaking sockets and rounding off nuts and bolt heads. TOOL BOX: Place where the tools you do not need are stored. KITCHEN DRAWER/WIFE'S PURSE/KID'S BEDROOMS: Places where the tools you need are stored. GASKET ADHESIVE: Substance guaranteed to stick to everything but the parts you are trying to get it to stick to. Works best to seal the tube it comes in after one use. WORK BENCH: A portal to an alternate universe. Parts placed there will be transported to this universe and only be returned after you return from the parts store with the new replacement part. UNDENIABLE TRUTHS: No matter which fastener you leave until last -- it will be the hardest one to remove. You will have one left over fastener. TOOL AISLE: Tool used by merchants to assist you in buying tools you might need someday. PEN: Used to sign checks and credit card slips at the parts store. ELECTRICAL TAPE: Used in conjunction with fast food napkin to bandage wounds incurred using above mentioned tools. FULLY EQUIPPED MECHANIC'S WORKSHOP: Something you don't have, and will be required to visit with projects you can't complete. LAWN MOWER/SNOW BLOWER: Used to find tools and parts. STANDARD TOOL SET: One flat head screw driver. One claw hammer. One rusty pliers. One half a saw blade. PROFESSIONAL TOOL SET: One Vise Grip pliers One nail One Phillips screwdriver One old roll of duct tape and a roll of (rusty) tie wire, aka balin' war LOCKING PLIERS (COMMONLY CALLED "VISE GRIPS"): Originally designed to operate Hood Release Cables on Eagles, they have been adapted to a wide variety of uses.
  3. If you're trying to do it yourself, your local classifieds and junkyards will be the way to go. My truck has had a 3" lift for 5 years I think and it is all used parts and a bastard pack in the rear. Here's a thread of junkyard parts you could use to make your lift:
  4. My 89 was built in January of 89 and there is no duct tape on the wiring.
  5. I second Firestone Destination AT tires. I've run them in snow, rain, sand, mud/dirt, and a little bit of rocks between my Comanche and my Eagle. I thought they did very well in all situations. Even in the snow and rain, I never feel like I need four wheel drive. I have the original Destination ATs, but I will consider the AT2s for my next sets on each rig.
  6. It would be plenty reliable, in my opinion. Just make sure you go through Cruiser’s tips. My MJ was my first vehicle and when I’m home, it shares daily duties with my AMC Eagle. My truck was a complete restoration too. You should be able to find a truck in your budget. If I were you, I’d try to buy the nicest truck you can afford. Instead of buying a $3,000 truck that needs rust repair and paint, you may want to consider buying an $8,000-$10,000 truck from down south or out west that needs less work. I also think that the 2.5L is just as good of an engine as the 4.0 and there’s no reason to steer clear of one of those. You may want to check this thread out:
  7. A little roller 302 with a stick would be a fun little rig.
  8. Very good. It was an emotional roller coaster, I’m sure.
  9. This is going to look so good when it’s done. I’m excited.
  10. 89 MJ
    Comanche trim
    The Eliminators would have come with 10 hole wheels. There is no exact number of hunter green 92 Eliminators, but I would guess it has to be less than 100. 92s are rare, HO Eliminators are rare, and hunter green is rare. Its not necessarily worth any more than any other color Eliminator, and I wouldn't say a 92 is more valuable than a 91, but it is a very rare truck.
  11. 89 MJ
    Comanche trim
    I suppose that would most likely be the 10 hole wheels like these: But maybe it could also be the 5 spoke ones like these:
  12. I’m curious as to what your thoughts are going to be with the BFGs compared to the Milestars.
  13. I'm sure most of us at some point have done something that isn't quite the right way to do something, but it worked anyways. Let's hear some of those stories. Not so we can try them, but more for an entertainment factor. I have a few from the engine and transfer case swap in the Eagle. First, when we disassembled the engine, the valves looked like the surface of the moon with pitting and carbon. The picture shows how we cleaned the carbon off. To get the mating surface of the valves smooth, we pinched a piece of sandpaper (first 180, then 320) between the seat and the valve and held it still, then turned the valve with a drill. For the seats, we stuck a piece of sandpaper (180, then 320 again) to the valve, then spun it in the seats. Valve lapping compound was used to finish it up. Filling the combustion chamber with water, then using compressed air in the intake/exhaust ports looked like a jacuzzi before this highly scientific valve job. Afterwards it was sealed almost perfectly. Next up was the transfer case swap. I needed a longer driveshaft and was supposed to go wheeling in a couple of days. We ended up cutting an original Eagle driveshaft for the compressing part and welding it to another unknown driveshaft that we had. We did do it correctly by making sure the lines were absolutely straight and used the complete end of the Eagle shaft with the sliding part and used a dial indicator to get it straighter than AMC did from the factory. We even reused whatever u joints were in the driveshafts. Somehow it has been working perfectly for a couple thousand miles. I guess sometimes its better to be lucky than it is to be good.
  14. This sounds a lot like my issue. The temp stays fine until it’s not suddenly. What gearing do you have? I suspect my issue is that with lower gears and highway speeds the water pump starts cavitating. I think I'm going to try a flowcooler water pump and a high flow thermostat.
  15. I figured you might be entertained by it. I can’t think of anywhere else most of these pictures could be found.
  16. The hood on a 64 Chevelle is fairly plain looking. My dad wanted to do something about this and ended up finding a damaged 68 Chevelle hood that the scoops will be used out of. We cut the center out of the 68 hood. Here it is lined up in front of the 64 hood.
  17. Photos of several of the 84-86 oddities: 1. A pillar (no screw covers) 2. 86 Air cleaner lid NP229 Transfer case shifter (note the 3 positions for the transfer case shifter: High range, neutral, low range. The 4wd selector is to the right of that, behind the trans shifter) 3. External slave clutch 4. Diesel warning indicators (the gauge clusters also had a boost gauge) 5. The speedometer was different where the cable attaches. The face of the cluster is different as well, but this style was used up until 87, I believe. 6. System Sentry 7. Visor clips 8. Wagoneer tail lights and Jeep emblem location 9. Relay center
  18. You might enjoy this thread: Ok, I'm done being off topic now
  19. It is just crazy. It is cool to hear the number of people that have stepped up to help though.
  20. You'll fit in well here. There's quite a few Eagle Scouts on the forum.
  21. Here’s Cruiser’s thread on adjusting the tps: And you might as well give the throttle body a good cleaning too:
  22. I like that theory a lot. Makes a lot of sense. I agree that the brochure is 84-85.
  23. The 2.5L doctor beat me here I see. I was just going to say that this site can host photos too, so there's no need to use imgur unless you prefer to.
  24. Also available on AMC Eagles. Here is a couple more photos of those wheels: The second photo also shows the 84-85 Wagoneer 21 slot grille and the offset Jeep lettering.
  25. Any parts store should be able to make you some. That said, I’d go with what limey said and upgrade.
