89 MJ
    8
Everything posted by 89 MJ
  1. That is for sure. I think I would need to live in them if I had as many as I wanted though.
  2. Ohhh, green! I love green. You and your Little Red makes we want to build an MJ with a bunch of factory accessories. Fair enough. But you kept reminding me!
  3. Solid or slider?
  4. Cherokee will bolt in as long as yup use the Comanche brackets. @krustyballer16 Makes new brackets.
  5. I want to start by blaming Pete, Red Mistress, and eagslescout526 for making me realize I want to do this. I am casually looking to buy a mostly stock LWB Metric Ton Comanche. Minimal rust would be great and I’m not afraid to travel for one. Paint condition doesn’t matter either, so long as it is straight (I have a passenger door and fender to put on if those are damaged) Transmission doesn’t matter much to me. I prefer an 91-92 but would be okay with any year, so long as it is a Metric Ton. My plans with this truck are to get to get a bunch of factory accessories to put on it. I do do have a restored (my dad restored cars for a living, so this was a professional job) SWB 89 4x4 with a 4.0 and a 5 speed and a 3 inch lift (pictured below) I’d trade for one with cash on your end, otherwise I will be listing it for $12,000 once I 96 swap it. Note, I’m not looking for a perfect truck, but I don’t want some cheap repaint or trail rig. I just want a Metric Ton LWB because a little more bed space would be nice, and the higher towing capacity too. I want a black XJ to make a Goonies replica.
  6. I’m not saying my generation is better (I ho early think it’s worse)
  7. Clearly none of those hipster morons have ever experienced a Jeep. I guarantee you the author is a millennial snowflake that just whines about everything. Some kids should have been spanked...
  8. Nooo! That makes it impossible to make it have nice paint in the future.
  9. 89 MJ
    Home Security
    I like Glock security systems and Remington’s 870 style security system.
  10. Dang, I was hoping it was going to be on my side of the state, I would have bought it in a heartbeat.
  11. Seems cheap enough even just as a bed.
  12. You most likely have 4.10 gears. Those will be fine.
  13. Also, for you bed, maybe look into taking two beds and cutting one right behind the wheel opening and the other in front of the wheel opening. Then you won’t need to worry about making sure the wheel opening lines up. That is unless you just stretch the stock one in the middle. Here is a a pic of what I’m thinking the best way to do your door would be. Not an MJ, but still relevant. Check out the rear door, except you would section the front of the XJ window opening in the front of the MJ door.
  14. I’m going to make a few suggestions if you don’t mind, use the front of the XJ rear door to give the rear door (door from the factory MJ) a square window. I say to do that because if you use the XJ door, it will look weird with the B-pillar vent because the CJ rear door is more vertical.
  15. I saw an XJ with 3.73s, but like everyone else, not an MJ. I also saw this FB know it all trying to tell Pete he was wrong. Pete, I don’t think you were wrong.
  16. That would look really cool on the roof of your Liberty. Just sayin
  17. 89 MJ
    People on Facebook
    Cool! A local guy that I know builds 35-40 frames from scratch.
  18. I like this idea.
  19. What are you plans with it? Be sure to check under the carpet for rust.
  20. Most important upgrade though. Not even debateable.
  21. 89 MJ
    People on Facebook
    That is the plan, I’ve just been commenting on FB in case someone liked it then the motor work would get moved up in the timeframe.
