13
*X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 5AL Low Series Tracking ADL Skid Plate Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAF High Altitude Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PA2 STERLING SILVER M CC PRIMARY PAINT - HA2 QA2 STERLING SILVER MC SECONDARY PAINT - HA2 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze XPF Protective Coating and Remover YAA Build To U.S. Mkt. Specifications YGA Without Billable Fuel YGB 1 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z77 Right Front Spring Group VII Now you are correct about the build sheets being inaccurate. I made this disclaimer before. But its due to Chrysler reusing codes and such. Prior to 1989 like yours is a hit or miss on data. 1988 and down when AMC was still around weren't filed away properly so some data is still lost. Build date: 10/16/88 Body code JL62
Yes, that is for the High altitude CPS. Let me pull up starparts and compare if you don't mind?
Whoa. How did you get your build sheet?
Door handle gaskets
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
That’s a good idea. I’ll try it when I get my passenger door handle off. -
Maybe I should of...
eaglescout526 replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
If it doesn't have a T-stat being from Nevada, there could be more to your hidden cooling issues. -
November 2019-Pirate_Staz's 86
eaglescout526 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Interesting fact about his truck. It has a 94 drive train but no apparent modification to the firewall. Almost like the PO knew exactly what to do. But failed to add a fuel filter. It is a clean install by 86 swap standards. (Pete there’s a hidden one here. Don’t know how to undo that.) -
Holy cannoli! Congrats! -
Before I take off my door handles for a refresh on color, has anyone found a source for the gaskets or do you have to hope they won’t crumble in your hands?
Low mileage 86 in Ohio
eaglescout526 replied to Vineyard86manch's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
They generally were a special order unless the factory had some made. It’s weird we don’t see many auto XJs from 84-86. Probably because it was a three speed Chrysler. But probably not a lot were made. Just like the AW4 2.5L combo. -
The only redeemable feature to the modernization of War of the Worlds
Fantastic. Lots of interest. I will do my best with my busy time to contact the local company here to reproduce them for us.
OM616 Swap
eaglescout526 replied to dzlmnche's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I don't know how or why but the garnet interior with the black bezel and black face on the cluster looks really damn good. Just some maroon or black carpet and it will look better. -
What I’m curious about is why did yours come in a 90’s MoPar box and mine are in performance boxes? Anyways I will do some digging in my spare time to reproduce these. I wouldn’t expect to see reproductions for a while. Big plan with Little Red to happen.
If I could I’d have that interior. But red on red is a little too much commie for my liking. -
Thinking of rear axle options
eaglescout526 replied to coolwind57's topic in MJ Tech: Modification and Repairs
Neat. -
Well Pete is right. The AMC 20 only came with 4.10. So the owner probably can’t count or it isn’t an MJ AMC 20. Little known fact except to probably the older guys. Before AMC sold their axle tooling to Dana the D35 was once the AMC 35 -
No problem. Happy to provide with your trucks info.
*E1 Cloth Bench Seat -SA Charcoal 124 Zone 24-Canada-Prairie 1AB Canada Dealer Retail 3N8 Drive Away Program Tracking 4CP Federal A/C Excise Tax 4EA Sold Vehicle ACC Southwest Edition APA Monotone Paint ARL 300 Premium Group BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JDB 180 KPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKE LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps LMK Daytime Running Headlamps, High Beam MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHK Engine Block Heater PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAC Build To Canada Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 1/17/90 Body code TL61
If it has an AMC 20, probably
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGF H D A904 AUTO TRANS DMN 4.78 Axle Ratio EFB ENGINE - 2.8L GM 6CYL HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING Build date: 11/5/85 Body code:JL62
apparently I already owned some this whole time...
eaglescout526 replied to Pete M's topic in The Pub
Lol. Perfect opportunity to repaint them and throw them on your all stock MJ -
No problem. Starter should last you a life time.
