eaglescout526
Administrators
    13
  1. Try sourcing parts for a 4.2L for the V-belt stuff if you need such. I noticed that some stuff are shared between the two engines in the parts catalogue. Just trying to help ya save some pennies. Going serp is an option.
  2. Should be just a direct swap. Course the present issues you have are also easy fixes without swapping a whole engine and you can add AC to your current engine as well.
  3. I think the carpet is dirty and the lower dash is bad pic
  4. Everything but the steering wheel and the center console is blue.
  5. Build Date:12/16/87 Body Code:TM61 *X1 -YY 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL 2.5L Renix stuff is worth snagging too.
  6. Back glass and rear flares are worth saving. And that hitch looks factory. Wonder what is going on with that bench seat and the three headrests. Also the last digit is a two. I was able to make it out and the current VIN posted comes up as and XJ
  7. Nah.You don't want them. Theres 9 at vintage and a few a dealers for a grand total of..... $700
  8. List is $710. Guess it boils down to how badly you need the manifold. There are HO available as well
  9. Price. Not everyone needed 4wd. Most used them as city cruisers(XJ) or duty trucks(MJ). Granted I kinda wish I had 4wd but having 2wd is unique and with the 2.5L I can still go places just not as many as a 4wd can go.
  10. There are 17 Renix manifolds still left. There’s also some HO ones too.
  11. Is this what everyone is asking about and looking for? If so there are 17 Renix manifolds left in the U.S.
  12. Ouch. Wonder how bad that damage is.
  13. You can put in any speaker. Now you may have to modify the harness as factory ones are not made anymore. Should be a 5x5 round speaker. And said speaker fits in all MJ XJ doors
  14. I had defrost for a long while until I discovered a broken vac line going to the reservoir in the bumper. Have you checked that line? Usually that is a culprit to having defrost only.
  15. Y’all think those trucks are bad? Get a load of this: I don’t remember where I first saw this but seeing that six door ford made me remember this abomination.
  16. Check to see if your pump is pumping fuel. Since she fires and runs then you know your CPS is good and so is your spark. Check the fuel pump relay and the pump itself. Then go from there.
  17. I must be the only one who has a blue 2.5L block then. Make it whatever color. Doesn’t have to be those two.
  18. Paint it Chrysler or GM blue and it won’t look so odd
  19. So bizarre you have a 4.0 T-stat housing. Hey it works.
  20. Same as fiat and does not work on edge. Bizarre.
  21. You will need to adjust the tach to read the 2.5L properly. As for the other gauges you will need to keep at it and see why their readings are off.
  22. I believe the head restraints is seat belts
  23. Oh dammit. I was looking at a 4.0 set up after I looked up a VIN last night. 33002508 or 32002708 will work. My bad for the confusion.
