eaglescout526
Administrators
    13
  1. Damn. For $60 id take the bench and bumper.
  2. *X1 -Y1 3LR APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXB Jet Black QXB Jet Black TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build Date:6/16/87 Body Code:TL61 Wow. A late 87
  3. The cruise control box will be right under the steering column. It’s a small yellow box. If you lay on your back and look up under the dash you would see it. As for that RPM thing, I have no idea. Looks foreign to me.
  4. Don’t get rid of it if it is factory. The yellow box will say AMC on it
  5. Few things. Post your VIN in the registry and I will decode it for you. Second. The speedo cable plug is what you need to worry about for the different year clusters. It’s not hard to look up from under the dash and see clip or plug type cable Three if you have cruise there should be a yellow box under the dash. That control looks like a YJ style or another GM style stalk. And your speedo cable will have a rev counter or speed controller in between the two cables to split it.
  6. Depends on the year. All 84-90 are plug and play. But the speedo plugs are different for 84-early 87 model years and 87 late-90.
  7. If you do delete the EGR and tube hang on to them. Someone might want them as Renix 2.5L stuff is getting harder to find amongst the 4.0’s.
  8. Renix has no check engine lights. So you can do that if you want. Take a look at the Differentials pumpkin and look at the part number tag that is bolted to it. It should have the ratio. Or jack it up and count how many times the drive shaft spins to complete one full rotation of the tires. Chances are it could be 4.10 gear. Or 4.56 but that was on autos.
  9. Ah yes a fine selection. Sponsored by four wheeling with a trailer with a Yamaha in Moab.
  10. It was neat except the sun and heat here dried it up into a nasty pile of trash and leather. So I don’t feel that bad.
  11. Oh my god did I throw away an accessory?! I had something like that and tossed it shortly after I got my truck. Nice truck though! Welcome to the addiction.
  12. I got you. No problem.
  13. Any chance the bumper can be saved?
  14. Alright. I’m curious. Is that a vent relocation and well, I can’t tell. It’s an AC control deck but i don't know where from. Looks GM. Care to tell?
  15. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA Charcoal 155 Zone 55-Milwaukee 1AA U.S. Dealer Retail 25C Customer Preferred Package 25C 2TC Customer Preferred Package 2TC 3VN Customer Preferred Discount ALA SE Decor Group APA Monotone Paint BAP 75 Amp Alternator BCC Dual 730 Amp Maint Free Batteries BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KER KWR STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build Date:9/10/91 Body Code:JL62
  16. Those vents on the side where the covers used to be are worth snagging.
  17. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DCK 4SPD MANUAL TRANS - AISIN SEIKI EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY Build Date:9/4/85 Body Code:JL62
  18. Theres plenty of parts there that need to be saved. Like the front grill pieces and that license plate bracket.
  19. That’s awesome. This kit is missing it’s air lines but I’m sure those are just any off the shelf air line for air bags and such.
  20. Chrysler still has a lot of the front end pieces still around if you want quality.
  21. Honestly. I don't know how these would compare to the JK shocks I have. Definitely a neat kit.
  22. Depends on what you need. I recently listed some NOS MoPar front suspension parts that are available still.
  23. Ok so that thermistor won’t work for you. You can splice it in. Course do you currently have an empty plug on the harness?
