13
4.0 alternator on 2.5L
eaglescout526 replied to Myles Cyncora's topic in MJ Tech: Modification and Repairs
This has been a problem before as I fought with this before adding AC. Renix 2.5L's without AC have a special pulley they need to be in line with the others. The bracket is fine, its the part stores that don't know the difference between the ACless models and AC equipped. Pulley looks like this: His probably looks like this: And this should be the bracket: -
Carpet/Vinyl interior from "factory interiors"
eaglescout526 replied to Deleted's topic in MJ Tech: Modification and Repairs
Bake until golden brown. -
Do you have AC or no AC? Doesn’t matter too much if it’s 4.0L or 2.5L. But the no AC systems require a specific pulley. I got mine from Napa a few years back with the no AC specific pulley. -
Shame. I'm sure the plastics can be salvaged.
Rear bumper doesn't look terrible.
JP5A or JP5B diesel gas tank
eaglescout526 replied to Geek's topic in MJ Tech: Modification and Repairs
Diesels got the full 23.5 gallons instead of the 16. -
Could always turn em around
It has OEM bed rails. Too bad its not a long bed.
*X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 166 Zone 66-Orlando 1AA U.S. Dealer Retail ALA SE Decor Group APA Monotone Paint BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 10/5/89 Body code JL61
*X1 -H9 3LY AGJ Driver Assistance Group APB TWO TONE PAINT PACKAGE - I APC TWO TONE PAINT PACKAGE - II CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYC Amped QA2 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 10/11/87 Body code TM61
I will get an accurate build sheet in a second. Jdog get the front bug shield and grill pieces. Aftermarket grill pieces are flimsy and questionable quality.
To be fair I decided to take a pic way to late in the evening. Should've post those on your build.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Don't fret. My coworkers make fun of me everyday for my truck and get told I should "upgrade" to a JT. I shrug it off or proceed to tell them how the MJ is superior to the Gladiator wannabe.
Lockpick skill:100
Has your door locks been swapped at some point? Usually the door and glove box locks are the same key unless one or the other has been swapped.
So I talked to the tech about it. I asked him if he has a AMC cruise control tester and sure enough he knew exactly what I was talking about. Pulled it out with instructions. He has had it for forever and can not remember the last time he ever used it. He told me that if I ever wanted to barrow it, I can. I might barrow it and make a video demonstrating how it works.
Hey a Mopar front bug shield. Neat! Its got other goodies too.
*X1 -YY 3LQ APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP KD8 STRIPE/BADGE/MOLDING/DELETE LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Punk'n Metallic Clear Coat QE4 Punk'n Metallic Clear Coat SBA POWER STEERING TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 4/15/87 Body code TL61
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR DCB Transmission - 4-Speed Manual,T3340 DMN 4.78 Axle Ratio EPD ENGINE - 2.5L I4 TBI GAS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE Build date 12/2/85 Body code TL62
That’s probably right. I know for the 2.5L there’s absolutely nothing there for clearance issues so that special nut baffled me.
Wow. I have no other words but I'm glad you went back and raised hell as I'm sure I would have. But for $100 is a good deal for that in its time. I don't even trust my own work with my truck except tires and AC.
Well duh. I know there's 9 left. One dealer never changed their count to zero after they sent the nuts off to a vintage parts like company. Ah I see where you got them from. No wonder I thought there was 8 missing from the list. But having such coveted nut is worth it. Perhaps 3D print if folks don't want to go the nut and bolt route.
