13
'90 Eliminator (Puddy)
eaglescout526 replied to Jtslick89's topic in Member Projects: Your Comanches
Looks really good despite all the damage it has. And no problem. Better to score NOS caps for the same price as used ones. Your current rims look like ZJ rims. -
Let me know. Pirate and I will be out there on the 13th.
If you can't find parts there is an 89 XJ at the AMC salvage I frequent that has the AC lines and brackets. I took the controls and dash wiring though.
I recommend trying to stick with your era for your truck as it should make installation less of a headache down the road.
TJ NV3550 starter bolts
eaglescout526 replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
I know mine is pretty much unmolested(minus the radio). I wonder if the 88 model years fixed that issue. I'm sure enough techs complained about that being a problem. -
What 2.5L have you guys seen where there’s two external torx bolts for the top bell house bolts? Both mine and a spare I have had all hex bolts all around for the bell and external torx for the starter. -
Carpet/Vinyl interior from "factory interiors"
eaglescout526 replied to Deleted's topic in MJ Tech: Modification and Repairs
Well since lunch is involved I don't see why not. -
4.0 alternator on 2.5L
eaglescout526 replied to Myles Cyncora's topic in MJ Tech: Modification and Repairs
No. You will need to get the pulley with an alt combo sadly. That is how I sourced mine. Napa had one and I don't remember which one I ordered from them but it was a battle and a half to get the right one. If I can find my purchase history I will post the PN. Nope, history on that is gone. If you go to anywhere else, make sure to have the counter monkeys verify that is has a six ribbed serp belt with a v belt pulley. -
This has been a problem before as I fought with this before adding AC. Renix 2.5L's without AC have a special pulley they need to be in line with the others. The bracket is fine, its the part stores that don't know the difference between the ACless models and AC equipped. Pulley looks like this: His probably looks like this: And this should be the bracket: -
Bake until golden brown. -
Do you have AC or no AC? Doesn’t matter too much if it’s 4.0L or 2.5L. But the no AC systems require a specific pulley. I got mine from Napa a few years back with the no AC specific pulley. -
Shame. I'm sure the plastics can be salvaged.
Rear bumper doesn't look terrible.
JP5A or JP5B diesel gas tank
eaglescout526 replied to Geek's topic in MJ Tech: Modification and Repairs
Diesels got the full 23.5 gallons instead of the 16. -
Could always turn em around
It has OEM bed rails. Too bad its not a long bed.
*X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 166 Zone 66-Orlando 1AA U.S. Dealer Retail ALA SE Decor Group APA Monotone Paint BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 10/5/89 Body code JL61
*X1 -H9 3LY AGJ Driver Assistance Group APB TWO TONE PAINT PACKAGE - I APC TWO TONE PAINT PACKAGE - II CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYC Amped QA2 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 10/11/87 Body code TM61
I will get an accurate build sheet in a second. Jdog get the front bug shield and grill pieces. Aftermarket grill pieces are flimsy and questionable quality.
To be fair I decided to take a pic way to late in the evening. Should've post those on your build.
- 656 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Don't fret. My coworkers make fun of me everyday for my truck and get told I should "upgrade" to a JT. I shrug it off or proceed to tell them how the MJ is superior to the Gladiator wannabe.
Lockpick skill:100
Has your door locks been swapped at some point? Usually the door and glove box locks are the same key unless one or the other has been swapped.
