13
I can help you acquired the Honey(darker tan) ones. I think there is one driver and pass left. There looks to be tan cloth and vinyl.
Depending on the state in which the Jeep was delivered to or if the Jeep left the factory without one but the dealers put one on. Mine never came with a front license plate but my build sheet has a code that says front license plate attach required, meaning it could've been delivered to a state that required the front plate. I have seen some codes that say front plate delete.
Same way except the rear support of the bar is mounted to the wheel well closest to the rear window.
Wow. Send it to another state.
My apologies. There are no front NOS ones left.
I can get you the front part number later. I think there may be a few fronts left as NOS.
*X3 -SA Charcoal AGC Black Ram 1500 Sport Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Punk'n Metallic Clear Coat QE4 Punk'n Metallic Clear Coat TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 11/8/87 Body code TL61 More 2.5L have been showing up in yards lately. Wish I had that kind of luck.
*A6 Seats - Vinyl High Back Bucket -YY APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYM QYM SBA POWER STEERING TBG SPARE TIRE - COMPACT Build date 8/21/86 Body code TL62. Some good 2.5L parts there
Interior colors/paint
eaglescout526 replied to eaglescout526's topic in MJ Tech: DIY Projects and Write-Ups
Lol not a single one was suitable and I can not find a Chrysler color chart with part numbers to save my life. I found the charcoal color number once and then I lost it. But I do agree with you there the caps and chart are deceiving but yet all the other colors match perfectly. -
Same dilemma I had before settling with the Rustoleum charcoal color for the darker portion of the grey interior. -
When did the ball cooler disappear?
eaglescout526 replied to Airborne Janitor's topic in MJ Tech: Modification and Repairs
Despite the better air flow, I think its for the best interest to keep the family jewels cool. -
Its possible it happened for the 95 model year but was available around 93-94. -
jdog is right. 95 was when they started to appear in the XJ's as factory. The lower panel was reorderable but with the vent as removable and a plug to be ordered with it. That's from the 1984-94 PN supersession. -
Lol. Ever since I got that NOS one.
*X1 -SA Charcoal 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK GX8 Delete Keyless Entry JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PS4 BRIGHT PLATINUM METALLIC CLEAR COAT QS4 BRIGHT PLATINUM CLEAR COAT RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 3/3/88 Body code TM62
Internal to External slave AX5
eaglescout526 replied to WeezyBlue's topic in MJ Tech: Modification and Repairs
The one JeepDriver has pictured is for 94-96 XJ's. It is still available new but chances are you're not going to want to pay the price of the kit. -
Probably because of the process being cheaper for AMC -
84-86 XJ's and 86 MJ's had external. 87-92? or somewhere around there had internal then Chrysler switched them back to external. You should be fine to use either bell house. This is all assuming you have a 2.5L and AX5 -
I thought there were a couple Olympic MJ's floating around on here with all the decals and such.
*D4 TRIM STYLE D4 - VINYL BENCH SEAT -H9 165 Zone 65-New Orleans 1AA U.S. Dealer Retail 4XA Air Conditioning Bypass 4XU Quad Seat Credit ALA APA Monotone Paint BAP 75 Amp Alternator BCX Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CUM Mini Floor Console DBB All Manual Transmissions DCK 4SPD MANUAL TRANS - AISIN SEIKI DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EPE Engine - 2.5L Power Tech I-4 Cyl. GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer K3Z STRIPE/BADGE/MOLDING/COLOR KDN KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SAA Manual Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEA No Optional Sales Codes YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 12/17/90 Body code TL61
To a degree that is correct. Some Cali trucks got delivered here via train and were then shipped off to Cali or NM. But that is nice to know. Older trucks have no idea where they were sent to unless they have the original AMC build sheet.
I took mine out recently. I had a pic of the bottom removed and it looked like some sort of cloth/fiber like material. That was as far as I could take it apart. I think the vacuum from the engine pulls in the vapors from the tank to help ensure no fume is wasted and the cannister helps sort out the water from the fuel mixture if there is any water vapors in the tank.
