eaglescout526
Administrators
    13
  1. *X1 TRIM STYLE X1 - CLOTH BENCH -H9 105 Zone 05-Chrysler Military Sales 1AV Export O.M.S.C. U.S. Specifications 4HC Special Scheduling Condition III 5AM Largo Tracking 5KN Metro Cars of Detroit 8ED MISCELLANEOUS INTL DEALERS ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Open BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3E STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE8 DARK VIVID RED PRIMARY PAINT - HE8 QE8 DARK VIVID RED SECONDARY PAINT - HE8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAE MUD &&&& SNOW TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGA Without Billable Fuel YGB 1 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 1/26/89 Body code JM61
  2. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 151 Zone 51-Chicago 1AA U.S. Dealer Retail 4HA Special Scheduling Condition I 5KK First American Title Insurance CO. ADA Light Group ALA Decor Group ALK APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Open BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HW1 JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWX LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PS3 DOVER GRAY MET CC PRI PNT - HS3 QS3 DOVER GRAY MET CC SEC PNT - HS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJM 15X7.0 Chrome Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 6/4/90 Body code JL62 No problem. Not all the codes are accurate due to being recycled.
  3. 86 is an odd ball year. You would need a new air box in order to use the 87-90 2.5L boot. But being an 86, you won't be able to put the newer style box in due to the round hole for the cold air intake vs the rectangle on the 87-90 air boxes.
  4. Awesome!
  5. Awesome! Christine? If youre a fan of the old testament of Star Wars I recommend Shadows of the Empire.
  6. Ready Player One. If you have not read it.
  7. Well..this is a stab but by your name you have an 87 MJ. I believe if not all Renix MJ's did not have DRL or the side markers blink. When you pull out the switch to turn your lights on, the side markers will stay on and when you turn on your signal they will not blink. That feature appeared on newer XJ's. But all this will depend on weather you have the original Renix harness and set up or the newer HO swap.
  8. Actually its funny you say that because I did cry when I lost the accord to a ford Taurus. And the only reason why I did is because it was in the family since new and I remember riding a lot in that car. But as time went on the more I realized I would've had to rebuild the engine so I am glad it is gone. Lol. But that's not against the point, it just had sentimental value. But I agree, let the dream auto come later. More and more of these tucked away Jeeps and other cars are coming out, he just might stumble upon that one where the owner sees it as an old farm truck.
  9. Yeah it actually translates to literally a pumpkin color used today. Found that one out through the JT. But only the AMC BE Colorado Red's from pre 88 have that code for whatever reason.
  10. *A6 Seats - Vinyl High Back Bucket -YY APA MONOTONE PAINT PACKAGE AWJ Visibility Group CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP KD8 STRIPE/BADGE/MOLDING/DELETE LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL PE4 Colorado red QE4 Colorado Red SBA POWER STEERING SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels Build date 6/23/87 Body code TL61 Sold by ROY BALDWIN MOTOR CO INC CAPITOLA CA
  11. *E1 Cloth Bench Seat -YY 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA SE Decor Group ALK Italia Package APA Monotone Paint BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWW T: BRILLIANT WHITE - NAMEPLATES - W LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PQ9 DK BALTIC BLUE MET CC PRI PNT - HQ9 QQ9 DK BALTIC BLUE MET CC SEC PNT - HQ9 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 7/27/89 Body code TL62
  12. THERE WAS A KIT TO DO THIS?! *X8 Cloth Low-Back Bucket Seats -H9 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 5KN Metro Cars of Detroit ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint ARL 300 Premium Group BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3A STRIPE/BADGE/MOLDING/COLOR KKG LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PA2 STERLING SILVER MET CC PRI PNT - HA2 QA2 STERLING SILVER MET CC SEC PNT - HA2 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 9/10/89 Body code JL62
  13. Where did you find that one?
  14. See. I love that he wants an older car. Most kids in our generation don't appreciate and understand the simplicities automobiles had back then without all the computers and fuel injection. Granted our Renix trucks are computers but really easy to work with. Hell most kids today see an old car and wonder why anyone would want it because it doesn't have a Starbucks coffee warmer. That being said he should go the route of cheap and fuel efficient right now and save up to aquire his dream J-truck. Granted I had no idea what I was getting into when I got my MJ after I wrecked my Accord but I knew I wanted a truck and I knew my grandfather had a small pick up and thus I ended up with an MJ and an addiction. Plus I also don't like driving much so I still save some money on gas.
  15. Calling all WA members. I have a bit of an issue that happened to my XJ up in WA. Some neighborhood kids broke the rear quarter window on it, I plan to have AMC salvage pull a rear quarter window for me and send it up there. If anyone is near the town of Everette, PM me please if you can help me out.
  16. Doin the same thing, just work. Dealerships probably won't close but business is affected.
  17. Which side do you need? I have one for sale currently.
  18. I did the VIN not too long ago. Nothing about Metric ton. Unless the upcountry suspension group is the replacement sales code. Not even his build sheet really says so. Just a 3.55/1 differential.
  19. From ebay *X8 SEATS - CLOTH LOW-BACK BUCKET -Q8 3LV ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE AGJ Driver Assistance Group AHL HEAVY DUTY INSUL PACKAGE APB TWO TONE PAINT PACKAGE - I APP TWO TONE PAINT PACKAGE AWE UP COUNTRY SUSPENSION GROUP AWH POWER EQUIPMENT GROUP BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-5SPD AUTOMATIC 5-45RFE DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JHA WINDSHIELD WIPERS - DELUXE MBF REAR BUMPER - STEP TYPE (BRIGHT) NAE EMISS CONTROL TESTING &&&&&&&& LABEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PXB Jet Black QXG ECO Green Peral Coat RAF Radio - AM/FM Cassette SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJN 15" Aluminum Wheels Build date 1/21/87 Body code JM61 Hmmmm, Shame, his build sheet does not line up quite right with the current one....damn Chrysler. Its like the BBC when they lost all the Dr. Who.
  20. Maybe an H.O. member might be able to tell you but the Renix clusters do have an adjustable tach. Have you taken apart the cluster to get to the back of the tach to find the potentiometer?
  21. I have a couple of those from my dash bezel when I had no switches.
  22. Lol. I am not sure why to 175 though? I would think the D35 is bigger than the 30 in size.
  23. 230 is the D30. 175 should be the D35. I don't know why but its Chryslers newest thing to have the axles in MM rather than their model. If you had a D44 it would actually say which is one of the few codes that Chrysler still uses.
  24. No problem! Remember 90% of this sheet is accurate. Any of these codes could be recycled ones by Chrysler for the newer cars.
