eaglescout526
Administrators
    13
  1. Nope! That system is all plug and "where the hell does that go?".
  2. Yes. Doesn't matter which trans you have. I have an auto set up in mine and it works just fine.
  3. Lol. That's your starter dork. The hose circled is the evap canister and its run off.
  4. Snag it. It is nice to have with the 2.5L.
  5. Looks like that cluster came out of a Jeep with cruise. Did you snag that too? Also just realized that cluster came from an XJ with the 2.8L the tach will never read right.
  6. Only compatibility issue is the speedo cable. 87-90 used a pinch type clip cable vs the ones 84-86 used. Otherwise it is plug and play. There are needle puller tools
  7. *ZZ -ZZ AJT RADIO PREP GROUP AJY Popular Equipment Package CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGZ Transmission- 4-Spd. Automatic EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 11/20/85 Body code TM62
  8. 7TH photo is evap canister
  9. *X4 -SA Charcoal 3LY ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGW Transmission - 4-Spd. Automatic,44RE ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL NHB HVY.DTY/AUX TRANS OIL COOLER NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 7/14/88 Body code JM62
  10. I need to sit down and PDF some of my manuals.
  11. So some updated news. They have been busy but they are finishing up the work on this decal. I should hopefully see it here in the next week or so.
  12. *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4EA Sold Vehicle 4XA Air Conditioning Bypass AHL Heavy Duty Insulation Group APA Monotone Paint ARM Radio AM/FM Cassette BAY 105 Amp Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRC Entire Fleet Key Alike (FREQ 7) GUB Power Mirrors-Base HCD Do Not Use - See HCA HGD Deluxe Insulation Group JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JJA Cigar Lighter K2B STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KLH LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 1/14/90 Body code JL61.
  13. Well my curiosity got me. Tis beautiful. Will get you a build sheet if I don’t forget.
  14. Satiraclehen rebuilt his in his build thread. Ask him what he used. It has to be a really pliable rubber material.
  15. No. No NOS at any dealer. There’s a couple XJs that I know have these handles I can pull.
  16. No problem. What Mjeff87 said about the blower. Wouldn't hurt to take it out and lube it up either. There is a ground mod you should do for it if you have AC. Service components do include those two and your suspension and steering pieces. Basically pieces that wear out with mileage and time. Yes the C101 if your 88 has it(if it was made before the year 1988, went away with the late 88 and 89-90 model years) can be a huge source of resistance but not surge power. Disregard my power surge comment, that was used in place of electrical resistance when I was lacking the better term.
  17. I'm sure the blower motor still works in that state, I've had this happen under hard acceleration where air will stop coming out of the vents. Check the vac lines, the motor should be running always. The vent doors are controlled by vac assisted motors. Unless you have a power surge when accelerating which can lead to future problems. Just do a thorough check of every service component and make sure everything is working and up to spec.
  18. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -SA CHARCOAL 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4HA Special Scheduling Condition I 4XA Air Conditioning Bypass ALA SE Decor Group APA Monotone Paint BAP 75 Amp Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer K3Z STRIPE/BADGE/MOLDING/COLOR KDN KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 12/5/90 Body code TL61
  19. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 173 Zone 73-San Francisco 1AA U.S. Dealer Retail 4AF American Coin Merchandising 4HC Special Scheduling Condition III 5KN Metro Cars of Detroit ADH Heavy Duty Electrical Group ALN Body Color Bumper Group APA Monotone Paint ARL 300 Premium Group BA1 100 AMP ALTERNATOR BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3A STRIPE/BADGE/MOLDING/COLOR KKE LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAE California Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PA2 STERLING SILVER MET CC PRI PNT - HA2 QA2 STERLING SILVER MET CC SEC PNT - HA2 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 6/7/90 Body code TL61
  20. *W7 Cloth Lo-Back Bckt/Red Accent Seats -SA Charcoal 3LX ADA LIGHT PACKAGE ADL PACKAGE - 4X4 PROTECTION AGL APA MONOTONE PAINT PACKAGE CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS - FRONT LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Punk'n Metallic Clear Coat QE4 Punk'n Metallic Clear Coat RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJN 15" Aluminum Wheels XEA TOW HOOKS Tow hooks option. Neat. Build date 3/1/88 Body code JP62
  21. Gorgeous. Now were all gonna want a build thread.
  22. That's how I feel about getting NOS parts.
  23. The five piece grill set up is starting to get hard to find. I know the chrome marker bezels are reproduced but not black. As you said interior is desirable but pretty much everything from the door and back is unique and should be a must snag and don’t forget the drip rails. Under hood lamp and Renix 2.5L stuff is disappearing faster than the 4.0L
  24. Yup. There.
  25. 1JTML63SXHT020483 Shame. She was a beaut. *A6 Seats - Vinyl High Back Bucket -Y1 3LW AGI APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DMR 3.42 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL NHM AUTO SPEED CONTROL PE4 Punk'n Metallic Clear Coat QE4 Punk'n Metallic Clear Coat RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 9/21/86 Body code JH61. Oooo high level code. Never seen one.
