eaglescout526
Administrators
    13
  1. Hope you didnt ditch those factory bed rails somewhere. But looks like a good find even at 74K on the odo.
  2. There are no 2.5L cam packages left.
  3. Looks like I’m running some 2.5L performance part numbers on my lunch.
  4. Jesus. H. Chrysler.
  5. Thats awesome! I’ve never seen such a good example of that sticker except in the catalog. That needs to be remade.
  6. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE AJZ AWH POWER EQUIPMENT GROUP AWJ Visibility Group BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGZ Transmission- 4-Spd. Automatic,MT643 EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJM Wheels - 15 x 7.0 Chrome Build date 9/2/85 Body code TP62
  7. *Q7 Cloth Low-Back Bucket Seats -SA CHARCOAL 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount 4XA Air Conditioning Bypass ADA Light Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BAF 130 Amp Alternator BCC Dual 730 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHS Floor Mount Automatic Shift Lever DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3X STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Front Bumper MCA front bumper pads MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PX8 Black Clear Coat QX8 Black Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TRM On/Off Road Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEA No Optional Sales Codes YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 4/29/91 Body code TL61
  8. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADL SKID PLATE GROUP AJY Popular Equipment Package AWE AWJ Visibility Group BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GTZ MIRRORS - MANUAL REMOTE HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 12/9/85 Body code JM62
  9. So its been a week, with retuning to work sooner than I expected, doing anything to this bumper will be slow now. I spent the past few days removing surface rust anywhere I could get a flap disc, cut off wheel, wire brush and sanding wheel to remove the rust. Most of it is gone with the exception of a couple areas. I did manage to get the bracket plates welded to the factory ones for better support. First weld was not bad but not good but its together. The second one after showing my father tells me to turn up the wire speed on the welder and I got better results that time. All in all its coming along. Right where the support goes I left some vinegar in there and was able to get all the rust inside removed. Now to beef it up and make it better.
  10. At least it can be done once a year with good results VS every other month probably. Also ive enjoyed reading the new things that come up with your CJ.
  11. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 172 Zone 72-Portland 1AA U.S. Dealer Retail 5AM Largo Tracking 5KN Metro Cars of Detroit ADL Skid Plate Group ALN Body Color Bumper Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3E STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE8 DARK VIVID RED PRIMARY PAINT - HE8 QE8 DARK VIVID RED SECONDARY PAINT - HE8 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW All Terrain Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 9/26/88 Body code JM61
  12. Like I said I know the ones I’ve seen are the older style. I should pull them anyways for anyone like you.
  13. being an 85 it probably may be too early to have it fit without modification.
  14. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AJT RADIO PREP GROUP AJZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAF HIGH ALTITUDE EMISS CONTROL PKG NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SUA TILT STEERING COLUMN Build date 8/1/85 Body code JP62
  15. I may know where a couple are at AMC salvage, but being back to work, my time is limited to getting down there. So if someone else doesn’t have one right away I can go next Monday which will be my day off and go look for ya.
  16. If I had to guess, sportruck stripes.
  17. Unless the OP goofed the VIN when reading it, unfortunately if the whole VIN is wrong when we run it, we run the last eight and that usually yields us a VIN. But it may not be the right VIN and usually the last eight are unique to the vehicle unless its a newer vehicle with the same last 8.
  18. https://www.ebay.com/itm/91-96-Jeep-Cherokee-Comanche-XJ-Factory-Speedometer-Gauge-Cluster-OEM-119K-Read/193548854911?epid=1923990800&hash=item2d1069267f:g:kXIAAOSwD6le~gPq I don't know about you guys but it aint right.(I know what it is)
  19. Only took me a day to get everything back but yes its nice. Time to support the addiction again.
  20. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) RAC RADIO - AM/MTR SBA POWER STEERING Build date 10/6/85 Body code TL62
  21. RWD Sport with a long bed.
  22. Theres something really really weird with this VIN. If I had to suspect, it could be some weird unrecorded VIN or a lost data VIN.
  23. Looking. Like JMO said, its locking up the catalog for whatever reason. Let me try DC.
  24. Build date 10/30/85
