eaglescout526
Administrators
    13
  1. Also the temp gauge grounds out upon start up. Does it do that and come back down before going to a high temp?
  2. I was thinking 10W30 too. It’s a good oil weight for out here.
  3. Alrighty I got one for ya guys since oil weight makes controversy around here. If you guys were (and those of you who down own) to run an oil weight in your vintage engines(prior to EFI era), specifically a 403 olds, what weight would you use? I haven’t done an oil change yet and the internet is not fruitful for a specific oil weight, but I have some 20w50 I’m gonna run and use since it’s free oil from my other grandfather.
  4. Pretty damn lucky haha. I have a member on here to thank very much for finding it. I also snagged a NOS master cyl for the system sentry. Here goes nothin with this set up and I will let you know, it seems very simple for how complex it sounds.
  5. Haven’t had much progress on doin the floors. Wife has been obsessed with bandit lately so I’ve been getting that figured. Buuuuutttt I got this for Chunk Oh yeah. System sentry is coming. Thanks Will!
  6. Could be a lot worse. Take your time, start with the cheapest and work your way up. Probably best to get all the parts first and spend a weekend or two replacing old with new rather than replace a few here and there.
  7. Fuel leak addressed. Still have idle issue but as soon as it gets warm it idles and revs real nice. So I need to actually adjust the fast idle to warm up and then it should do just fine. Gettin closer to doing a drive around the block.
  8. Wow. It’s got the right code for it. That’s impressive. Yes 23 gallon tank can be had. Only on long beds. The 16 and 23 share the same tank stamping but there’s a baffle inside that changes the gallons that can be had.
  9. *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 135 Zone 35-Washington 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JJA Cigar Lighter JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 1/9/89 Body code JL61 Sold by PINESBROOK JEEP-EAGLE, LYNCHBURG VA
  10. *ZZ -ZZ AJY Popular Equipment Package CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 1/2/86 Body code TM62
  11. 1JTHL65F5GT131063 *ZZ -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT DDQ Transmission - 5-Speed Manual DMN 4.10 Axle Ratio EPD ENGINE - 2.5L I4 TBI GAS GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW HOOKS Build date 1/10/86 Body code JL62
  12. Dammit. I knew I missed one.
  13. Got the new choke tubes in and got myself a new problem. Won’t idle right so I did some adjustments to the choke and got it to do a nice steady idle at 1k rpm. I know it’s supposed to be lower but I’ll work that out soon. I also found another fuel leak at the fuel inlet. I plan to address this tomorrow with a new fuel filter and Teflon on the fuel filter pipe to stop the leak.
  14. Good point, chances are it probably will. Course right now Chunk is in pieces still so I’m no where near adding cupholders.
  15. *J5 Cloth/Vinyl High-Back Bucket Seats -SA Charcoal 00D 40510-111 Mga 00D 00K 40726-105 MGA 00K 00L 40725-100 MGA 00L 00V 40815-105 MGA 00V 00X 40826-103 MGA 00X 0AD FAM: DA TRACKING: 71029T15 MY:2008 0AI 40919-105 MGA 0AI 0AK PCN 40729-150-Z MGA 0AK 163 Zone 63-Dallas 1AA U.S. Dealer Retail 26E Customer Preferred Package 26E 2TE Customer Preferred Package 2TE 3VR Customer Preferred Discount 644 Texas State Code 944 Texas State Code APC Center Band Two Tone Paint ARW Sport Decor Group (97-02-26) AWH Power Equipment Group BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CAD High Back Bucket Seats CBX Door Trim Panel - Carpet/Vinyl CDB Reclining Front Seats CFM Rear Fold w/Removable Cushion Seat CGT Driver Air Bag Only CKA Carpets - Floor and Cargo Area CKN Cargo Compartment Carpet CKT Cargo Tie Down Loops CKX Plastic Liftgate Trim Panel CLE Front &&&& Rear Floor Mats CSA Spare Tire Cover CSC Cargo Compartment Cover CSR Passenger Assist Handles CUF Full Length Floor Console CUN Overhead Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHS Push to Pass DMD 3.55 Rear Axle Ratio DRA Corporate 8.25 Rear Axle EAA All Engines ERH 4.0L I6 Power Tech Engine GBB Tinted Windshield Glass GCB Front Door Tinted Glass GED Tinted Rr Drs/Qtr/Liftgate Glass GEH Fixed Door Vent Glass GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Power Mirrors, Fold-Away GVA All Vehicles W/O Power Mirrors GXM Remote Keyless Entry HAA Air Conditioning HGD Deluxe Insulation Group JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JHB Rear Window Wiper/Washer JJA Cigar Lighter JJB Dual Note Electric Horns JPA Power Windows JPB Power Locks K27 Bodyside Molding K2R FLAME RED CLEAR-COAT - MOLDING K3Z BLACK - FENDER FLARES KSX BLACK CLEAR COAT - LOWER TWO TONE A KVP RADIANT SILVER MET. C/C - BADGE - SP LAJ Headlamps On Warning Chimes LBC Glove Box Lamp LDB Cargo Compartment Lamp LMA Halogen Headlamps LPS CHMSL Lamp MB1 Black Front Bumper MB5 Black Rear Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Qtr Solid Window Insert MMG Belt Moldings MMK Body Color Drip Trough Molding MNA Black Door Handles MUK Silver/Chrome Badging MWG Roof Rack NAA Federal Emissions NBK EVAP Control System NFA 20 Gallon Fuel Tank PJN Moss Green Pearl Coat QX9 Black RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers RDD Fixed Long Mast Antenna SBA Power Steering SCG Leather Wrapped Steering Wheel SDA Normal Duty Suspension SHA Front Stabilizer Bar SHC Rear Stabilizer Bar SUA Tilt Steering Column TBC Compact Spare Tire TBL Inside Mounted Spare Tire TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGG 9 Additional Gallons of Gas Z1A GVW Rating - 4550# ZFH Spring - Left Front ZFT Spring - Left Rear ZUH Spring - Right Front ZUT Spring - Right Rear Build date 3/1/95 Body code TL72
  16. *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 163 Zone 63-Dallas 1AA U.S. Dealer Retail 26K Customer Preferred Package 26K 2TK Customer Preferred Package 2TK 3J3 No Charge Air Conditioning 3VQ Customer Preferred Discount 4M1 Retail to Bid Diversion Tracking ADA Light Group APA Monotone Paint ARC Rubicon X ARN Laredo Decor Group AWH Power Equipment Group BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CFM Rear Fold w/Removable Cushion Seat CKB Floor Carpet CKN Cargo Compartment Carpet CKT Cargo Tie Down Loops CKV Cargo Area Storage CLC Front Floor Mats CSA Spare Tire Cover CSC Cargo Compartment Cover CUF Full Length Floor Console CUN Overhead Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHS Push to Pass DMD 3.55 Rear Axle Ratio DRA Corporate 8.25 Rear Axle ERH 4.0L I6 Power Tech Engine GBB Tinted Windshield Glass GCB Front Door Tinted Glass GED Tinted Rr Drs/Qtr/Liftgate Glass GEH Fixed Door Vent Glass GFA Rear Window Defroster GRB Entire Fleet Key Alike (FREQ 6) GSB Right Convex Mirror GTB Power Heated Mirrors GXM Remote Keyless Entry HAA Air Conditioning HGD Deluxe Insulation Group JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JHB Rear Window Wiper/Washer JJA Cigar Lighter JPA Power Windows JPB Power Locks K3D SHALE GREEN MET. C/C - Fender Flare K4D Applique - Bodyside, Body Color KCM VIPER STEEL GRAY - DIMENSIONAL GRAP LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDA Underhood Lamp LDB Cargo Compartment Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps MBU Argent/Dark Argent Front Bumper MBZ Argent/Dark Argent Rear Bumper MCA Front Bumper Guards MDA Front License Plate Bracket MFM Grille-Black/Bright MHB Bright Windshield Moldings MMC Rear Qtr Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I MWA Roof Rack NAA Federal Emissions NBK EVAP Control System NFA 20 Gallon Fuel Tank NHM Speed Control PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCG 6 Premium Infinity Speakers RDC Power Antenna SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBL Inside Mounted Spare Tire TMW P215/75R15 OWL All Terrain Tires TZA Goodyear Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z1B GVW Rating - 4600# ZFX Spring - Left Rear ZNB Spring - Right Front Build date 4/9/92 Body code TL74
  17. *X8 Cloth Low-Back Bucket Seats -Q8 133 Zone 33-Philadelphia 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores ALM APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor CSR Passenger Assist Handles CUM Mini Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHS Push to Pass DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3C STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PQ9 QQ9 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 5/17/89 Body code JM61 Sold by KOVATCH LEHIGHTON JEEP, LEHIGHTON PA
  18. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 132 Zone 32-New York 1AA U.S. Dealer Retail 4EA Sold Vehicle 4HC Special Scheduling Condition III 5AM Largo Tracking 5KN ADB Protection Group ADH Heavy Duty Electrical Group ADL Skid Plate Group ALN APA Monotone Paint BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor Area CLA Front Floor Mats CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Performance Data & Video Recorder JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MCA MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK MMP MOLDING - DOOR EDGE GUARDS NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 11/14/88 Body code JM61 Sold by BROWN'S JEEP CHRYSLER DODGE, PATCHOGUE NY
  19. *B1 TRIM STYLE B1 - CLOTH & VNL BENCH SEAT -SA Charcoal 173 Zone 73-San Francisco 1AA U.S. Dealer Retail 4AF 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAE California Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PWB PEARL WHITE PRIMARY PAINT - HWB QWB PEARL WHITE SECONDARY PAINT - HWB RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA SCB Perforated Steering SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 8/19/88 Body code TL62 Sold by JOE KERLEY JEEP, SAN JOSE CA
  20. *X3 -YY AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PE4 Colorado Red QE4 Colorado Red RAC RADIO - AM/MTR SBA POWER STEERING TBG SPARE TIRE - COMPACT WJM Wheels - 15 x 7.0 Chrome Build date 12/3/87 Body code TL62 Sold by SOUTHEAST CHRYSLER JEEP DODGE, NASHVILLE TN
  21. *X3 -SA Charcoal AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS NAA ESA W/CATALYST (EXC CALIF SYSTEM) PX6 QX6 RAC RADIO - AM/MTR TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 5/25/88 Body code TL61 Sold by HAUSMAN MOTOR COMPANY INC, LOUISVILLE KY
  22. *X1 -YY APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JDA SPEEDOMETER - 140 KILO PRIMARY JGB Clock - Digital KQJ LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MWB SPORT BAR NAG PYM QYM SBA POWER STEERING TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Same info as above but in list.
  23. *ZZ -ZZ AGR AJT RADIO PREP GROUP AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR DGF H D A904 AUTO TRANS EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 10/11/85 Body code JM62 Eww Blue on garnet?
  24. *ZZ -ZZ APP TWO TONE PAINT PACKAGE - (MEX POLICE) CGX Head Restraints-Outboard Seating, RR DGZ Transmission- 3-Spd. Automatic EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GTZ MIRRORS - MANUAL REMOTE HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) RAC RADIO - AM/MTR Build date 5/26/86 Body code TL62
