eaglescout526
Administrators
    13
  1. Nope. They rarely pop up. The only other one I and probably other members have seen was on a junkyard MJ.
  2. I’m pretty sure the catalog just calls it a rear step bumper. It’s very similar to the J-truck rear bumper but made specifically for the MJ. The later bumper was made to fit the style of the front.
  3. That is a really rare factory 86 only bumper. Just an FYI.
  4. This one I have a better idea on than actually hanging the header haha. I have an idea on how to hang the header as well but want to see if theres any good ideas out there that might be like mine.
  5. I did some digging to see if I could find a post on folks hanging header panels and applying power to them, but I can not find the post right now. Anywho has anyone done this? I think I have an idea on how I want to do this but I want to see if anyone else has done it with some good success.
  6. There are 4 colors that I know of and none of them are that different. Orange was found in YJs and CJs, Yellow was in the XJ, MJ and SJ(I have seen a couple with the yellow), Black was found in SJ's and Grey was the Dana Corp aftermarket version that was offered to everyone else. As far as I know of specific years for what color is beyond me, chances are, someone found a box and said this would work. I actually have an orange one, came from AMC salvage and they had YJ written on it.
  7. Official kit page is now live! Check it out for any details, please ask any questions there or here as I will leave this one open as well for a little bit. I have a list of who posted first to recent. I will go in that order. Please allow me a week or two to get production going as I need to order some parts to complete these kits like the vac lines. Thank you all for your interest in these once more! I am happy to provide the service again!
  8. TCU’s are different. How different? Well part numbers are different I know that much. As for the internals? Well I’m not sure. Now I don’t see why a 4.0L TCU wouldn’t work, I’d just imagine it would have different shift points than what the AW4 would actually need for the 2.5L.
  9. Actually not a lot is involved. It’s about an hour or two to install. I have a thread up but it’s hidden at the moment. Doing some editing to it.
  10. Couple years ago, I offered full complete cruise control kits and came with everything needed to set up an MJ or XJ with cruise control. Outlined here will be the details of the kit, parts included, parts not included, limitations and warranty of the outlined kit. Details of the kit: The kits made will be put together with new and used parts. Used parts being the wiring harness, the regulator, the vacuum football, speed sensor and the servo. New parts will include brake switch, vacuum harness, speedo adapter. * I hand build the vac harness, it takes me some time to do as I use a NOS harness as a template to make sure the hoses are the right length from the football behind the bumper to the servo and engine side vac harness. All the regulators (yellow AMC box) have been/get tested before leaving my possession to ensure they are working and will be ready to go in your MJ. I do set the potentiometers on the regulator to basic testing specs to ensure the box is working, you as the end user will have to adjust the potentiometers to ensure cruise control is running how you want it to. I will include the adjusting procedure and what potentiometers do what with the instructions. All other used parts are tested to make sure they’re in working order. The regulator is the brains of the operation and is the most important to make sure it’s in working order. These kits include instructions faithful to what AMC typed up back when the kits were new. It is easy to follow and even references a DIY here on CC for visuals and help. Now here is what the kit will include: Wiring harness, vacuum harness, brake switch, cruise/turn signal stalk, vacuum reservoir(football), servo w/cable w/mounting bracket, speed sensor, vacuum dump valve (most are attached to the wiring harness), speed sensor to cluster adaptor. What isnt included: Speedo from the transmission to the speed sensor. Here is the part number for the speedo cable: 53006180(other numbers include:(2wd)53002871, 53006186,53009006, 05003807AA,(4wd)53000059, 53003899, 53004894, 53009000, 04740321), available from crown automotive. I purchased these cables when I used to make the kits, I liked the quality of them over the others, but if you do not, there is the part number to cross reference to other cables, it is for 4wd 4.0L but will work on a 2.5L w/4wd and even 2wd models. I can no longer provide these cables and If I did the price of the kit would jump up to cover the cost of the cable. Better to let the end user find the cable they like if they are unsatisfied with the cable I provided On the user end: Here is what will need to be done by the purchaser. Regulator adjustment. This adjustment will help dial in proper engagement of cruise control, when it engages and spot on engagement at the requested MPH setting. Instructions will be included. And purchasing a speedo cable. Price of these kits will run $200, that includes my time to assemble the kit, assembling the vac harness, the parts and shipping of the kit to you. Paypal friends and family option is preferred as it gives the seller the full amount. If for whatever reason parts end up arriving damaged, I will see about replacing them at no extra cost. Limitations: Sadly, I am limited to the parts I have on hand. If you're a 2.5L owner, I won't be able to make you a kit due to the servo cable lengths being different between both Renix engines. Now this doesn't mean that one can’t get creative enough to mount the servo elsewhere to work, I as a 2.5L owner did not find a good place to mount the servo properly that worked for me. If that is something you are willing to take the risk with, I won't be responsible for any issues that occur to the cruise control. Now if it's a 4.0L it will all bolt in place without any issues as most if not all the parts have originated from Jeeps that have 4.0L's. *Depending on the model year of the cluster I need to know if I need to send an 84-86 adaptor or an 87-90. Also, it's the perfect opportunity to swap in an 84-86 full cluster if you are interested in that route. Warranty: Now given most of the parts are almost 40 years old I am willing to give a warranty on specific, irreplaceable parts. One being the regulator, I did have one fail on me personally years ago and replaced it with a working one. I will provide a lifetime warranty (given if I have the parts) to the purchaser on the following parts: Regulator, servo and the throttle cable. Before sending any replacement parts, we will run through some diagnosis from the FSM to make sure that nothing is either user error or wiring harness fault. If I cannot provide a replacement part, meaning my stock has run out, then there won't be much more I can do as like I said, these parts are approaching 40 years of age and are NLA anywhere. That being said, I will be requesting the non-functioning part back to diagnose the issue. I will also not be held responsible for any damage to the cruise control kit once it is in your possession and has arrived safe and sound. Any user damage to the parts will null the warranty above and will be charged for the replacement part outlined in the warranty or any other part in need of replacement. I am always available for any questions and concerns about the kit, installation and operation. The line of people interested in the kit as follows: Whitaker717 Yungupgrade Jkey8195 ChiefSparkster gvthnks I will send each of you a PM asking for shipping info, once I have that I will follow up with a tracking number as soon as I get it shipped. Expect a week or two of production to at least get a couple kits made. Oh and please let me know which year set up you are running or if you swapping to an older style cluster.
  11. I will start a new official thread this evening. I will include the details of the kit, warranty of irreplaceable parts(will explain), price(will break down) and what will have to be acquired on the user end(will explain this too). I’ll include a list of the members I have in order of who approached first and will be sending out PMs in the order. I’ll do it in a similar style that Dzimm did with his tail lamps.
  12. 5 and 6. Alrighty I’ll put this project on my priority list.
  13. I’ll shed some light but probably chances are Chrysler probably left the part number as a cast number after the original number stopped being what it used to be in the first run. Chances are the other two are different part numbers. Why spend more money to change a part number in a wheel when you can just run it and change the part number outside of the wheel?
  14. Holy crap! A sure a crap that’s a selec-trac MJ! That’s not something you see everyday. No problem.
  15. Ironically it actually doesn’t matter. All the wiring harnesses are for auto trans. The only difference between the two is the manual has a switch that turns cruise on and off for shifting which isn’t needed unless you need to shift then you just tap the brake pedal and shift as normal and hit resume on the stalk.
  16. No problem. The ML in the last 8 stood out to me.
  17. I would check fuses and relays before wasting the time to get the new starter in only to be back to square one. If you had lights and what not then it would be a different story. The starter relay is located on the passenger side of the bay by some relays with hopefully a black cover still protects them.
  18. Peculiar. Battery is good? Did you clean the starter relay?
  19. Lol yup. You’re amongst the three.
  20. *A8 TRIM STYLE A8 - VINYL LOW BACK BUCKET ST -SA CHARCOAL 173 Zone 73-San Francisco 1AA U.S. Dealer Retail 3V3 Customer Preferred Discount 4AF 5KN ADL Skid Plate Group ALN APA Monotone Paint ARL BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3B STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAE California Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PB3 QB3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires TZH Michelin Brand Tires WJN 15" Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 8/23/90 Body code JL62 Sold by THOMPSON'S CHRY-JEEP, PLACERVILLE CA
  21. *X8 Cloth Low-Back Bucket Seats -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 4EA 5KM AMES Department Stores AHL Heavy Duty Insulation Group ALM APA Monotone Paint ARL BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning HGD Deluxe Insulation Group JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3X STRIPE/BADGE/MOLDING/COLOR KKE LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAF High Altitude Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PX8 Black Clear Coat QX8 Black Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z78 Right Front Spring Group VIII Build date 10/31/89(spooooookyyyy) Body code JL62 Sold by PHIL LONG DENVER JEEP-CHRY, DENVER CO
  22. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 141 Zone 41-Cincinatti 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA ALK APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RA8 Delete Radio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z57 Left Front Spring Group Vii Z77 Right Front Spring Group VII Build date 10/3/89 Body code TL61 Sold by TOM WHITESIDE AUTO SALES, MT STERLING OH
  23. *D1 TRIM STYLE D1 - CLOTH BENCH -SA Charcoal 142 Zone 42-Detroit 1AA U.S. Dealer Retail 5AL APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Solid Window MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PB3 QB3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 8/21/88 Body code TL61 Sold by CHAMPION JEEP-EAGLE INC, MT CLEMENS MI
  24. *A6 Seats - Vinyl High Back Bucket -H9 3LR APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHB HVY DTY/AUX TRANS OIL COOLER NMB ENGINE COOLING - STANDARD DUTY PX6 QX6 RAC RADIO - AM/MTR SBA POWER STEERING TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WJN 15" Aluminum Wheels Build date 3/23/87 Body code TL61 Sold by MCCAFFERTY JEEP, LANGHORNE PA
  25. *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -H9 142 Zone 42-Detroit 1AA U.S. Dealer Retail 3V3 Customer Preferred Discount ALN APA Monotone Paint ARL BAP 75 Amp Alternator BCC Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3M STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE9 QE9 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TMW Tires TZH Michelin Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z77 Right Front Spring Group VII Build date 6/9/91 Body code TL61 Sold by YARK CHRYSLER-JEEP-DODGE-RAM-FIAT, TOLEDO OH
