Project “Tomahawk”
ghetdjc320 replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Replacement Cab Heat shield
ghetdjc320 replied to Salvagedcircuit's topic in MJ Tech: Modification and Repairs
I used dynamat followed by 3/4” dynaliner. Looks to me like that’s going to do the trick and work great -
Also curious. I like the idea of that corner armor as well
Anyone working on reproducing splash guards/mud flaps?
ghetdjc320 replied to ghetdjc320's topic in The Pub
I was thinking of something similar. With a good front and rear trace out, I could trim it from a generic mud flap -
Anyone Done a D44 ARB Locker Install?
ghetdjc320 replied to AdroitKirby's topic in MJ Tech: Modification and Repairs
I’ve done a few -
Project “Tomahawk”
If the top of the shackle points forward to the TC 10* as they’re suggesting that would be great. As it is, it’s pointing approx -25* if their statement is to have any logic.
That’s like saying there is still gold to be found. If you know where they are please let me know -
True but royalties to bare the logo are a tiny percentage of the cost and relatively easy to apply for. -
I haven’t heard any updates for some time but was wondering if anyone has this project on their radar. We could really use some and it doesn’t seem like it would be that difficult to reproduce. I do recall there was a member making the brackets for the rear splash guards. This post is somewhat self serving as I need some myself
Project “Tomahawk”
Just knocked out what I hope to be the last of the patch panels. I’ll sand down the hole bed and shoot it with epoxy primer before adding some evercoat fibertech over the weld joints followed by Rage then a glazing compound as a skim coat. Bottom of the bed and inside will be raptor lined. Some strategic use of seam sealer and adding better drainage is in order as well. -
Project “Tomahawk”
Yep that’s it! Got mine at Morris 4x4. Took about maybe 2-3 weeks to ship. I still have it all wrapped up in the shop along with a ton of other things. The D ring version of this bumper adds some cost but that’s because they add significant bracing for those d ring mount points. It’s a very nice bumper for sure. Was planning to go with the Hanson rear MJ bumper (not advertised but they will make them upon request) as it matches nicely but I also have an oem bumper and hitch I could use if need be. -
Need a quick measurement
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Could just be some slight variances in the flare mounting holes. They do have some play in them -
Perfect, thanks! -
Hello all, my MJ is all apart so I can’t get this dimension but I need the space between the front and rear flares for stock flares on a short bed rig. The back edge of the front flare to the front edge of the rear flare. TIA!
KJ 8.25 nuff said. Right bolt patter, better width than stock, nice sized disks, 3” axle tubes that don’t spin, plenty of locker options, non oversized pumpkin, no shims needed to setup carrier due to adjusters. It has plenty of brackets to remove just like the 8.8. They are also relatively easy to find and economical. If your swapping front and rear axles that’s a different story
Brake upgrades - start with this
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: DIY Projects and Write-Ups
Centric is a go to if oem want not available. Normally a pretty good bet -
Project “Tomahawk”
Project “Tomahawk”
Project “Tomahawk”
Updates! Doing the final metal work and prepping the patch panels. @Dzimm made me a custom set of tail light housings for the 1156/1157 waterproof sockets. These use 4 locator tabs and have a much better seal. All the wiring is sealed as well. Trying to track down a set of splash guards/mud flaps if anyone has any they’d like to sell/trade. -
The KJ Liberty 8.25 is the way to go. It runs 2.5” wider than the stock Dana 35/44 and matches the truck perfectly. Disk brakes are simple to service and self clean which is a nice advantage in certain applications. Plus it’s a relatively easy axle to setup with gears and a locker
whats with these dual rate coil springs?
ghetdjc320 replied to MancheKid86's topic in MJ Tech: Modification and Repairs
I also ran the Metal Cloak springs in my MJ. They worked great and stayed in the bucket as described. The higher quality springs are typically Metal Cloak, Old Man Emu and Currie. Rubicon express are a decent option still though. Ride quality is still mostly determined by the shocks for a coil spring setup. For a Jeep Speed style rig built for high speed off-roading, the acos pro with the hydraulic bump stops is a nice setup when tuned and setup properly.
