87Chief
Everything posted by 87Chief
1989 LWB 4.0 4x4 Overland Build
87Chief replied to TuckerTJ's topic in Member Projects: Your Comanches
Can you send me pics of your roof top tent rack? The photobuxket filter set so I can't see them.. email is littlemlittle@gmail.com I'm want to mount a RTT on a rack in the bed but want it to be removable. Thanks!- 47 replies
- overland
- roof top tent
(and 4 more)
Tagged with:
We're at the alignment shop
87Chief replied to coolwind57's topic in MJ Tech: Modification and Repairs
I had the same problem with my 87 chief, I got adjustable lower control arms and it helped out a lot. Better than buying new shim (you get new LCA's). -
Thanks!
Ok, thanks for the replies!
Yes, I know the ECU is different. I'm going to replace to the 2.5 ECU with a 4.0, I'm just not sure which one I could use, the auto or do I have to get a 5speed ECU?
I am in the middle of swapping my 4.0 into my 87 2.5 and need some help with the transmission wiring.. I acquire a 88 4.0 aw4 combo donor, got the engine wiring harness, computers (transmission too), pretty much stripped it down. I am wanting to go with an ax15 or nv3550, but I'm not sure I can use the current computer I have since it had a aw4 in it.. I don't want to replace the interior wiring, but I do have some loose wiring from the aw4 in my engine bay at the moment, can I get rid of those if I'm going 5 speed? I guess my question is do I need to get a 4.0 5 speed computer? Thanks
How much was the nv3550 if you don't mind me asking? Also what year and make did it come from? What trade did you use and did you run into any problems with the input shaft being flush? Thanks!
Short wheel base bed dimensions
87Chief replied to mattbuch96's topic in MJ Tech: Modification and Repairs
Some threads in here that can take you there. http://comancheclub.com/topic/38023-what-other-camper-shells-fit/ -
for those who have bobbed long beds
87Chief replied to wheelsaz08's topic in MJ Tech: Modification and Repairs
http://www.pirate4x4.com/forum/jeep-cherokee/846058-bobbed-mj-info-needed.html And here http://comancheclub.com/topic/17768-bobbed-bed-pix-please/ -
Good luck!
Will theses wheels fit a Jeep comanche
87Chief replied to ComancheLee's topic in MJ Tech: Modification and Repairs
Don't do that. -
Probably the only thing I would do with an LS comanche..
I think the benefit to 97+ doors are the no vent windows (bigger room). and the seal on the door. I could be wrong though, but that's just my opinion.
:popcorn:
Are you wanting another 4.0L or something else? I think up to 96 fit just the sensors are different, not sure which ones though.
Anyone else have SO that keep there projects in check?
87Chief replied to Comanche SS's topic in The Pub
Preach. -
4.0l from 2.5l motor mounts question
87Chief replied to 87Chief's topic in MJ Tech: Modification and Repairs
Thanks! -
I agree with this. Haven't done it yet, but I'm sure it will add a lot of room.
Awesome, thanks for the info! Just to make sure, the passenger mount is just a beefier mount correct? It stays in the same place? Thanks! -
I will, I just wanted to make sure that the track bar bolts are different from the 4.0 and 2.5.. -
Passenger 4.0 Sent from my SM-G930V using Tapatalk -
Was wondering if these mounts look correct. I figured the passenger mount mounts in the same spot. The driver mount looks to come forward just a bit... anyone else know if their second track bar mount goes into the motor mount? I just want to make sure these look correct. (Shiny black is from 88 4.0 and the other bigger mount is 4.0 also.) Old 2.5 4.0 Above is old 2.5. This is the bottom of the driver 4.0. Sent from my SM-G930V using Tapatalk
360 Fuel Injection Build
87Chief replied to 360MJDude's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I think it's up for sale.... http://www.ebay.com/itm/1986-Jeep-Comanche/232142964528?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D39107%26meid%3Db270f25fcd414d73a428fd33f1e87922%26pid%3D100010%26rk%3D5%26rkt%3D6%26sd%3D232143716621 -
Starting the rebuild after the flood
87Chief replied to RescueDuck33's topic in Member Projects: Your Comanches
Awesome build, and nice house! -
What part of NC are you in? Truck looks amazing!
