jerpderp
1174 profile views
jerpderp's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. The nylon nuts for the speakers are available at NAPA p/n 665-1002. https://www.napaonline.com/en/p/BK_6651002
  2. Went from original 2wd springs to OME 2930s with new spring cushions. I think it only gave me 1.25” over where it sat before. 🤷🏼‍♂️
  3. When I did my swap I didn’t notice a change in the actual alignment, but since I did some lift springs, the steering wheel was off center.
  4. My guess was that BA-10/5 trannys and AX-15 trannys has different shift levers due to the different heights of the shifter housing. The original lever from my 87 has an extra bend to it than the lever I pulled from a 90 XJ. I used my original lever on my NV3550 conversion and the angle of the shift knob is kinda awkward. I think removal of the shift lever is different for later years, but I removed the shifter housing, put the lower section in a vise, and used a punch to knock the lever off. I believe newer shifters have threaded holes in the sides that pull the inner bushing out to relieve some tension and make the process easier. Sent from my iPhone using Tapatalk
  5. jerpderp
    name that part
    Factory service manual in Braille Sent from my iPhone using Tapatalk
  6. My tabs were $30 two years ago, but then county voters approved a GIGANTIC public transportation project. Now they’re $50. 66% increase, but still not bad. People with newer cars really got hosed, sometimes hundreds extra each year. Sent from my iPhone using Tapatalk
  7. I don't have much first hand experience with this, but I've had friends do the junkyard turbo set up. I'd definitely recommend using a used turbo over a Chinese one. Look for Saabs or Volvos, should be pretty cheap. Also try to grab a used intercooler as well just to save $$. Since you don't want to run high boost psi, a smaller intercooler should work fine with less lag. Not sure if this will work space wise, but you may be able to fab an adapter or weld a flange onto the stock manifold. For bottom dollar engine management, megasquirt seems to be the way to go. Good luck Sent from my iPhone using Tapatalk
  8. If I was gonna buy an old diesel, it'd be a dodge. It's so clean, aaaand a manual trans. [emoji7] The tracks are super cool, but beaucoup bucks. I'm sure maintenance isn't cheap/easy either Sent from my iPhone using Tapatalk
  9. By god do I love the wood grain bezel. Been looking for one since I bought my truck. Sent from my iPhone using Tapatalk
  10. Thanks man! Well you've got twice the Comanches to deal with so that's a lot to maintain. All the little things take the most time. Hopefully the Pontiac will get sorta daily status soon. Sent from my iPhone using Tapatalk
  11. The NV3550 was $600 shipped from a junkyard in Nebraska. I'm in WA. Found it on car-part.com(love that site). EVERYONE around here wants $400+ for their clapped out AX15 so I figured I'd spend a bit more for an upgraded trans. It was from a 2000 Cherokee. Tcase is an NP242 from a 91 Cherokee, short input. I talked to the guys at Advance Adapters about tcase inputs, and they said you could use long or short inputs with an NV3550. :dunno: I would prefer a long input just for the extra meat. I can take some pics if you want, there are some little differences you have to deal with. Sent from my iPhone using Tapatalk
  12. H0rnbrod, when I first saw this thread, I thought hell froze over since you always seemed dedicated to the LSV. I am glad all is now right in the world. I do have 1 question though: with your new adjustment, do you think braking will be affected by a load? I'm curious if the valve will turn out of the happy, full braking zone. Sent from my iPhone using Tapatalk
  13. So the Comanche was finally a 4x4. What a day that was. Took it to a stormwater drainage pit in my parents neighborhood to test it out, works flawlessly. My god, what a treat it is to drive with a proper transmission. No offense to you BA10-5 guys, but the NV3550 is night and day. Benefits: NV3550=stronger and shifts nicer, new hydraulics=lighter pedal w/ more feel, new u-joints=no more bad vibes man. Definitely changed the driving experience.
  14. After a few test drives, speedo was shaking violently, did an inspection, found that the inner cable was too long: Word of advice, don't use tin snips to trim the cable, it'll fray. Use a cut off wheel. Now that big work was done, all I had to do was rebuild and install the front drive shaft. Turns out that the double cardan is a bit tricky. It was slow going but I made good progress until it was time to reinstall the slinger. I tried using a punch/hammer and like an animal, I mangled 2 of them(the first one was worse): I finally came to my senses a month or so later and ordered a special installer for $25: Worked like a charm. Highly recommended if you're gonna rebuild your own front driveshaft.
  15. Welp, since its been about six(!) months since a real update,been a bit lazy, and a bit distracted by a new project: But now it's high time to provide the goods. I ended up swapping in the trans/t-case in early April, went pretty well. Old and new, side by side with my friend's doggo, Big Vinny. Definitely a size/weight difference. The actual tranny swap was probably the smoothest R and R I've ever done. But as they say, the devil is in the details. Here's some photographic evidences of issues that tried to derail me: This f#@&!^g exhaust donut had a death grip on my exhaust manifold. :mad: Neither the hammer/pry bar or hammer/chisel methods worked. Had to bring in the angle grinder/cutoff wheel to put a hurtin' on the donut. Cut out a ledge to pry on, only took about 45 minutes... :roll: For some sadistic reason, :fs2: a Jeep engineer decided that a 19mm allen was the ultimate way to remove and reinstall your drain/fill plugs on your NV3550. What normal person has an allen wrench set that goes that high? And I thought the metric square drive plugs on the Peugeot trans were ridiculous. Of course this was at 1 in the morning when I discovered this, but I would not admit defeat. So I found a 19mm bolt and a few nuts and whipped up a drain plug tool. Put the bolt head in the plug, and use a 19mm socket on the nuts to turn it. Words cannot describe the sense of victory I felt at that moment(or was it the lack of sleep?)
