jdog
    2
Everything posted by jdog
  1. That sucks about your floors, that insulation on the carpet holds moisture terribly well. Good luck on the power door locks, they are nice to have.
  2. That is clean and the paint matches nicely
  3. jdog
    Went to Moab:
    That worked for me, looks like a good trip
  4. instead of pushing the yellow thing grab and pill the cable from the back side. once tight then open the throttle from the bell crank or the throttle body, lots of play between the pedal and the throttle body.
  5. jdog
    Well..., Crap!!!
    sucks, looks like a nice truck
  6. jdog
    Tool Talk
    https://www.lislecorp.com/specialty-tools/pickle-fork-kit should be the pickle fork set, comes in handy when you can use a airhammer. Nice find for $40
  7. one more
  8. some corona virus songs
  9. jdog
    What books to read
    Thank you for all the suggestions, kinda surprised there wasn't a book topic on here
  10. Rip
  11. jdog
    What books to read
    That one and the authorities and magic 2.0 are ones I've read a few times
  12. jdog
    What books to read
    I'm open for either ill listen to podcasts to pass the day
  13. Well with the virus running rampant I've now got some free time and I am wondering what books are a must-read to you? These are ones that you've read over and over again for some reason or another. Thank you all for your recommendations.
  14. He's got two more posts to go before the classifieds open up
  15. You have to index it any time you pull it out
  16. Did you index the distributor? Also, more people will see this and assist if you start your own thread instead of hijacking someone elses
  17. https://www.ebay.com/itm/333546893798 Doesn't look bad
  18. Cruiser54.com
  19. Shouldn't have to pump the gas, I'd look at ics sticking, could also be a going bad fuel pump. Have you done cruisers tips?
  20. Did you connect the booster back up, you could have a vacuum leak
  21. Are you using the injectors from the 98 4.0?
  22. What's the plugs look like? I know you just replaced them but with it running rich it could have fouled them, also check for correct firing order
  23. Ok I'll try and get out there in the next day or two
  24. Sounds like you were busy at the yard. Looks like you got some good stuff
