jdog
    2
Everything posted by jdog
  1. Also possible bad new switch. Just because it's new doesn't mean it is good. Stock 1988 swb 4.0 ax15 np 231.
  2. Probably not the correct way but I have the key out, make sure the switch is in the off position. Install switch then run thru the function, start, run and acc, adjusting if needed. Stock 1988 swb 4.0 ax15 np 231.
  3. Got any pictures of it? Stock 1988 swb 4.0 ax15 np 231.
  4. nothing at d1-2 with key on or off? did it have the jumper? if still nothing with key on or jumper check for power at the ignition control module, c2 yellow wire
  5. Gotta ask, what's that in the background, I see a round headlight Stock 1988 swb 4.0 ax15 np 231.
  6. Be sure to start a build thread Stock 1988 swb 4.0 ax15 np 231.
  7. It's just a vibration damper, should be fine with out it Stock 1988 swb 4.0 ax15 np 231.
  8. Can you take a picture of the connector ends please Stock 1988 swb 4.0 ax15 np 231.
  9. Bought a box with tools from someone retiring, probably doesn't know what it does it he's young. Or using an older techs tools till he can get his own as he says it's in the tech box that was off that day Stock 1988 swb 4.0 ax15 np 231.
  10. It will need springs in the front if the rear is spring over axel Stock 1988 swb 4.0 ax15 np 231.
  11. No pictures? Stock 1988 swb 4.0 ax15 np 231.
  12. At least it wasn't a total waste of a day Stock 1988 swb 4.0 ax15 np 231.
  13. might be easier to see it if you drop the column to see the switch,
  14. thats sucks to do all that work just to figure that out
  15. not off hand but google does
  16. easiest way would be while its unplugged see if the hi beams work
  17. i don't have a column in front of me but that looks like the high beam switch
  18. not usually, whats your ohm reading of the fuse link to b3?
  19. People usually do, if they would perform the inspection of it instead of assuming it's bad it be a lot better. If they perform the inspection then all there out is hours worth of time and a 50cent gasket. Stock 1988 swb 4.0 ax15 np 231.
  20. Because out of all the possibilities it's the one that has the most use and fails more often other then a cap, also usually the cheapest fix Stock 1988 swb 4.0 ax15 np 231.
  21. Check the fan clutch, coolant level, was it actually overheating, possible bad sending unit, bad thermostat, is it open or closed cooling system? Stock 1988 swb 4.0 ax15 np 231.
  22. Check the fuse able links near the battery, they look like normal wires but will open like a fuse Stock 1988 swb 4.0 ax15 np 231.
  23. Yep, I'll send you a video tomorrow Stock 1988 swb 4.0 ax15 np 231.
  24. https://www.amazon.com/dp/B009TC5CDU/ref=cm_sw_r_cp_awdb_t1_15cuEbW3WTBVW Stock 1988 swb 4.0 ax15 np 231.
