jdog
    2
Everything posted by jdog
  1. jdog
    Blue gauge cluster
    @saveevryjp1998 The plastic mount cable, six cylinder pictures of the back of the speedo Stock 1988 swb 4.0 ax15 np 231.
  2. What did Walmart do about the turbines? Stock 1988 swb 4.0 ax15 np 231.
  3. jdog
    Blue gauge cluster
    Thank you for the offer but I am looking for the older style if you have any Stock 1988 swb 4.0 ax15 np 231.
  4. jdog
    Blue gauge cluster
    Looking for a blue gauge full cluster for 87-88 years mileage doesn't matter. Stock 1988 swb 4.0 ax15 np 231.
  5. I've got one or two I can send you so when you get a chance to look at Stock 1988 swb 4.0 ax15 np 231.
  6. As eaglescout said, there is two flashers, I'd swap them and see if the issue is still present. Stock 1988 swb 4.0 ax15 np 231.
  7. He wasn't planning on going to Martin's, I suggested it since he was headed to I76. Thanks for stopping by Pete. Stock 1988 swb 4.0 ax15 np 231.
  8. I will have to take back my yeah ill be there. Had something come up, but Pete when your junk yarding let me know and I'll try and come to them Stock 1988 swb 4.0 ax15 np 231.
  9. pretty easy, pull the door panels, the locks are locked in with slide clips and rod clips.
  10. This exactly. When you get fuel line ask for fuel injection fuel line, stuffs expensive but worth it. If you just ask for fuel line they will usually give the cheaper price to make the customer happy. Stock 1988 swb 4.0 ax15 np 231.
  11. Also which boot? Inner outer? Either one there's options if you search. Stock 1988 swb 4.0 ax15 np 231.
  12. He still needs 7 posts before they open up for him. Stock 1988 swb 4.0 ax15 np 231.
  13. Sometimes it's easier to pull the air box to find it Stock 1988 swb 4.0 ax15 np 231.
  14. Can we get some photos of the Interior and dash? Stock 1988 swb 4.0 ax15 np 231.
  15. I just got done swapping windows and locks, I would just do both, the harness needed for the locks is the same, but you could build a harness for just the lock circuit if you wanted. But as stated above why just locks? Stock 1988 swb 4.0 ax15 np 231.
  16. What exactly are you wanting to do? The blocks are the same, it's just the intake and exhaust manifold that is different. If you are just looking to put the motor in to get it going swap the old intake and exhaust manifold from the old one. If your wanting to use the new exhaust and intake I believe you would have to change the Wiring the exhaust down pipe and computer as well. Someone else can correct me if I'm incorrect. Stock 1988 swb 4.0 ax15 np 231.
  17. oh man ELO. and Foghat, can't go on a cruise with out at least playing one of these two artist.
  18. jdog
    Comanche badges
    looks like they hopefully have you taken care of. wish i could have helped, but i only have the early style.
  19. jdog
    Comanche badges
    Which style? Stock 1988 swb 4.0 ax15 np 231.
  20. Yea if they are disconnected from the battery, but connected.... But I'm hoping he means he "reset the memory" in which case I'll agree with you as it does nothing. Stock 1988 swb 4.0 ax15 np 231.
  21. Does this mean you touched the battery cables together with the battery hooked up? Also are you getting power to the coil, have you checked the rotor and making sure it's spinning? Have you checked the crank sensor? Stock 1988 swb 4.0 ax15 np 231.
  22. Perform cruisers tips and check the front harness connector under the airbox on the left side. Stock 1988 swb 4.0 ax15 np 231.
  23. Sounds like it was just one of those gauge on the can and not a full gauge set. So it sounds like it was stagnant but with out a high side I can't be sure. Stock 1988 swb 4.0 ax15 np 231.
  24. Yours will probably pull up differently, I bet the build date will be a day earlier for you, thats just what I got and can remove if you want. Stock 1988 swb 4.0 ax15 np 231.
